[PATCH] libtests/complex: Avoid generated files
Mon May 21 14:53:46 UTC 2012
On 05/21/2012 09:49 AM, Sebastian Huber wrote:
> On 05/21/2012 04:48 PM, Joel Sherrill wrote:
>> Just to make sure I am interpreting this right, you just
>> modified the code to use macros and do the same
>> thing at compile time.
> Yes, this is my intention.
That will likely work on all the C cases.
Ada does not have a preprocessor.
I am betting you won't build that part of the tree so
that won't impact your particular situation. :)
Joel Sherrill, Ph.D.             Director of Research&   Development
