[PATCH 3/4] rbtree: API Changes
Wed May 2 17:14:09 UTC 2012
On 05/02/2012 12:08 PM, Gedare Bloom wrote:
> On Wed, May 2, 2012 at 1:02 PM, Joel Sherrill<joel.sherrill at oarcorp.com>  wrote:
>> Copyright should be a plain comment not a Doxygen one.
> OK
Just don't want it in generated docs all over the place.
>> In _RBTree_Initialize at bottom of patch "next =" appears
>> to be formatted strangely.
> I'd prefer to deal with style issues separately. This formatting was
> copied from Chain_Initialize and probably occurs there.
Yep. and that code is old.  It isn't particularly ugly but I
wouldn't use initialized variables that way today.  I would
also probably declare a void * pointer to assign the
result of _Addresses_Add_offset and put the cast on a line
by itself.
Leave it for a second round but I definitely think when you
do enough to break onto two lines during variable
initialization, it is impacting readability.
>> On 05/02/2012 11:35 AM, Gedare Bloom wrote:
>>> Make default for rtems_rbtree functions be unprotected (preemption
>>> enabled)
>>> unless an unprotected variant e.g. rtems_rbtree_xxx_unprotected is
>>> available.
>>>   cpukit/sapi/inline/rtems/rbtree.inl |   87
>>>   cpukit/score/src/rbtree.c           |    2 +-
>>>   2 files changed, 77 insertions(+), 12 deletions(-)
>>> diff --git a/cpukit/sapi/inline/rtems/rbtree.inl
>>> b/cpukit/sapi/inline/rtems/rbtree.inl
>>> index ab81baf..0d507fb 100644
>>> --- a/cpukit/sapi/inline/rtems/rbtree.inl
>>> +++ b/cpukit/sapi/inline/rtems/rbtree.inl
>>> @@ -5,17 +5,14 @@
>>>    *  with the RBTree API in RTEMS. The rbtree is a Red Black Tree that
>>>    *  is part of the Super Core. This is the published interface to that
>>>    *  code.
>>> - *  Copyright (c) 2010 Gedare Bloom.
>>> + *  Copyright (c) 2010-2012 Gedare Bloom.
>>>    *  The license and distribution terms for this file may be
>>>    *  found in the file LICENSE in this distribution or at
>>>    *  http://www.rtems.com/license/LICENSE.
>>> - *  $Id$
>>>   #ifndef _RTEMS_RBTREE_H
>>> @@ -254,6 +251,17 @@ RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_root(
>>>     return _RBTree_Is_root( the_rbtree, the_node );
>>> + * @copydoc _RBTree_Find_unprotected()
>>> +RTEMS_INLINE_ROUTINE rtems_rbtree_node* rtems_rbtree_find_unprotected(
>>> +    rtems_rbtree_control *the_rbtree,
>>> +    rtems_rbtree_node *the_node
>>> +  return _RBTree_Find_unprotected( the_rbtree, the_node );
>>>   /** @brief Find the node with given key in the tree
>>>    *  This function returns a pointer to the node having key equal to the
>>> key
>>> @@ -316,6 +324,17 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node*
>>> rtems_rbtree_successor(
>>> + * @copydoc _RBTree_Extract_unprotected()
>>> +RTEMS_INLINE_ROUTINE void rtems_rbtree_extract_unprotected(
>>> +  _RBTree_Extract_unprotected( the_rbtree, the_node );
>>>    *  @brief Extract the specified node from a rbtree
>>>    *  This routine extracts @a the_node from @a the_rbtree on which it
>>> resides.
>>> @@ -334,6 +353,20 @@ RTEMS_INLINE_ROUTINE void rtems_rbtree_extract(
>>>    *  This function removes the min node from @a the_rbtree and returns
>>>    *  a pointer to that node.  If @a the_rbtree is empty, then NULL is
>>> returned.
>>> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min_unprotected(
>>> +  return _RBTree_Get_unprotected( the_rbtree, RBT_LEFT );
>>> + *  @brief Obtain the min node on a rbtree
>>> + *  This function removes the min node from @a the_rbtree and returns
>>> + *  a pointer to that node.  If @a the_rbtree is empty, then NULL is
>>> returned.
>>>    *  It disables interrupts to ensure the atomicity of the get operation.
>>>   RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_min(
>>> @@ -348,6 +381,20 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node
>>>    *  This function removes the max node from @a the_rbtree and returns
>>> returned.
>>> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max_unprotected(
>>> +  return _RBTree_Get_unprotected( the_rbtree, RBT_RIGHT );
>>> + *  @brief Obtain the max node on a rbtree
>>> + *  This function removes the max node from @a the_rbtree and returns
>>> returned.
>>>   RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_get_max(
>>> @@ -363,13 +410,12 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node
>>>    *  This function returns a pointer to the min node from @a the_rbtree
>>>    *  without changing the tree.  If @a the_rbtree is empty,
>>>    *  then NULL is returned.
>>> - *  It disables interrupts to ensure the atomicity of the peek operation.
>>>   RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_peek_min(
>>>     const rtems_rbtree_control *the_rbtree
>>> -  return _RBTree_Peek( the_rbtree, RBT_LEFT );
>>> +  return _RBTree_First( the_rbtree, RBT_LEFT );
>>> @@ -378,15 +424,23 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_node
>>>    *  This function returns a pointer to the max node from @a the_rbtree
>>>   RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_peek_max(
>>> -  return _RBTree_Peek( the_rbtree, RBT_RIGHT );
>>> +  return _RBTree_First( the_rbtree, RBT_RIGHT );
>>> + * @copydoc _RBTree_Find_header_unprotected()
>>> +RTEMS_INLINE_ROUTINE rtems_rbtree_control
>>> *rtems_rbtree_find_header_unprotected(
>>> +  return _RBTree_Find_header_unprotected( the_node );
>>>    *  @brief Find the control header of the tree containing a given node.
>>> @@ -399,7 +453,18 @@ RTEMS_INLINE_ROUTINE rtems_rbtree_control
>>> *rtems_rbtree_find_header(
>>> -  return(_RBTree_Find_header( the_node ));
>>> +  return _RBTree_Find_header( the_node );
>>> + * @copydoc _RBTree_Insert_unprotected()
>>> +RTEMS_INLINE_ROUTINE rtems_rbtree_node *rtems_rbtree_insert_unprotected(
>>> +  return _RBTree_Insert_unprotected( the_rbtree, the_node );
>>> @@ -427,7 +492,7 @@ RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_unique(
>>> -  return( _RBTree_Is_unique(the_rbtree) );
>>> +  return _RBTree_Is_unique(the_rbtree);
>>>   #endif
>>> diff --git a/cpukit/score/src/rbtree.c b/cpukit/score/src/rbtree.c
>>> index e0fc560..387e66b 100644
>>> --- a/cpukit/score/src/rbtree.c
>>> +++ b/cpukit/score/src/rbtree.c
>>> @@ -52,7 +52,7 @@ void _RBTree_Initialize(
>>>     count = number_nodes;
>>>     next  = starting_address;
>>>     while ( count-- ) {
>>> -    _RBTree_Insert(the_rbtree, next);
>>> +    _RBTree_Insert_unprotected(the_rbtree, next);
>>>       next           = (RBTree_Node *)
>>>                           _Addresses_Add_offset( (void *) next, node_size
>> Joel Sherrill, Ph.D.             Director of Research&     Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>     Support Available             (256) 722-9985
