[rtems commit] bsps: Use allocator mutex for generic IRQ support
Joel Sherrill
Joel.Sherrill at OARcorp.com
Tue Nov 6 09:40:10 UTC 2012
It violates convention to directly include a score file like this. If you want to use the allocator mutex, it needs a simple wrapper API that gives it public visibility.
Also it would be nice to generalize the sparc code which implements this interrupt model on top of the simple vectored API. That is needed for the new TCP/IP stack and USB. Not critical for this but needed.:-)
--joel
-------- Original Message --------
Subject: [rtems commit] bsps: Use allocator mutex for generic IRQ support
To: rtems-vc at rtems.org
CC:
Module: rtems
Branch: master
Commit: a9e5e747f08f7f157ec20f3a08c159ec85f7f394
Changeset: http://git.rtems.org/rtems/commit/?id=a9e5e747f08f7f157ec20f3a08c159ec85f7f394
Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
Date: Tue Nov 6 10:15:17 2012 +0100
Since the allocator mutex allows nesting now we can use it for the
generic IRQ support (recursive obtain in a potential malloc()). This
simplifies the code and reduces memory usage.
c/src/lib/libbsp/shared/src/irq-generic.c | 105 +++++------------------------
1 files changed, 16 insertions(+), 89 deletions(-)
diff --git a/c/src/lib/libbsp/shared/src/irq-generic.c b/c/src/lib/libbsp/shared/src/irq-generic.c
index 4f18e34..d0d5932 100644
--- a/c/src/lib/libbsp/shared/src/irq-generic.c
+++ b/c/src/lib/libbsp/shared/src/irq-generic.c
@@ -21,9 +21,11 @@
* http://www.rtems.com/license/LICENSE.
+#include <bsp/irq-generic.h>
-#include <bsp/irq-generic.h>
+#include <rtems/score/apimutex.h>
#ifdef BSP_INTERRUPT_USE_INDEX_TABLE
bsp_interrupt_handler_index_type bsp_interrupt_handler_index_table
@@ -37,8 +39,6 @@ bsp_interrupt_handler_entry bsp_interrupt_handler_table
static uint8_t bsp_interrupt_handler_unique_table
[(BSP_INTERRUPT_HANDLER_TABLE_SIZE + 7 + 1) / 8];
-static rtems_id bsp_interrupt_mutex = RTEMS_ID_NONE;
static void bsp_interrupt_handler_empty(void *arg)
rtems_vector_number vector = (rtems_vector_number) arg;
@@ -141,59 +141,17 @@ static void bsp_interrupt_free_handler_entry(bsp_interrupt_handler_entry *e)
#endif
-static rtems_status_code bsp_interrupt_lock(void)
+static void bsp_interrupt_lock(void)
- rtems_status_code sc = RTEMS_SUCCESSFUL;
if (_System_state_Is_up(_System_state_Get())) {
- if (bsp_interrupt_mutex == RTEMS_ID_NONE) {
- rtems_id mutex = RTEMS_ID_NONE;
- rtems_interrupt_level level;
- /* Create a mutex */
- sc = rtems_semaphore_create (
- rtems_build_name('I', 'N', 'T', 'R'),
- 1,
- RTEMS_BINARY_SEMAPHORE | RTEMS_INHERIT_PRIORITY | RTEMS_PRIORITY,
- 0,
- &mutex
- if (sc != RTEMS_SUCCESSFUL) {
- return sc;
- /* Assign the mutex */
- rtems_interrupt_disable(level);
- /* Nobody else assigned the mutex in the meantime */
- bsp_interrupt_mutex = mutex;
- rtems_interrupt_enable(level);
- } else {
- /* Somebody else won */
- sc = rtems_semaphore_delete(mutex);
- return sc;
- return rtems_semaphore_obtain(
- bsp_interrupt_mutex,
- RTEMS_WAIT,
- RTEMS_NO_TIMEOUT
- } else {
- return RTEMS_SUCCESSFUL;
+ _RTEMS_Lock_allocator();
-static rtems_status_code bsp_interrupt_unlock(void)
+static void bsp_interrupt_unlock(void)
- if (bsp_interrupt_mutex != RTEMS_ID_NONE) {
- return rtems_semaphore_release(bsp_interrupt_mutex);
- } else {
+ if (_System_state_Is_up(_System_state_Get())) {
+ _RTEMS_Unlock_allocator();
@@ -202,16 +160,7 @@ rtems_status_code bsp_interrupt_initialize(void)
size_t i = 0;
- sc = bsp_interrupt_lock();
- return sc;
- /* We need one semaphore */
- if (_System_state_Is_before_initialization(_System_state_Get())) {
- Configuration.work_space_size += sizeof(Semaphore_Control);
- ++Configuration_RTEMS_API.maximum_semaphores;
+ bsp_interrupt_lock();
if (bsp_interrupt_is_initialized()) {
bsp_interrupt_unlock();
@@ -232,10 +181,7 @@ rtems_status_code bsp_interrupt_initialize(void)
bsp_interrupt_set_initialized();
- sc = bsp_interrupt_unlock();
- return sc;
+ bsp_interrupt_unlock();
@@ -282,10 +228,7 @@ static rtems_status_code bsp_interrupt_handler_install(
/* Lock */
- return sc;
/* Get handler table index */
index = bsp_interrupt_handler_index(vector);
@@ -382,10 +325,7 @@ static rtems_status_code bsp_interrupt_handler_install(
/* Unlock */
- return sc;
@@ -426,10 +366,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
/* Lock */
- return sc;
@@ -508,10 +445,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
/* Unlock */
- return sc;
@@ -532,7 +466,6 @@ static rtems_status_code bsp_interrupt_handler_iterate(
void *arg
bsp_interrupt_handler_entry *current = NULL;
rtems_option options = 0;
rtems_vector_number index = 0;
@@ -547,10 +480,7 @@ static rtems_status_code bsp_interrupt_handler_iterate(
/* Lock */
- return sc;
/* Interate */
@@ -565,10 +495,7 @@ static rtems_status_code bsp_interrupt_handler_iterate(
/* Unlock */
- return sc;
rtems-vc mailing list
http://www.rtems.org/mailman/listinfo/rtems-vc
