[PATCH 5/8] sptests/spinternalerror01: New test
Wed Nov 7 16:06:00 UTC 2012
 testsuites/sptests/Makefile.am                     |    1 +
 testsuites/sptests/configure.ac                    |    1 +
 testsuites/sptests/spinternalerror01/Makefile.am   |   19 +++++
 testsuites/sptests/spinternalerror01/init.c        |   74 ++++++++++++++++++++
 .../spinternalerror01/spinternalerror01.doc        |   11 +++
 .../spinternalerror01/spinternalerror01.scn        |    2 +
 6 files changed, 108 insertions(+), 0 deletions(-)
 create mode 100644 testsuites/sptests/spinternalerror01/Makefile.am
 create mode 100644 testsuites/sptests/spinternalerror01/init.c
 create mode 100644 testsuites/sptests/spinternalerror01/spinternalerror01.doc
 create mode 100644 testsuites/sptests/spinternalerror01/spinternalerror01.scn
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index dd79451..b596961 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -30,6 +30,7 @@ SUBDIRS = \
     spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01
 SUBDIRS += speventtransient01
 SUBDIRS += speventsystem01
+SUBDIRS += spinternalerror01
 include $(top_srcdir)/../automake/subdirs.am
 include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 5bee64c..0f0c9bd 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -27,6 +27,7 @@ AC_CHECK_SIZEOF([time_t])
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+spinternalerror01/Makefile
 speventsystem01/Makefile
 speventtransient01/Makefile
 spintrcritical18/Makefile
diff --git a/testsuites/sptests/spinternalerror01/Makefile.am b/testsuites/sptests/spinternalerror01/Makefile.am
new file mode 100644
index 0000000..0f8d985
--- /dev/null
+++ b/testsuites/sptests/spinternalerror01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spinternalerror01
+spinternalerror01_SOURCES = init.c
+dist_rtems_tests_DATA = spinternalerror01.scn spinternalerror01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spinternalerror01_OBJECTS)
+LINK_LIBS = $(spinternalerror01_LDLIBS)
+spinternalerror01$(EXEEXT): $(spinternalerror01_OBJECTS) $(spinternalerror01_DEPENDENCIES)
+	@rm -f spinternalerror01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spinternalerror01/init.c b/testsuites/sptests/spinternalerror01/init.c
index 0000000..e592fcc
--- /dev/null
+++ b/testsuites/sptests/spinternalerror01/init.c
@@ -0,0 +1,74 @@
+ * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Obere Lagerstr. 30
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <bsp.h>
+#include <bsp/bootcard.h>
+uint32_t boot_card(const char *cmdline)
+  _Internal_error_Occurred(0xdeadbeef, false, 0x600df00d);
+  return 0;
+static void fatal_extension(uint32_t source, bool is_internal, uint32_t error)
+  printk(
+    "\n"
+    "\n"
+    "*** TEST SPINTERNALERROR 1 ***\n"
+    "*** END OF TEST SPINTERNALERROR 1 ***\n"
+static void *idle_body(uintptr_t ignored)
+  while (true) {
+    /* Do nothing */
+  return NULL;
+#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = fatal_extension }
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
+#define CONFIGURE_SCHEDULER_ENTRY_POINTS NULL
+#define CONFIGURE_SCHEDULER_USER
+#define CONFIGURE_MEMORY_FOR_SCHEDULER 0
+#define CONFIGURE_MEMORY_PER_TASK_FOR_SCHEDULER 0
+#define CONFIGURE_TASK_STACK_ALLOCATOR NULL
+#define CONFIGURE_TASK_STACK_DEALLOCATOR NULL
+#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+#define CONFIGURE_IDLE_TASK_BODY idle_body
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spinternalerror01/spinternalerror01.doc b/testsuites/sptests/spinternalerror01/spinternalerror01.doc
index 0000000..a37c5b0
--- /dev/null
+++ b/testsuites/sptests/spinternalerror01/spinternalerror01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spinternalerror01
+directives:
+  _Internal_error_Occurred()
+concepts:
+  - Ensure that _Internal_error_Occurred() works right after low-level start.
diff --git a/testsuites/sptests/spinternalerror01/spinternalerror01.scn b/testsuites/sptests/spinternalerror01/spinternalerror01.scn
index 0000000..ecdae59
--- /dev/null
+++ b/testsuites/sptests/spinternalerror01/spinternalerror01.scn
@@ -0,0 +1,2 @@
+*** TEST SPINTERNALERROR 1 ***
+*** END OF TEST SPINTERNALERROR 1 ***
1.7.7
