[PATCH 07/23] sapi: Use rtems_config*_get_maximum_extensions
Tue Nov 6 12:56:29 UTC 2012
 cpukit/sapi/src/extension.c |    2 +-
 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpukit/sapi/src/extension.c b/cpukit/sapi/src/extension.c
index 80a19fa..9038b29 100644
--- a/cpukit/sapi/src/extension.c
+++ b/cpukit/sapi/src/extension.c
@@ -36,7 +36,7 @@ void _Extension_Manager_initialization(void)
     &_Extension_Information,
     OBJECTS_CLASSIC_API,                 /* object API */
     OBJECTS_RTEMS_EXTENSIONS,
-    Configuration.maximum_extensions,
+    rtems_configuration_get_maximum_extensions(),
     sizeof( Extension_Control ),
     false,                     /* true if the name is a string */
     RTEMS_MAXIMUM_NAME_LENGTH  /* maximum length of an object name */
1.7.7
