[PATCH 2/2] score/rbtree: replace _RBTree_Peek_unprotected with _RBTree_First.
Gedare Bloom
gedare at rtems.org
Wed May 2 15:32:23 UTC 2012
I noticed that RBTree_First and RBTree_Peek_unprotected implement the
same thing. I prefer to simplify to one of them and RBTree_First
seemed to be more commonly used and is "unprotected" by default.
Right now I'm leaving RBTree_Peek in place as the protected interface.
The user API remains unchanged since it lacked an unprotected version
previously. I will follow-up with a user API wrapper for RBTree_First.
I'm not really satisfied with the mixture of default protected vs
unprotected but the behavior generally follows the chains where a
function tends to be protected by default if it modifies or iterates a
chain and unprotected if it only deals with a single node. It might be
nice to formalize the reasoning and make sure the approach is
consistent between the two data structures.
-Gedare
On Wed, May 2, 2012 at 11:26 AM, Gedare Bloom <gedare at rtems.org> wrote:
> cpukit/score/inline/rtems/score/rbtree.inl | 20 +-------------------
> cpukit/score/src/rbtreepeek.c | 6 ++----
> 2 files changed, 3 insertions(+), 23 deletions(-)
> diff --git a/cpukit/score/inline/rtems/score/rbtree.inl b/cpukit/score/inline/rtems/score/rbtree.inl
> index d646b06..a079745 100644
> --- a/cpukit/score/inline/rtems/score/rbtree.inl
> +++ b/cpukit/score/inline/rtems/score/rbtree.inl
> @@ -10,13 +10,11 @@
> - * Copyright (c) 2010 Gedare Bloom.
> + * Copyright (c) 2010-2012 Gedare Bloom.
> * The license and distribution terms for this file may be
> * found in the file LICENSE in this distribution or at
> * http://www.rtems.com/license/LICENSE.
> - * $Id$
> #ifndef _RTEMS_SCORE_RBTREE_H
> @@ -459,22 +457,6 @@ RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Get_unprotected(
> return the_node;
> -/** @brief Peek at the First Node (unprotected)
> - * This function returns a pointer to the first node, minimum if @a dir is 0
> - * or maximum if @a dir is 1, from @a the_rbtree without extracting it.
> - * It does NOT disable interrupts to ensure the atomicity of the peek.
> - * @retval NULL if @a the_rbtree is empty.
> -RTEMS_INLINE_ROUTINE RBTree_Node *_RBTree_Peek_unprotected(
> - const RBTree_Control *the_rbtree,
> - RBTree_Direction dir
> - return(the_rbtree->first[dir]);
> /** @brief Rotate the_node in the direction passed as second argument
> * This routine rotates @a the_node to the direction @a dir, swapping
> diff --git a/cpukit/score/src/rbtreepeek.c b/cpukit/score/src/rbtreepeek.c
> index 13ea333..81ff0fd 100644
> --- a/cpukit/score/src/rbtreepeek.c
> +++ b/cpukit/score/src/rbtreepeek.c
> @@ -1,11 +1,9 @@
> - * $Id$
> #if HAVE_CONFIG_H
> @@ -45,7 +43,7 @@ RBTree_Node *_RBTree_Peek(
> return_node = NULL;
> _ISR_Disable( level );
> - return_node = _RBTree_Peek_unprotected( the_rbtree, dir );
> + return_node = _RBTree_First( the_rbtree, dir );
> _ISR_Enable( level );
> return return_node;
> 1.7.1
