POSIX key structure in rbtree approach
Mon May 7 15:37:29 UTC 2012
On Mon, May 7, 2012 at 11:16 AM, Ashi <ashi08104 at gmail.com> wrote:
> I'm terribly sorry for my late reply. I'm off for my weekend.
Most of us are. :)
> 2012/5/4 Gedare Bloom <gedare at rtems.org>
>> On Fri, May 4, 2012 at 3:28 AM, Ashi <ashi08104 at gmail.com> wrote:
>> > Hi, all. I'm working on the "Use hash or map in POSIX keys" project.
>> > As Joel said, the first thing to be determined is the problem of what
>> > data goes with each thread and what goes with each key. I find it's
>> > difficult to design the interface without some specific approach. And
>> > since the rbtree api is available in RTEMS, I have tried to do the
>> > design in the rbtree approach.
>> Good. The rbtree should support an efficient map operation.
> Gedare, thanks for your reply!
>> > I find 2 data structures need revised(added): POSIX_Keys_Control and
>> > key_node.
>> > typedef struct {
>> >            Objects_Control     Object;
>> >            void     (*destructor)( void * );
>> >            key_node * key_node_ptr;
>> > }POSIX_Keys_Control;
>> > typedef struct{
>> >          rtems_rbtree_node Node;
>> >          Objects_Id thread_id;
>> >          void **value;
>> > }key_node;
>> > POSIX_Keys_Control is used to manage all keys. And key_node is the
>> > structure contains key data and rbtree node.
>> I think you might want an rtems_rbtree_control key_tree field in
>> POSIX_Keys_Control instead of this key_node* dynamic array.  Then your
>> code can add structs containing an rtems_rbtree_node dynamically to
>> the key_tree.
> After read the rbtree.h in score, I find I confused the rtems_rbtree_node
> and rtems_rbtree_control. It should be the rtems_rbtree_control here.
>> Also the key_node structure should follow a naming convention of
>> POSIX_Keys_Key_node or something similar.
>> API_Package_name_Struct_type_name is the general format for
>> structures. API_Package_name_Method_name is the general format for
>> functions. Note the mixture of lower and upper case letters.
> I see.
>> > I'm not quite sure about the Objects_Control member's function in
>> > current implementation. I find key = Object.id, in which key is
>> > pthread_key_t type, and  _POSIX_Keys_Get(key, &location) is used to
>> > find key's corresponding the_key, which is POSIX_Keys_Control type.So
>> > is it the only function of Object member ?
>> Object_Control means the structure embeds an RTEMS Object so that the
>> structure can be managed by the Object Manager whose responsibilities
>> include pre-allocating enough objects of a certain type to satisfy
>> requests to Create those objects.
>> It seems to me that the Key (key_node) should be the Object since the
>> number of keys is the resource being managed. The present solution
>> uses an array of values (one for each thread) because each thread can
>> have its own version of a given key. The key is "looked up" by the
>> Object Id of the Key and then the requesting thread.  What we should
>> prefer is a more scalable solution that does not require
>> pre-allocating an array of values for all possible threads.  Something
>> like...
>> typedef struct {
>>          void **value;
>> } POSIX_Keys_Control;
>> And maybe a global:
>> rtems_rbtree_control POSIX_Keys_Tree;
> I think this is a new and great idea that I haven't thought before,Does it
> mean a single POSIX_Keys_Tree contains all node in the system?
yes
> I know a rbtree contains only key data belongs to one specific key in my
> design above, and I was thinking the idea of manage all keys by a rbtree,
> then there would be a hiearchy: all keys are in one rbtree, and each key's
> data are in their own rbtrees. But I think this design is a little complex,
> and your idea is more uniform. However, will these two differ much in
> runtime?
not sure because i do not quite understand your design. but I get the
feeling that your design will have a big problem of managing multiple
rbtrees simultaneously. I have not tried to do that before. Both
approaches seem like they would have similar (log-time) asymptotic
behavior.
>> Then you would implement an rbtree_compare function that will combine
>> the POSIX_Keys_control.Object.id with POSIX_Keys_control.thread_id as
>> a "key" for the rbtree to use for storing each POSIX_Keys_Control.
> I see, I can compare POSIX_Keys_control.Object.id first and if they are
> equal, then compare the POSIX_Keys_control.thread_id.
>> all key related operations are described as follow:
>> - key create:
>> create POSIX_Keys_Control instance and intialize an empty rbtree, in
>> which rtems_rbtree_control instance will be created and an rbtree
>> node's key compare function is also needed. Thread_id is compared in
>> the compare function. So this approach doesdn't consider allocate same
>> data for the same thread in the same key, because only different
>> Thread_id are comparable. But I find something about duplicate node in
>> the Gedare's rbtree patch, maybe the duplicate feature also can be
>> added into POSIX key.
>> You still want unique rbtree comparisons so that a thread can
>> distinguish its own keys, unless it is valid for a thread to allocate
>> multiple values with the same key?
>> Key create should not create the red-black tree; the rbtree should be
>> created during initialization of the POSIX_Keys manager---which by the
>> way is improperly named right now as POSIX_Key_Manager_initialization
>> and should be renamed POSIX_Keys_Manager_initialization with an s on
>> Keys (or just POSIX_Keys_Initialization).
> I didn't notice the  POSIX_Key_Manager_initialization before, thanks. BTW
> I've a question about the _Objects_Initialize_information(), which
> _POSIX_Key_Manager_initialization calls. I read the code of
> _Objects_Initialize_information(), but still don't know what the maximum
> parameter is used for? I think it's not for determining the memory size of
> all objects in one manager and then allocating such size of memory, is it?
maximum determines the total number of that kind of object. it is
controlled by some CONFIGURE_MAXIMUM_XXX, e.g.
CONIFIGURE_MAXIMUM_POSIX_KEYS.
-Gedare
>> > - key delete
>> > delete all the nodes in rbtree by rtems_rbtree_get_min() or
>> > rtems_rbtree_get_max(), and delete the RBTree_Control,
>> > POSIX_Keys_Control instance. The key data's deallocation is done by
>> > user.
>> > - key get specific
>> > we can use _RBTree_Find() to do the actually work behind
>> > get_specific(),  the runtime is O(log(n))
>> > - key set specific
>> > after a proper key_node is create, we can use _RBTree_Insert() to do
>> > the set specific. the runtime is rbtree insert runtime, which is
>> > O(log(n)).
>> > I'm not sure whether this design is appropriate and this design is
>> > very simple, need many more work to do. Hope further discussion to
>> > make it more clear!
>> Simple is good. I think you're on the right track other than my few
>> comments about organizing the structures. You have the right ideas for
>> how to implement the Keys functions I believe.
>> -Gedare
> Yeah, it remind me the K.I.S.S. principle!
> -best regards!
> -zw_yao
>> > --best regards!
>> > --zw_yao
>> > _______________________________________________
>> > rtems-devel mailing list
>> > rtems-devel at rtems.org
>> > http://www.rtems.org/mailman/listinfo/rtems-devel
