[PATCH 35 v4] LEON: moved register definitions into grlib header file
Wed May 16 17:31:10 UTC 2012
Looks ok to me.
On 05/16/2012 10:20 AM, Daniel Hellstrom wrote:
> Some register layout definitions for LEON3 reside in ambapp.h which
> does not really has anything to do with device registers. The
> register structures has been incorrectly named LEON3_*, the cores
> are not only used on LEON3 but on LEON4 and perhaps on LEON5 when
> that day comes. Some structures has been renamed according to the
> GRLIB core name instead, which CPU that actually use it is not
> relevant. Drivers has been updated with the new names.
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>   c/src/lib/libbsp/sparc/Makefile.am                 |    1 +
>   c/src/lib/libbsp/sparc/leon2/Makefile.am           |    1 +
>   c/src/lib/libbsp/sparc/leon2/preinstall.am         |    4 +
>   c/src/lib/libbsp/sparc/leon2/rasta/rasta.c         |   29 +------
>   c/src/lib/libbsp/sparc/leon3/Makefile.am           |    1 +
>   c/src/lib/libbsp/sparc/leon3/amba/amba.c           |    7 +-
>   c/src/lib/libbsp/sparc/leon3/clock/ckinit.c        |   10 +-
>   c/src/lib/libbsp/sparc/leon3/console/console.c     |   10 +-
>   .../libbsp/sparc/leon3/console/printk_support.c    |    8 +-
>   c/src/lib/libbsp/sparc/leon3/include/amba.h        |    1 +
>   c/src/lib/libbsp/sparc/leon3/include/leon.h        |   28 +------
>   .../sparc/leon3/leon_smc91111/leon_smc91111.c      |   12 ++--
>   c/src/lib/libbsp/sparc/leon3/preinstall.am         |    4 +
>   c/src/lib/libbsp/sparc/leon3/timer/timer.c         |    4 +-
>   c/src/lib/libbsp/sparc/shared/can/grcan.c          |    5 +-
>   c/src/lib/libbsp/sparc/shared/can/occan.c          |    5 +-
>   c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c         |    5 +-
>   c/src/lib/libbsp/sparc/shared/include/ambapp.h     |   43 ---------
>   c/src/lib/libbsp/sparc/shared/include/grlib.h      |   91 ++++++++++++++++++++
>   c/src/lib/libbsp/sparc/shared/spw/grspw.c          |    5 +-
>   c/src/lib/libbsp/sparc/shared/uart/apbuart.c       |   13 ++--
>   21 files changed, 153 insertions(+), 134 deletions(-)
>   create mode 100644 c/src/lib/libbsp/sparc/shared/include/grlib.h
> diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
> index 2b9909c..e0c7de6 100644
> --- a/c/src/lib/libbsp/sparc/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/Makefile.am
> @@ -18,6 +18,7 @@ EXTRA_DIST += shared/irq/irq-shared.c
>   # AMBA Plug&Play bus
>   EXTRA_DIST += shared/include/ambapp.h
>   EXTRA_DIST += shared/include/ambapp_ids.h
> +EXTRA_DIST += shared/include/grlib.h
>   EXTRA_DIST += shared/amba/ambapp.c
>   EXTRA_DIST += shared/amba/ambapp_alloc.c
>   EXTRA_DIST += shared/amba/ambapp_count.c
> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> index c2310bc..d4135fa 100644
> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> @@ -82,6 +82,7 @@ libbsp_a_SOURCES += \
>   # AMBA bus
>   include_HEADERS += ../../sparc/shared/include/ambapp.h
>   include_HEADERS += ../../sparc/shared/include/ambapp_ids.h
> +include_HEADERS += ../../sparc/shared/include/grlib.h
>   libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp.c
>   libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_alloc.c
>   libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_count.c
> diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
> index 2978d58..84aa2b4 100644
> --- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
> @@ -161,6 +161,10 @@ $(PROJECT_INCLUDE)/ambapp_ids.h: ../../sparc/shared/include/ambapp_ids.h $(PROJE
>          $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/ambapp_ids.h
>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp_ids.h
> +$(PROJECT_INCLUDE)/grlib.h: ../../sparc/shared/include/grlib.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/grlib.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/grlib.h
>   $(PROJECT_INCLUDE)/i2cmst.h: ../../sparc/shared/include/i2cmst.h $(PROJECT_INCLUDE)/$(dirstamp)
>          $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/i2cmst.h
>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/i2cmst.h
> diff --git a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
> index 0be7e4b..087f9be 100644
> --- a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
> +++ b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
> @@ -10,6 +10,7 @@
>   #include<pci.h>
>   #include<rasta.h>
>   #include<ambapp.h>
> +#include<grlib.h>
>   #include<grcan_rasta.h>
>   #include<grspw_rasta.h>
>   #include<b1553brm_rasta.h>
> @@ -41,32 +42,10 @@
>   #define DBG(x...)
>   #endif
> -typedef struct {
> -  volatile unsigned int ilevel;
> -  volatile unsigned int ipend;
> -  volatile unsigned int iforce;
> -  volatile unsigned int iclear;
> -  volatile unsigned int mpstat;
> -  volatile unsigned int notused01;
> -  volatile unsigned int notused02;
> -  volatile unsigned int notused03;
> -  volatile unsigned int notused10;
> -  volatile unsigned int notused11;
> -  volatile unsigned int notused12;
> -  volatile unsigned int notused13;
> -  volatile unsigned int notused20;
> -  volatile unsigned int notused21;
> -  volatile unsigned int notused22;
> -  volatile unsigned int notused23;
> -  volatile unsigned int mask[16];
> -  volatile unsigned int force[16];
> -} LEON3_IrqCtrl_Regs_Map;
>   static int bus, dev, fun;
> -LEON3_IrqCtrl_Regs_Map *irq = NULL;
> -LEON_Register_Map      *regs = (LEON_Register_Map *)0x80000000;
> +struct irqmp_regs *irq = NULL;
> +LEON_Register_Map *regs = (LEON_Register_Map *)0x80000000;
>   struct gpio_reg *gpio0, *gpio1;
> @@ -291,7 +270,7 @@ int rasta_register(void)
>       apb_base[2] = 0x000e8000;
>   #endif
>       /* Set up rasta irq controller */
> -    irq = (LEON3_IrqCtrl_Regs_Map *) (bar0+IRQ_OFFSET);
> +    irq = (struct irqmp_regs *) (bar0+IRQ_OFFSET);
>       irq->iclear = 0xffff;
>       irq->ilevel = 0;
>       irq->mask[0] = 0xffff&  ~(UART0_IRQ|UART1_IRQ|SPW0_IRQ|SPW1_IRQ|SPW2_IRQ|GRCAN_IRQ|BRM_IRQ);
> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> index f3153f1..e6a04d9 100644
> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> @@ -48,6 +48,7 @@ libbsp_a_SOURCES += gnatsupp/gnatsupp.c ../../sparc/shared/gnatcommon.c
>   include_HEADERS += include/amba.h
>   libbsp_a_SOURCES += amba/amba.c
> diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> index 60281f3..d782d76 100644
> --- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> +++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> @@ -27,7 +27,7 @@ struct ambapp_bus ambapp_plb;
>   extern void leon3_ext_irq_init(void);
>   /* Pointers to Interrupt Controller configuration registers */
> -volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;
> +volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
>    *  amba_initialize
> @@ -63,8 +63,7 @@ void amba_initialize(void)
>       asm volatile( "mov 1, %g1; ta 0x0" );
> -  LEON3_IrqCtrl_Regs = (volatile LEON3_IrqCtrl_Regs_Map *)
> -                       DEV_TO_APB(adev)->start;
> +  LEON3_IrqCtrl_Regs = (volatile struct irqmp_regs *)DEV_TO_APB(adev)->start;
>     if ((LEON3_IrqCtrl_Regs->ampctrl>>  28)>  0) {
>       /* IRQ Controller has support for multiple IRQ Controllers, each
>        * CPU can be routed to different Controllers, we find out which
> @@ -87,7 +86,7 @@ void amba_initialize(void)
>                                    VENDOR_GAISLER, GAISLER_GPTIMER,
>                                    ambapp_find_by_idx, NULL);
>     if (adev) {
> -    LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *)DEV_TO_APB(adev)->start;
> +    LEON3_Timer_Regs = (volatile struct gptimer_regs *)DEV_TO_APB(adev)->start;
>       /* Register AMBA Bus Frequency */
>       ambapp_freq_init(&ambapp_plb, adev,
> diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> index 2a75a35..ce47cb6 100644
> --- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> +++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
> @@ -38,7 +38,7 @@
>   #endif
> -volatile LEON3_Timer_Regs_Map *LEON3_Timer_Regs = 0;
> +volatile struct gptimer_regs *LEON3_Timer_Regs = 0;
>   static int clkirq;
>   #define CLOCK_VECTOR LEON_TRAP_TYPE( clkirq )
> @@ -65,9 +65,9 @@ static int clkirq;
>                 VENDOR_GAISLER, GAISLER_GPTIMER, ambapp_find_by_idx, NULL); \
>       if (adev) { \
>         /* Found APB GPTIMER Timer */ \
> -      LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) \
> +      LEON3_Timer_Regs = (volatile struct gptimer_regs *) \
>                            DEV_TO_APB(adev)->start; \
> -      clkirq = (LEON3_Timer_Regs->status&  0xf8)>>  3; \
> +      clkirq = (LEON3_Timer_Regs->cfg&  0xf8)>>  3; \
>         Adjust_clkirq_for_node(); \
> @@ -83,7 +83,7 @@ static int clkirq;
>       LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].reload = \
>         rtems_configuration_get_microseconds_per_tick() - 1; \
> -    LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].conf = \
> +    LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].ctrl = \
>         LEON3_GPTIMER_EN | LEON3_GPTIMER_RL | \
>           LEON3_GPTIMER_LD | LEON3_GPTIMER_IRQEN; \
>     } while (0)
> @@ -91,7 +91,7 @@ static int clkirq;
>   #define Clock_driver_support_shutdown_hardware() \
>     do { \
>       LEON_Mask_interrupt(LEON_TRAP_TYPE(clkirq)); \
> -    LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].conf = 0; \
> +    LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].ctrl = 0; \
>     } while (0)
>   uint32_t bsp_clock_nanoseconds_since_last_tick(void)
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
> index 0575468..3870685 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
> @@ -49,14 +49,14 @@ int syscon_uart_index __attribute__((weak)) = 0;
>   extern void apbuart_outbyte_polled(
> -  ambapp_apb_uart *regs,
> +  struct apbuart_regs *regs,
>     unsigned char ch,
>     int do_cr_on_newline,
>     int wait_sent
> -/* body is in debugputs.c */
> +/* body is in printk_support.c */
>    *  apbuart_inbyte_nonblocking
> @@ -64,12 +64,12 @@ extern void apbuart_outbyte_polled(
>    *  This routine polls for a character.
> -extern int apbuart_inbyte_nonblocking(ambapp_apb_uart *regs);
> +extern int apbuart_inbyte_nonblocking(struct apbuart_regs *regs);
>   struct apbuart_priv {
> -  ambapp_apb_uart *regs;
> +  struct apbuart_regs *regs;
>     unsigned int freq_hz;
>   #if CONSOLE_USE_INTERRUPTS
>     int irq;
> @@ -252,7 +252,7 @@ int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
>     struct ambapp_apb_info *apb = (struct ambapp_apb_info *)dev->devinfo;
>     /* Extract needed information of one APBUART */
> -  apbuarts[uarts].regs = (ambapp_apb_uart *)apb->start;
> +  apbuarts[uarts].regs = (struct apbuart_regs *)apb->start;
>     apbuarts[uarts].irq = apb->irq;
>   #endif
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
> index 080d4fa..9815053 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
> @@ -29,7 +29,7 @@
>   int debug_uart_index __attribute__((weak)) = 0;
> -ambapp_apb_uart *dbg_uart = NULL;
> +struct apbuart_regs *dbg_uart = NULL;
>   /* Before UART driver has registered (or when no UART is available), calls to
>    * printk that gets to bsp_out_char() will be filling data into the
> @@ -74,7 +74,7 @@ int bsp_debug_uart_init(void)
>        * for printk
>       apb = (struct ambapp_apb_info *)adev->devinfo;
> -    dbg_uart = (ambapp_apb_uart *)apb->start;
> +    dbg_uart = (struct apbuart_regs *)apb->start;
>       dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
>       dbg_uart->status = 0;
>       return 1;
> @@ -88,7 +88,7 @@ int bsp_debug_uart_init(void)
>    *  This routine transmits a character using polling.
>     unsigned char ch,
>     int wait_sent
> @@ -121,7 +121,7 @@ send:
> -int apbuart_inbyte_nonblocking(ambapp_apb_uart *regs)
> +int apbuart_inbyte_nonblocking(struct apbuart_regs *regs)
>     /* Clear errors */
>     if (regs->status&  LEON_REG_UART_STATUS_ERR)
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/amba.h b/c/src/lib/libbsp/sparc/leon3/include/amba.h
> index 32b4a42..a4a0ac9 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/amba.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/amba.h
> @@ -27,6 +27,7 @@
>   #define LEON3_APB_SLAVES 16
>   #include<ambapp.h>
> +#include<grlib.h>
>   #ifdef __cplusplus
>   extern "C" {
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> index da752b2..96a4262 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> @@ -46,30 +46,6 @@ extern "C" {
>     ( (_trap)>= 0x11&&  \
>       (_trap)<= 0x1F )
> -typedef struct {
> -  volatile unsigned int value;
> -  volatile unsigned int reload;
> -  volatile unsigned int conf;
> -  volatile unsigned int notused;
> -} LEON3_Timer_SubType;
> -typedef struct {
> -  volatile unsigned int scaler_value;   /* common timer registers */
> -  volatile unsigned int scaler_reload;
> -  volatile unsigned int status;
> -  LEON3_Timer_SubType timer[8];
> -} LEON3_Timer_Regs_Map;
> -typedef struct {
> -  volatile unsigned int iodata;
> -  volatile unsigned int ioout;
> -  volatile unsigned int iodir;
> -  volatile unsigned int irqmask;
> -  volatile unsigned int irqpol;
> -  volatile unsigned int irqedge;
> -} LEON3_IOPORT_Regs_Map;
>   /*  *  This is used to manipulate the on-chip registers. */
> @@ -139,8 +115,8 @@ typedef struct {
>   #define LEON_REG_UART_CTRL_FL     0x00000040 /* Flow control enable */
>   #define LEON_REG_UART_CTRL_LB     0x00000080 /* Loop Back enable */
> -extern volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;  /* LEON3 Interrupt Controller */
> -extern volatile LEON3_Timer_Regs_Map *LEON3_Timer_Regs; /* LEON3 GP Timer */
> +extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;  /* LEON3 Interrupt Controller */
> +extern volatile struct gptimer_regs *LEON3_Timer_Regs; /* LEON3 GP Timer */
>   /* LEON3 CPU Index of boot CPU */
>   extern int LEON3_Cpu_Index;
> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> index 9e582fb..9b9961d 100644
> --- a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> +++ b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> @@ -34,7 +34,7 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
>                                      int attach)
>     unsigned long addr_mctrl = 0;
> -  LEON3_IOPORT_Regs_Map *io;
> +  struct grgpio_regs *io;
>     struct ambapp_apb_info apbpio;
>     struct ambapp_apb_info apbmctrl;
> @@ -63,7 +63,7 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
>     /* Get  controller address */
>     addr_mctrl = (unsigned long) apbmctrl.start;
> -  io = (LEON3_IOPORT_Regs_Map *) apbpio.start;
> +  io = (struct grgpio_regs *) apbpio.start;
>     printk(
>           "Activating Leon3 io port for smsc_lan91cxx (pio:%x mctrl:%x)\n",
> @@ -71,10 +71,10 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
>           (unsigned int)addr_mctrl);
>     /* Setup PIO IRQ */
> -  io->irqmask |= (1<<  leon_scmv91111_configuration.pio);
> -  io->irqpol |= (1<<  leon_scmv91111_configuration.pio);
> -  io->irqedge |= (1<<  leon_scmv91111_configuration.pio);
> -  io->iodir&= ~(1<<  leon_scmv91111_configuration.pio);
> +  io->imask |= (1<<  leon_scmv91111_configuration.pio);
> +  io->ipol |= (1<<  leon_scmv91111_configuration.pio);
> +  io->iedge |= (1<<  leon_scmv91111_configuration.pio);
> +  io->dir&= ~(1<<  leon_scmv91111_configuration.pio);
>     /* Setup memory controller I/O waitstates */
>     *((volatile unsigned int *) addr_mctrl) |= 0x10f80000;       /* enable I/O area access */
> diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
> index 540e37b..dffbb5a 100644
> --- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
> @@ -89,6 +89,10 @@ $(PROJECT_INCLUDE)/ambapp_ids.h: ../../sparc/shared/include/ambapp_ids.h $(PROJE
>   $(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>          $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/bsp/irq-generic.h
>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
> diff --git a/c/src/lib/libbsp/sparc/leon3/timer/timer.c b/c/src/lib/libbsp/sparc/leon3/timer/timer.c
> index f747dd6..241ecb8 100644
> --- a/c/src/lib/libbsp/sparc/leon3/timer/timer.c
> +++ b/c/src/lib/libbsp/sparc/leon3/timer/timer.c
> @@ -35,7 +35,7 @@ bool benchmark_timer_find_average_overhead;
>   bool benchmark_timer_is_initialized = false;
>   void benchmark_timer_initialize(void)
> @@ -50,7 +50,7 @@ void benchmark_timer_initialize(void)
>       } else {
>         benchmark_timer_is_initialized = true;
> -    LEON3_Timer_Regs->timer[LEON3_TIMER_INDEX].conf = LEON3_GPTIMER_EN | LEON3_GPTIMER_LD;
> +    LEON3_Timer_Regs->timer[LEON3_TIMER_INDEX].ctrl = LEON3_GPTIMER_EN | LEON3_GPTIMER_LD;
> diff --git a/c/src/lib/libbsp/sparc/shared/can/grcan.c b/c/src/lib/libbsp/sparc/shared/can/grcan.c
> index 3b0a14a..d592fba 100644
> --- a/c/src/lib/libbsp/sparc/shared/can/grcan.c
> +++ b/c/src/lib/libbsp/sparc/shared/can/grcan.c
> @@ -26,6 +26,7 @@
>   #include<grcan.h>
>   #include<ambapp.h>
> +#include<grlib.h>
>   #define WRAP_AROUND_TX_MSGS 1
>   #define WRAP_AROUND_RX_MSGS 2
> @@ -1097,11 +1098,11 @@ static rtems_device_driver grcan_initialize(
>     /* LEON3: find timer address via AMBA Plug&Play info */
>       struct ambapp_apb_info gptimer;
> -    LEON3_Timer_Regs_Map *tregs;
> +    struct gptimer_regs *tregs;
>       if (ambapp_find_apbslv (&ambapp_plb, VENDOR_GAISLER, GAISLER_GPTIMER,&gptimer)
>           == 1) {
> -      tregs = (LEON3_Timer_Regs_Map *) gptimer.start;
> +      tregs = (struct gptimer_regs *) gptimer.start;
>         sys_freq_hz = (tregs->scaler_reload + 1) * 1000 * 1000;
>         DBG("GRCAN: detected %dHZ system frequency\n\r", sys_freq_hz);
>       } else {
> diff --git a/c/src/lib/libbsp/sparc/shared/can/occan.c b/c/src/lib/libbsp/sparc/shared/can/occan.c
> index 4fb932d..b1bf54e 100644
> --- a/c/src/lib/libbsp/sparc/shared/can/occan.c
> +++ b/c/src/lib/libbsp/sparc/shared/can/occan.c
> @@ -19,6 +19,7 @@
>   #include<leon.h>
>   #include<ambapp.h>
> +#include<grlib.h>
>   #include<occan.h>
>   /* RTEMS ->  ERRNO decoding table
> @@ -936,11 +937,11 @@ static rtems_device_driver occan_initialize(rtems_device_major_number major, rte
>                  if ( ambapp_find_apbslv(&ambapp_plb, VENDOR_GAISLER,
>                                           GAISLER_GPTIMER,&gptimer) == 1 ){
> -                       tregs = (LEON3_Timer_Regs_Map *)gptimer.start;
> +                       tregs = (struct gptimer_regs *)gptimer.start;
>                          sys_freq_hz = (tregs->scaler_reload+1)*1000*1000;
>                          DBG("OCCAN: detected %dHZ system frequency\n\r",sys_freq_hz);
>                  }else{
> diff --git a/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c b/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
> index 7ba7208..7acf17d 100644
> --- a/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
> +++ b/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
> @@ -17,6 +17,7 @@
>   #include<bsp.h>
>   #include<i2cmst.h>
>   #include<ambapp.h>
> +#include<grlib.h>
>   #include<rtems/libi2c.h>
>   /* Enable debug printks? */
> @@ -318,11 +319,11 @@ rtems_status_code leon_register_i2c(struct ambapp_bus *abus)
>            if (ambapp_find_apbslv(abus, VENDOR_GAISLER,
>                                   GAISLER_GPTIMER,&gptimer) == 1 ) {
>              gr_i2cmst_desc.prv.sysfreq = (tregs->scaler_reload+1)*1000;
>            } else {
>              gr_i2cmst_desc.prv.sysfreq = 40000; /* Default to 40MHz */
> diff --git a/c/src/lib/libbsp/sparc/shared/include/ambapp.h b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> index 5eb3f2a..c3fd13a 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> @@ -355,49 +355,6 @@ extern int ambapp_find_ahbslvs(
>          int maxno);
> -/******** AMBA DEVICES *******/
> -/* ESA MEMORY CONTROLLER */
> -typedef struct {
> -  unsigned int mcfg1;
> -  unsigned int mcfg2;
> -  unsigned int mcfg3;
> -} ambapp_regmap_mctrl;
> -/* APB UART */
> -typedef struct {
> -  volatile unsigned int data;
> -  volatile unsigned int ctrl;
> -  volatile unsigned int scaler;
> -} ambapp_apb_uart;
> -typedef struct {
> -  volatile unsigned int ampctrl;
> -  volatile unsigned int icsel[2];
> -  /* Extended IRQ registers */
> -  volatile unsigned int intid[16];
> -  /* 0x100, align to 4Kb boundary */
> -  volatile unsigned int resv1[(0x1000-0x100)/4];
>   #ifdef __cplusplus
>   #endif
> diff --git a/c/src/lib/libbsp/sparc/shared/include/grlib.h b/c/src/lib/libbsp/sparc/shared/include/grlib.h
> new file mode 100644
> index 0000000..7f1f7d0
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/include/grlib.h
> @@ -0,0 +1,91 @@
> + *  Common GRLIB AMBA Core Register definitions
> + *  COPYRIGHT (c) 2012
> + *  Aeroflex Gaisler
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.com/license/LICENSE.
> +#ifndef __GRLIB_H__
> +#define __GRLIB_H__
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +/* ESA MEMORY CONTROLLER */
> +struct mctrl_regs {
> +  unsigned int mcfg1;
> +  unsigned int mcfg2;
> +  unsigned int mcfg3;
> +/* APB UART */
> +struct apbuart_regs {
> +  volatile unsigned int data;
> +  volatile unsigned int status;
> +  volatile unsigned int ctrl;
> +  volatile unsigned int scaler;
> +/* IRQMP and IRQAMP interrupt controllers */
> +struct irqmp_regs {
> +  volatile unsigned int ilevel;      /* 0x00 */
> +  volatile unsigned int ipend;       /* 0x04 */
> +  volatile unsigned int iforce;      /* 0x08 */
> +  volatile unsigned int iclear;      /* 0x0c */
> +  volatile unsigned int mpstat;      /* 0x10 */
> +  volatile unsigned int bcast;       /* 0x14 */
> +  volatile unsigned int notused02;   /* 0x18 */
> +  volatile unsigned int notused03;   /* 0x1c */
> +  volatile unsigned int ampctrl;     /* 0x20 */
> +  volatile unsigned int icsel[2];    /* 0x24,0x28 */
> +  volatile unsigned int notused13;   /* 0x2c */
> +  volatile unsigned int notused20;   /* 0x30 */
> +  volatile unsigned int notused21;   /* 0x34 */
> +  volatile unsigned int notused22;   /* 0x38 */
> +  volatile unsigned int notused23;   /* 0x3c */
> +  volatile unsigned int mask[16];    /* 0x40 */
> +  volatile unsigned int force[16];   /* 0x80 */
> +  /* Extended IRQ registers */
> +  volatile unsigned int intid[16];   /* 0xc0 */
> +  /* 0x100, align to 4Kb boundary */
> +  volatile unsigned int resv1[(0x1000-0x100)/4];
> +/* GPTIMER Timer instance */
> +struct gptimer_timer_regs {
> +  volatile unsigned int value;
> +  volatile unsigned int reload;
> +  volatile unsigned int notused;
> +/* GPTIMER common registers */
> +struct gptimer_regs {
> +  volatile unsigned int scaler_value;   /* common timer registers */
> +  volatile unsigned int scaler_reload;
> +  volatile unsigned int cfg;
> +  struct gptimer_timer_regs timer[7];
> +/* GRGPIO GPIO */
> +struct grgpio_regs {
> +  volatile unsigned int data;        /* 0x00 I/O port data register */
> +  volatile unsigned int output;      /* 0x04 I/O port output register */
> +  volatile unsigned int dir;         /* 0x08 I/O port direction register */
> +  volatile unsigned int imask;       /* 0x0C Interrupt mask register */
> +  volatile unsigned int ipol;        /* 0x10 Interrupt polarity register */
> +  volatile unsigned int iedge;       /* 0x14 Interrupt edge register */
> +  volatile unsigned int bypass;      /* 0x18 Bypass register */
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw.c b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
> index 8ab5020..55986ba 100644
> --- a/c/src/lib/libbsp/sparc/shared/spw/grspw.c
> +++ b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
> @@ -83,6 +83,7 @@
>   #include<ctype.h>
>   #include<rtems/bspIo.h>
>   #include<ambapp.h>
> +#include<grlib.h>
>   #include<grspw.h>
>   #define DBGSPW_IOCALLS 1
> @@ -390,11 +391,11 @@ int GRSPW_PREFIX(_register)(struct ambapp_bus *bus)
>                          sys_freq_khz = (tregs->scaler_reload+1)*1000;
>                          SPACEWIRE_DBG("GRSPW: detected %dkHZ system frequency\n\r",sys_freq_khz);
>                  }else{
> diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
> index d442e80..25d0373 100644
> --- a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
> +++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
> @@ -22,6 +22,7 @@
>   #include<string.h>
>   #include<ambapp.h>
> +#include<grlib.h>
>   #include<apbuart.h>
>   #ifndef DEFAULT_TXBUF_SIZE
> @@ -79,7 +80,7 @@ static rtems_device_driver apbuart_write(rtems_device_major_number major, rtems_
>   static rtems_device_driver apbuart_control(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
>   typedef struct {
>          int irq;
>          int minor;
>          int scaler;
> @@ -153,7 +154,7 @@ static void apbuart_hw_open(apbuart_priv *uart);
>   #endif
>   #if 0
> -static int apbuart_outbyte_try(ambapp_apb_uart *regs,  unsigned char ch)
> +static int apbuart_outbyte_try(struct apbuart_regs *regs, unsigned char ch)
>          if ( (READ_REG(&regs->status)&  LEON_REG_UART_STATUS_THE) == 0 )
>                  return -1; /* Failed */
> @@ -164,7 +165,7 @@ static int apbuart_outbyte_try(ambapp_apb_uart *regs,  unsigned char ch)
> -static int apbuart_inbyte_try(ambapp_apb_uart *regs)
> +static int apbuart_inbyte_try(struct apbuart_regs *regs)
>          /* Clear errors if any */
> @@ -386,11 +387,11 @@ static rtems_device_driver apbuart_initialize(rtems_device_major_number  major,
>                          DBG("APBUART: detected %dHZ system frequency\n\r",sys_freq_hz);
>                  }else{
> @@ -419,7 +420,7 @@ static rtems_device_driver apbuart_initialize(rtems_device_major_number  major,
>                  printk("APBUART[%d]: at 0x%x irq %d (0x%x)\n\r",i,dev.start,dev.irq,(unsigned int)&apbuarts[i]);
> -               apbuarts[i].regs = (ambapp_apb_uart *)dev.start;
> +               apbuarts[i].regs = (struct apbuart_regs *)dev.start;
>                  apbuarts[i].irq = dev.irq;
>                  apbuarts[i].minor = i;
> 1.7.0.4
Joel Sherrill, Ph.D.             Director of Research&   Development
