[PATCH] libtests/complex: Avoid generated files
Mon May 21 15:07:31 UTC 2012
On 05/21/2012 04:53 PM, Joel Sherrill wrote:
> On 05/21/2012 09:49 AM, Sebastian Huber wrote:
>> On 05/21/2012 04:48 PM, Joel Sherrill wrote:
>>> Just to make sure I am interpreting this right, you just
>>> modified the code to use macros and do the same
>>> thing at compile time.
>> Yes, this is my intention.
> That will likely work on all the C cases.
> Ada does not have a preprocessor.
> I am betting you won't build that part of the tree so
> that won't impact your particular situation. :)
Which generated Ada file do you have in mind?  I find nothing in
c/src/ada-tests/sptests/sp19
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
