the hash approach of POSIX key
Ashi ashi08104 at gmail.com
Mon May 21 14:27:18 UTC 2012
On May 21, 2012 10:16 PM, "Ashi" <ashi08104 at gmail.com> wrote:
> 2012/5/21 Gedare Bloom <gedare at rtems.org>
>> On Mon, May 21, 2012 at 9:30 AM, Ashi <ashi08104 at gmail.com> wrote:
>> > Hi, all.
>> > I'm working on the POSIX key project(here is a introduction of it:[1]).
>> > Since using hash is a good candidate of the solution, I'm trying to do
>> the
>> Hashing is a good candidate solution for what problem? It is not clear
>> to me what the hash solves, that is why to use a hash at all?
> Sorry for the obscure description. Here, we use hash table to dynamicly
> manage POSIX key, then the key can be added and deleted flexibly without
> losing the speed of key query, add, delete operation. While key and it's
> data field is fixed in current implementation, more description of the
> problem of current POSIX implementation is in [1]. This hash approach is an
> alternative to another approach(the rbtree approach), I have decide which
> is better.(Probably, both should be implemented).
I haven't decide which is better.(Probably, both should be implemented).
Sorry, I replied from cellphone, and made a typo.
>  > design using hash. I'm not clear about how to deal with UThash[2] in
>> RTEMS.
>> > Shall we directly include this lib or reimplemented in RTEMS? If assumed
>> > directly use, I think we can manage all keys in one hash table as like
>> in
>> > the rbtree approach. Since UThash is able to use structure as it's hash
>> key,
>> > then the POSIX_Keys_Control can be defined as:
>> > typedef struct {
>> >     Objects_Control Object;
>> >     void (*destructor) (void *);
>> >     hash_key_t hash_key; /* use struct hash_key_t as a hash key */
>> >     void *value;
>> >     UT_hash_handle hh;
>> > } POSIX_Keys_Control;
>> > the hash_key_t type is a structure include Object id and pthread_key_t:
>> > typedef struct {
>> >     Objects_Id thread_id;
>> >     pthread_key_t key;
>> > } hash_key_t;
>> > Then all the keys' data is managed in one hash table. I've a question
>> about
>> > this design: is it a waste of memory that every key data holds a
>> > POSIX_Keys_Control structure? If it is, I think we could manage it in a
>> two
>> > level structure: first level manages all keys by one hash table, and
>> each
>> > key manages its values in second level by one bash table:
>> > typedef struct {
>> >     Objects_Id Object.id;    /* use Object.id as hash key, I don't know
>> > whether we could directly use Object as a hash key? I know it's no
>> problem
>> > in UThash  */
>> >     key_node_t * key_node;
>> >     UT_hash_handle hh;
>> > typedef struct {
>> >    Objects_Id thread_id; /* use thread_id as hash key */
>> >    void *value;
>> >    UT_hash_handle hh;
>> > } key_node_t;
>> > And as Gedare suggested in my last discuss, the implementation should
>> > consider do actually work in in the supercore layer and shared between
>> Posix
>> > Keys and Classic Task vars, however, I haven't think about it yet, I'm a
>> > little behind my work.
>> > links:
>>   [1]: http://www.rtems.com/ml/rtems-users/2012/april/msg00110.html
>> > [2]:http://uthash.sourceforge.net/
>> > Best wishes!
>> > zw_yao
> Best wishes!
> zw_yao
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120521/bac34340/attachment-0001.html>
