[PATCH] testsuites - remove all $Id$ strings
Joel Sherrill
joel.sherrill at OARcorp.com
Thu May 3 17:17:57 UTC 2012
On 05/03/2012 10:46 AM, Gedare Bloom wrote:
> Do you have a branch / link to the patch or was it supposed to
> accompany your email?
I sent that message using "git send-email" but it
didn't include the patch. I don't know why.
I replied to myself immediately and that one got
blocked as too large of an attachment. Compressed
and attached.
Remember I am doing this with a script. If a file
doesn't match the patterns, I am either changing
the patterns or fixing the file. Fixing the file is
a only for cases where something is clearly
misformatted or incorrect.
--joel
> On Thu, May 3, 2012 at 11:19 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> This is a patch to remove all CVS Id strings from the testsuites.
>> It is completely done by a shell script with much help from sed.
>> I tried to take into acount a number of odd cases:
>> + Removed enough to avoid two blank comment lines
>> + Removed file headers with only Id string
>> - In some cases, I fixed files to have copyright or
>> properly formatted headers before running script.
>> + Removed blank first line at top of file if sed left it.
>> I tested most of the patterns on individual files.
>> I perused the diff but it is large. Since this is a
>> big patch and mechanical, I would appreciate a review.
>> Thanks.
>> --joel
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
Joel Sherrill, Ph.D. Director of Research& Development
Type: application/x-bzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120503/dfa891c3/attachment-0001.bin>
