[PATCH 1/3] Filesystem: PR1398: Fix lseek() mechanic
Tue May 8 19:17:13 UTC 2012
On 08/05/12 08:43, Chris Johns wrote:
> On 8/05/12 3:34 PM, Sebastian Huber wrote:
>> Is the complex rtems_rfs_rtems_file_lseek() really necessary? What
>> happens if we simply change the iop->offset? Will the read and write
>> handler cope with that?
> I do not know. The current file seek code plays with buffers. I am not
> sure what effect this may have if the code was removed. I can see
> moving this code would make the seek cheaper and if someone is seeking
> with no I/O there is a cost.
> Is there another issue I am missing ?
I only wondered why the [PATCH 2/3] Filesystem: PR1871: Fix O_APPEND
works (mrfs_fsrdwr test case).
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
