[PATCH] testsuites - remove all $Id$ strings
Thu May 3 15:22:45 UTC 2012
git send-email didn't quite work. It left the patch out.
By nibble I meant remove all within an area. This
does it in testsuites.
On 05/03/2012 10:19 AM, Joel Sherrill wrote:
> This is a patch to remove all CVS Id strings from the testsuites.
> It is completely done by a shell script with much help from sed.
> I tried to take into acount a number of odd cases:
> + Removed enough to avoid two blank comment lines
> + Removed file headers with only Id string
>    - In some cases, I fixed files to have copyright or
>      properly formatted headers before running script.
> + Removed blank first line at top of file if sed left it.
> I tested most of the patterns on individual files.
> I perused the diff but it is large.  Since this is a
> big patch and mechanical, I would appreciate a review.
> Thanks.
> --joel
> rtems-devel mailing list
> rtems-devel at rtems.org
Joel Sherrill, Ph.D.             Director of Research&   Development
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120503/18e13779/attachment-0001.ksh>
