[PATCH] libtests/complex: Avoid generated files
Mon May 21 14:48:35 UTC 2012
Just to make sure I am interpreting this right, you just
modified the code to use macros and do the same
thing at compile time.
On 05/21/2012 09:44 AM, sebastian.huber at embedded-brains.de wrote:
> From: Sebastian Huber<sebastian.huber at embedded-brains.de>
> Use C pre-processor instead of shell commands.
>   testsuites/libtests/complex/Makefile.am  |   20 -----
>   testsuites/libtests/complex/docomplex.c  |  104 +-------------------------
>   testsuites/libtests/complex/docomplex.h  |  118 ++++++++++++++++++++++++++++++
>   testsuites/libtests/complex/docomplex.in |  116 -----------------------------
>   testsuites/libtests/complex/docomplexf.c |  104 +-------------------------
>   testsuites/libtests/complex/docomplexl.c |  104 +-------------------------
>   6 files changed, 133 insertions(+), 433 deletions(-)
>   create mode 100644 testsuites/libtests/complex/docomplex.h
>   delete mode 100644 testsuites/libtests/complex/docomplex.in
> diff --git a/testsuites/libtests/complex/Makefile.am b/testsuites/libtests/complex/Makefile.am
> index 2a16eec..7861d4a 100644
> --- a/testsuites/libtests/complex/Makefile.am
> +++ b/testsuites/libtests/complex/Makefile.am
> @@ -2,30 +2,10 @@ if HAS_COMPLEX
>   rtems_tests_PROGRAMS = complex
>   complex_SOURCES = init.c docomplex.c docomplexf.c docomplexl.c
>   endif
> -EXTRA_DIST = docomplex.in
>   # FIXME: Skip long double, not yet supported in newlib
>   complex_CPPFLAGS = $(AM_CPPFLAGS) -DNO_LONG_DOUBLE
> -docomplex.c: $(srcdir)/docomplex.in
> -       sed -e 's,[@]FTYPE[@],double,' \
> -       -e 's,[@]FSUFFIX[@], ,g' \
> -       -e 's,[@]FGUARD[@],NO_DOUBLE,' \
> -       $(srcdir)/docomplex.in>  $(srcdir)/docomplex.c
> -docomplexf.c: $(srcdir)/docomplex.in
> -       sed -e 's,[@]FTYPE[@],float,' \
> -       -e 's,[@]FSUFFIX[@],f,g' \
> -       -e 's,[@]FGUARD[@],NO_FLOAT,' \
> -       $(srcdir)/docomplex.in>  $(srcdir)/docomplexf.c
> -docomplexl.c: $(srcdir)/docomplex.in
> -       sed -e 's,[@]FTYPE[@],long double,' \
> -       -e 's,[@]FSUFFIX[@],l,g' \
> -       -e 's,%f,%Lf,g' \
> -       -e 's,[@]FGUARD[@],NO_LONG_DOUBLE,' \
> -       $(srcdir)/docomplex.in>  $(srcdir)/docomplexl.c
>   dist_rtems_tests_DATA = complex.scn
>   include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> diff --git a/testsuites/libtests/complex/docomplex.c b/testsuites/libtests/complex/docomplex.c
> index 7a1b961..eb8d3df 100644
> --- a/testsuites/libtests/complex/docomplex.c
> +++ b/testsuites/libtests/complex/docomplex.c
> @@ -11,106 +11,12 @@
>   #ifdef HAVE_CONFIG_H
> -#include "config.h"
> +  #include "config.h"
>   #endif
> -#include<complex.h>
> -#include<stdio.h>
> -extern void docomplex  (void);
> -void
> -docomplex  (void)
>   #ifndef NO_DOUBLE
> -  complex double ca, cb, cc;
> -  double f1;
> -  ca = 1.0 + 1.0 * I;
> -  cb = 1.0 - 1.0 * I;
> -  f1 = cabs  (ca);
> -  fprintf (stdout, "cabs   : %f\n", f1);
> -  cc = cacos  (ca);
> -  fprintf (stdout, "cacos  : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = cacosh  (ca);
> -  fprintf (stdout, "cacosh : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  f1 = carg  (ca);
> -  fprintf (stdout, "carg   : %f\n", f1);
> -  cc = casin  (ca);
> -  fprintf (stdout, "casin  : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = casinh  (ca);
> -  fprintf (stdout, "casinh : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = catan  (ca);
> -  fprintf (stdout, "catan  : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = catanh  (ca);
> -  fprintf (stdout, "catanh : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = ccos  (ca);
> -  fprintf (stdout, "ccos   : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = ccosh  (ca);
> -  fprintf (stdout, "ccosh  : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = cexp  (ca);
> -  fprintf (stdout, "cexp   : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  f1 = cimag  (ca);
> -  fprintf (stdout, "cimag  : %f\n", f1);
> -  cc = clog  (ca);
> -  fprintf (stdout, "clog   : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = conj  (ca);
> -  fprintf (stdout, "conj   : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = cpow  (ca, cb);
> -  fprintf (stdout, "cpow   : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = cproj  (ca);
> -  fprintf (stdout, "cproj  : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  f1 = creal  (ca);
> -  fprintf (stdout, "creal  : %f\n", f1);
> -  cc = csin  (ca);
> -  fprintf (stdout, "csin   : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = csinh  (ca);
> -  fprintf (stdout, "csinh  : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = csqrt  (ca);
> -  fprintf (stdout, "csqrt  : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = ctan  (ca);
> -  fprintf (stdout, "ctan   : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> -  cc = ctanh  (ca);
> -  fprintf (stdout, "ctanh  : %f %fi\n", creal  (cc),
> -          cimag  (cc));
> +  #define SUFFIX
> +  #define FTYPE double
> +  #define PRI "%f"
> +  #include "docomplex.h"
>   #endif
> diff --git a/testsuites/libtests/complex/docomplex.h b/testsuites/libtests/complex/docomplex.h
> new file mode 100644
> index 0000000..0f0b21a
> --- /dev/null
> +++ b/testsuites/libtests/complex/docomplex.h
> @@ -0,0 +1,118 @@
> + * Copyright (c) 2010, 2011 by
> + * Ralf Corsepius, Ulm/Germany. All rights reserved.
> + * Permission to use, copy, modify, and distribute this software
> + * is freely granted, provided that this notice is preserved.
> +#include<complex.h>
> +#include<stdio.h>
> +#define CONCAT(x, y) x ## y
> +#define XCONCAT(x, y) CONCAT(x, y)
> +#define STRINGIFY(x, y) # x # y
> +#define XSTRINGIFY(x, y) STRINGIFY(x, y)
> +#define FUNC(name) XCONCAT(name, SUFFIX)
> +#define STR(name) XSTRINGIFY(name, SUFFIX)
> +extern void FUNC(docomplex) (void);
> +void
> +FUNC(docomplex) (void)
> +  complex FTYPE ca, cb, cc;
> +  FTYPE f1;
> +  ca = 1.0 + 1.0 * I;
> +  cb = 1.0 - 1.0 * I;
> +  f1 = FUNC(cabs) (ca);
> +  fprintf (stdout, STR(cabs) "  : " PRI "\n", f1);
> +  cc = FUNC(cacos) (ca);
> +  fprintf (stdout, STR(cacos) " : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +          FUNC(cimag) (cc));
> +  cc = FUNC(cacosh) (ca);
> +  fprintf (stdout, STR(cacosh) ": " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  f1 = FUNC(carg) (ca);
> +  fprintf (stdout, STR(carg) "  : " PRI "\n", f1);
> +  cc = FUNC(casin) (ca);
> +  fprintf (stdout, STR(casin) " : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(casinh) (ca);
> +  fprintf (stdout, STR(casinh) ": " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(catan) (ca);
> +  fprintf (stdout, STR(catan) " : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(catanh) (ca);
> +  fprintf (stdout, STR(catanh) ": " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(ccos) (ca);
> +  fprintf (stdout, STR(ccos) "  : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(ccosh) (ca);
> +  fprintf (stdout, STR(ccosh) " : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(cexp) (ca);
> +  fprintf (stdout, STR(cexp) "  : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  f1 = FUNC(cimag) (ca);
> +  fprintf (stdout, STR(cimag) " : " PRI "\n", f1);
> +  cc = FUNC(clog) (ca);
> +  fprintf (stdout, STR(clog) "  : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(conj) (ca);
> +  fprintf (stdout, STR(conj) "  : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(cpow) (ca, cb);
> +  fprintf (stdout, STR(cpow) "  : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(cproj) (ca);
> +  fprintf (stdout, STR(cproj) " : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  f1 = FUNC(creal) (ca);
> +  fprintf (stdout, STR(creal) " : " PRI "\n", f1);
> +  cc = FUNC(csin) (ca);
> +  fprintf (stdout, STR(csin) "  : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(csinh) (ca);
> +  fprintf (stdout, STR(csinh) " : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(csqrt) (ca);
> +  fprintf (stdout, STR(csqrt) " : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(ctan) (ca);
> +  fprintf (stdout, STR(ctan) "  : " PRI " " PRI "i\n", FUNC(creal) (cc),
> +  cc = FUNC(ctanh) (ca);
> +  fprintf (stdout, STR(ctanh) " : " PRI " " PRI "i\n", FUNC(creal) (cc),
> diff --git a/testsuites/libtests/complex/docomplex.in b/testsuites/libtests/complex/docomplex.in
> deleted file mode 100644
> index e476f6d..0000000
> --- a/testsuites/libtests/complex/docomplex.in
> +++ /dev/null
> @@ -1,116 +0,0 @@
> - * Copyright (c) 2010, 2011 by
> - * Ralf Corsepius, Ulm/Germany. All rights reserved.
> - * Permission to use, copy, modify, and distribute this software
> - * is freely granted, provided that this notice is preserved.
> - * Try to compile and link against POSIX complex math routines.
> -#ifdef HAVE_CONFIG_H
> -#endif
> -#include<stdio.h>
> -extern void docomplex at FSUFFIX@ (void);
> -void
> -docomplex at FSUFFIX@ (void)
> -#ifndef @FGUARD@
> -  complex @FTYPE@ ca, cb, cc;
> -  @FTYPE@ f1;
> -  f1 = cabs at FSUFFIX@ (ca);
> -  fprintf (stdout, "cabs at FSUFFIX@  : %f\n", f1);
> -  cc = cacos at FSUFFIX@ (ca);
> -  fprintf (stdout, "cacos at FSUFFIX@ : %f %fi\n", creal at FSUFFIX@ (cc),
> -          cimag at FSUFFIX@ (cc));
> -  cc = cacosh at FSUFFIX@ (ca);
> -  fprintf (stdout, "cacosh at FSUFFIX@: %f %fi\n", creal at FSUFFIX@ (cc),
> -  f1 = carg at FSUFFIX@ (ca);
> -  fprintf (stdout, "carg at FSUFFIX@  : %f\n", f1);
> -  cc = casin at FSUFFIX@ (ca);
> -  fprintf (stdout, "casin at FSUFFIX@ : %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = casinh at FSUFFIX@ (ca);
> -  fprintf (stdout, "casinh at FSUFFIX@: %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = catan at FSUFFIX@ (ca);
> -  fprintf (stdout, "catan at FSUFFIX@ : %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = catanh at FSUFFIX@ (ca);
> -  fprintf (stdout, "catanh at FSUFFIX@: %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = ccos at FSUFFIX@ (ca);
> -  fprintf (stdout, "ccos at FSUFFIX@  : %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = ccosh at FSUFFIX@ (ca);
> -  fprintf (stdout, "ccosh at FSUFFIX@ : %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = cexp at FSUFFIX@ (ca);
> -  fprintf (stdout, "cexp at FSUFFIX@  : %f %fi\n", creal at FSUFFIX@ (cc),
> -  f1 = cimag at FSUFFIX@ (ca);
> -  fprintf (stdout, "cimag at FSUFFIX@ : %f\n", f1);
> -  cc = clog at FSUFFIX@ (ca);
> -  fprintf (stdout, "clog at FSUFFIX@  : %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = conj at FSUFFIX@ (ca);
> -  fprintf (stdout, "conj at FSUFFIX@  : %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = cpow at FSUFFIX@ (ca, cb);
> -  fprintf (stdout, "cpow at FSUFFIX@  : %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = cproj at FSUFFIX@ (ca);
> -  fprintf (stdout, "cproj at FSUFFIX@ : %f %fi\n", creal at FSUFFIX@ (cc),
> -  f1 = creal at FSUFFIX@ (ca);
> -  fprintf (stdout, "creal at FSUFFIX@ : %f\n", f1);
> -  cc = csin at FSUFFIX@ (ca);
> -  fprintf (stdout, "csin at FSUFFIX@  : %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = csinh at FSUFFIX@ (ca);
> -  fprintf (stdout, "csinh at FSUFFIX@ : %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = csqrt at FSUFFIX@ (ca);
> -  fprintf (stdout, "csqrt at FSUFFIX@ : %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = ctan at FSUFFIX@ (ca);
> -  fprintf (stdout, "ctan at FSUFFIX@  : %f %fi\n", creal at FSUFFIX@ (cc),
> -  cc = ctanh at FSUFFIX@ (ca);
> -  fprintf (stdout, "ctanh at FSUFFIX@ : %f %fi\n", creal at FSUFFIX@ (cc),
> -#endif
> diff --git a/testsuites/libtests/complex/docomplexf.c b/testsuites/libtests/complex/docomplexf.c
> index ff2e73d..bc1ffb3 100644
> --- a/testsuites/libtests/complex/docomplexf.c
> +++ b/testsuites/libtests/complex/docomplexf.c
>   #endif
> -#include<stdio.h>
> -extern void docomplexf (void);
> -void
> -docomplexf (void)
>   #ifndef NO_FLOAT
> -  complex float ca, cb, cc;
> -  float f1;
> -  f1 = cabsf (ca);
> -  fprintf (stdout, "cabsf  : %f\n", f1);
> -  cc = cacosf (ca);
> -  fprintf (stdout, "cacosf : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = cacoshf (ca);
> -  fprintf (stdout, "cacoshf: %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  f1 = cargf (ca);
> -  fprintf (stdout, "cargf  : %f\n", f1);
> -  cc = casinf (ca);
> -  fprintf (stdout, "casinf : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = casinhf (ca);
> -  fprintf (stdout, "casinhf: %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = catanf (ca);
> -  fprintf (stdout, "catanf : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = catanhf (ca);
> -  fprintf (stdout, "catanhf: %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = ccosf (ca);
> -  fprintf (stdout, "ccosf  : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = ccoshf (ca);
> -  fprintf (stdout, "ccoshf : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = cexpf (ca);
> -  fprintf (stdout, "cexpf  : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  f1 = cimagf (ca);
> -  fprintf (stdout, "cimagf : %f\n", f1);
> -  cc = clogf (ca);
> -  fprintf (stdout, "clogf  : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = conjf (ca);
> -  fprintf (stdout, "conjf  : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = cpowf (ca, cb);
> -  fprintf (stdout, "cpowf  : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = cprojf (ca);
> -  fprintf (stdout, "cprojf : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  f1 = crealf (ca);
> -  fprintf (stdout, "crealf : %f\n", f1);
> -  cc = csinf (ca);
> -  fprintf (stdout, "csinf  : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = csinhf (ca);
> -  fprintf (stdout, "csinhf : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = csqrtf (ca);
> -  fprintf (stdout, "csqrtf : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = ctanf (ca);
> -  fprintf (stdout, "ctanf  : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> -  cc = ctanhf (ca);
> -  fprintf (stdout, "ctanhf : %f %fi\n", crealf (cc),
> -          cimagf (cc));
> +  #define SUFFIX f
> +  #define FTYPE float
> +  #define PRI "%f"
>   #endif
> diff --git a/testsuites/libtests/complex/docomplexl.c b/testsuites/libtests/complex/docomplexl.c
> index f63d00a..a4ed1be 100644
> --- a/testsuites/libtests/complex/docomplexl.c
> +++ b/testsuites/libtests/complex/docomplexl.c
>   #endif
> -#include<stdio.h>
> -extern void docomplexl (void);
> -void
> -docomplexl (void)
>   #ifndef NO_LONG_DOUBLE
> -  complex long double ca, cb, cc;
> -  long double f1;
> -  f1 = cabsl (ca);
> -  fprintf (stdout, "cabsl  : %Lf\n", f1);
> -  cc = cacosl (ca);
> -  fprintf (stdout, "cacosl : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = cacoshl (ca);
> -  fprintf (stdout, "cacoshl: %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  f1 = cargl (ca);
> -  fprintf (stdout, "cargl  : %Lf\n", f1);
> -  cc = casinl (ca);
> -  fprintf (stdout, "casinl : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = casinhl (ca);
> -  fprintf (stdout, "casinhl: %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = catanl (ca);
> -  fprintf (stdout, "catanl : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = catanhl (ca);
> -  fprintf (stdout, "catanhl: %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = ccosl (ca);
> -  fprintf (stdout, "ccosl  : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = ccoshl (ca);
> -  fprintf (stdout, "ccoshl : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = cexpl (ca);
> -  fprintf (stdout, "cexpl  : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  f1 = cimagl (ca);
> -  fprintf (stdout, "cimagl : %Lf\n", f1);
> -  cc = clogl (ca);
> -  fprintf (stdout, "clogl  : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = conjl (ca);
> -  fprintf (stdout, "conjl  : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = cpowl (ca, cb);
> -  fprintf (stdout, "cpowl  : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = cprojl (ca);
> -  fprintf (stdout, "cprojl : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  f1 = creall (ca);
> -  fprintf (stdout, "creall : %Lf\n", f1);
> -  cc = csinl (ca);
> -  fprintf (stdout, "csinl  : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = csinhl (ca);
> -  fprintf (stdout, "csinhl : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = csqrtl (ca);
> -  fprintf (stdout, "csqrtl : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = ctanl (ca);
> -  fprintf (stdout, "ctanl  : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> -  cc = ctanhl (ca);
> -  fprintf (stdout, "ctanhl : %Lf %Lfi\n", creall (cc),
> -          cimagl (cc));
> +  #define SUFFIX l
> +  #define FTYPE long double
> +  #define PRI "%Lf"
>   #endif
> 1.6.4.2
> rtems-devel mailing list
> rtems-devel at rtems.org
Joel Sherrill, Ph.D.             Director of Research&   Development
