powerpc | psim gdb error
Mon May 28 00:58:37 UTC 2012
Long holiday weekend here so forgive the lack of focus.
If you built your own gdb, it needs whatever rtems patches are available. For psim support, there are a handful of --enable-sim options which need to be provided.  Grep for enable-sim in the rtems-testing/gcc directory.
psim script with no options runs the test in a batch mode for automated testing. The output will be in a log directory where you ran it. Use a -i option for interactive.
--joel
Hesham Moustafa <heshamelmatary at gmail.com> wrote:
>That's what i got when using psim, but i wanna use psim-gdb
>hesham at Hesham-Laptop sim-scripts$ ./psim ~/powerpc/powerpc-rtems4.11/c/psim/testsuites/samples/hello/hello.exe
>powerpc-rtems4.11-run is /opt/rtems-4.11/bin/powerpc-rtems4.11-run
>running /home/hesham/powerpc/powerpc-rtems4.11/c/psim/testsuites/samples/hello/hello.exe for maximum 60 seconds... 200 ms run time
