[PATCH 01/23] sapi: Use rtems_config*_get_microseconds_per_tick
Joel Sherrill Joel.Sherrill at OARcorp.com
Tue Nov 6 13:58:43 UTC 2012
Thanks for the clean up patch. This type of stuff is based to remember.
This looks like a good check to add to check_submission in rtems-testing when it is in BSP mode. Configuration. should not be present.
Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
 c/src/lib/libbsp/m68k/idp/clock/ckinit.c     |    2 +-
 c/src/lib/libbsp/m68k/mcf52235/clock/clock.c |    4 ++--
 c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c |    4 ++--
 c/src/lib/libbsp/m68k/mcf5329/clock/clock.c  |    4 ++--
 c/src/lib/libcpu/arm/pxa255/clock/clock.c    |    8 ++++----
 cpukit/libmisc/capture/capture.c             |    2 +-
 6 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/idp/clock/ckinit.c b/c/src/lib/libbsp/m68k/idp/clock/ckinit.c
index efc4aa5..8391f8c 100644
--- a/c/src/lib/libbsp/m68k/idp/clock/ckinit.c
+++ b/c/src/lib/libbsp/m68k/idp/clock/ckinit.c
@@ -90,7 +90,7 @@ void Install_clock(
   rtems_isr_entry clock_isr )
   Clock_driver_ticks = 0;
-  Clock_isrs = (int)(Configuration.microseconds_per_tick / 1000);
+  Clock_isrs = (int)(rtems_configuration_get_microseconds_per_tick() / 1000);
 /*    led_putnum('c'); * for debugging purposes */
     Old_ticker = (rtems_isr_entry) set_vector( clock_isr, CLOCK_VECTOR, 1 );
diff --git a/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c b/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c
index fd79dfe..c22393d 100644
--- a/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c
+++ b/c/src/lib/libbsp/m68k/mcf52235/clock/clock.c
@@ -60,7 +60,7 @@ static void Clock_driver_support_shutdown_hardware(void)
  * Set up the clock hardware
- * We need to have 1 interrupt every BSP_Configuration.microseconds_per_tick
+ * We need to have 1 interrupt every rtems_configuration_get_microseconds_per_tick()
 static void Clock_driver_support_initialize_hardware(void)
@@ -68,7 +68,7 @@ static void Clock_driver_support_initialize_hardware(void)
   uint32_t pmr;
   uint32_t preScaleCode = 0;
   uint32_t clk = bsp_get_CPU_clock_speed() >> 1;
-  uint32_t tps = 1000000 / Configuration.microseconds_per_tick;
+  uint32_t tps = 1000000 / rtems_configuration_get_microseconds_per_tick();
   while (preScaleCode < 15) {
     pmr = (clk >> preScaleCode) / tps;
diff --git a/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c b/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c
index 4e18828..d058126 100644
--- a/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c
+++ b/c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c
@@ -52,7 +52,7 @@ static void Clock_driver_support_shutdown_hardware(void)
+ * We need to have 1 interrupt every BSP_rtems_configuration_get_microseconds_per_tick()
@@ -60,7 +60,7 @@ static void Clock_driver_support_initialize_hardware(void)
   uint32_t pmr;
diff --git a/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c b/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c
index a96e211..ed11320 100644
--- a/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c
+++ b/c/src/lib/libbsp/m68k/mcf5329/clock/clock.c
@@ -59,7 +59,7 @@ static void Clock_driver_support_shutdown_hardware(void)
@@ -67,7 +67,7 @@ static void Clock_driver_support_initialize_hardware(void)
   uint32_t pmr;
   uint32_t clk = bsp_get_BUS_clock_speed();
diff --git a/c/src/lib/libcpu/arm/pxa255/clock/clock.c b/c/src/lib/libcpu/arm/pxa255/clock/clock.c
index 0bb2b08..0736b14 100644
--- a/c/src/lib/libcpu/arm/pxa255/clock/clock.c
+++ b/c/src/lib/libcpu/arm/pxa255/clock/clock.c
@@ -50,9 +50,9 @@ static void clock_isr_on(const rtems_irq_connect_data *unused)
   XSCALE_OS_TIMER_IER |= 0x1;
 #if ON_SKYEYE==1
-  period_num = (TIMER_RATE* Configuration.microseconds_per_tick)/100000;
+  period_num = (TIMER_RATE* rtems_configuration_get_microseconds_per_tick())/100000;
 #else
-  period_num = (TIMER_RATE* Configuration.microseconds_per_tick)/10000;
+  period_num = (TIMER_RATE* rtems_configuration_get_microseconds_per_tick())/10000;
 #endif
   XSCALE_OS_TIMER_MR0 = XSCALE_OS_TIMER_TCR + period_num;
@@ -103,9 +103,9 @@ rtems_irq_connect_data clock_isr_data = {
 #if ON_SKYEYE==1
 #else
 #endif
diff --git a/cpukit/libmisc/capture/capture.c b/cpukit/libmisc/capture/capture.c
index 9f068f9..d3f8c5b 100644
--- a/cpukit/libmisc/capture/capture.c
+++ b/cpukit/libmisc/capture/capture.c
@@ -1031,7 +1031,7 @@ rtems_capture_open (uint32_t   size, rtems_capture_timestamp timestamp __attribu
    * Get the tick period from the BSP Configuration Table.
-  capture_tick_period = Configuration.microseconds_per_tick;
+  capture_tick_period = rtems_configuration_get_microseconds_per_tick();
    * Register the user extension handlers for the CAPture Engine.
1.7.7
rtems-devel mailing list
rtems-devel at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-devel
