[PATCH] score: PR1607: Add and use CPU_SIZEOF_POINTER
Mon Nov 5 01:41:32 UTC 2012
Joel Sherrill wrote:
> I believe this is a predefine for all configurations of gcc. There is no point duplicating this logical in RTEMS.
For RTEMS or even recent cross-compiled gccs this may be true but it is
not always the case. The MacOS and FreeBSD gcc's do not. I see clang
supports __SIZEOF_POINTER__ as well as __POINTER_WIDTH__ which is nice.
A 4.6.3 arm-eabi-gcc (non-RTEMS) has it.
I am fine with rejecting a compiler that does not provide
__SIZEOF_POINTER__ and using it.
