C++ Does not Compile on PowerPC
Sat May 5 07:53:21 UTC 2012
On 04/05/12 22:22, Joel Sherrill wrote:
> Hi
> The stdint.h in gcc 4.7.0 has changed and made constants
> like UINT32_MAX hidden to C++ code by default.
> In file included from
> ../../.././psim/lib/include/rtems/score/isr.h:361:0,
>                  from
> ../../.././psim/lib/include/rtems/score/object.h:22,
>                  from ../../.././psim/lib/include/rtems/score/mppkt.h:38,
>                  from
> ../../.././psim/lib/include/rtems/score/thread.h:92,
>                  from ../../.././psim/lib/include/rtems/score/heap.h:22,
>                  from ../../.././psim/lib/include/rtems/rtems/types.h:25,
>                  from ../../.././psim/lib/include/rtems.h:48,
>                  from
> ../../.././psim/lib/include/rtems++/rtemsStatusCode.h:22,
>                  from
> ../../.././psim/lib/include/rtems++/rtemsEvent.h:23,
>                  from
> ../../../../../rtems/c/src/librtems++/src/rtemsEvent.cc:19:
> ../../.././psim/lib/include/rtems/score/isr.inl: In function 'bool
> _ISR_Is_vector_number_valid(uint32_t)':
> ../../.././psim/lib/include/rtems/score/isr.inl:38:22: error:
> 'UINT32_MAX' was not declared in this scope
> Any thoughts on how to address this?
This shows only that the PowerPC CPU port is broken.  We don't define
CPU_SIMPLE_VECTORED_INTERRUPTS thus it is implicitly FALSE.  So we don't
need these
#define CPU_INTERRUPT_NUMBER_OF_VECTORS     (0)
#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (UINT32_MAX)
defines.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
