[PATCH v3] score: PR1607: Add and use CPU_SIZEOF_POINTER
Thu Nov 8 08:27:52 UTC 2012
Add and use new CPU port define CPU_SIZEOF_POINTER.  It must be an
integer literal that can be used by the assembler.  This value will be
used to calculate offsets of structure members.  These offsets will be
used in assembler code.
The size of a pointer is part of the application binary interface (ABI)
and thus independent of the actual programming language.  The compiler
will provide defines to determine the current ABI.  We use these defines
to select the appropriate CPU_SIZEOF_POINTER value.
Static assertions in the new file "cpukit/score/src/percpuasm.c" will
ensure that the value of CPU_SIZEOF_POINTER is consistent with the
current compiler settings.  Also the offset values used by assembler
code are verfied.
 cpukit/configure.ac                        |    9 ---
 cpukit/score/Makefile.am                   |    1 +
 cpukit/score/cpu/arm/rtems/score/cpu.h     |    3 +
 cpukit/score/cpu/avr/rtems/score/cpu.h     |    2 +
 cpukit/score/cpu/bfin/rtems/score/cpu.h    |    2 +
 cpukit/score/cpu/h8300/rtems/score/cpu.h   |    6 ++
 cpukit/score/cpu/i386/rtems/score/cpu.h    |    2 +
 cpukit/score/cpu/lm32/rtems/score/cpu.h    |    2 +
 cpukit/score/cpu/m32c/rtems/score/cpu.h    |    6 ++
 cpukit/score/cpu/m32r/rtems/score/cpu.h    |    2 +
 cpukit/score/cpu/m68k/rtems/score/cpu.h    |    2 +
 cpukit/score/cpu/mips/rtems/score/cpu.h    |    2 +
 cpukit/score/cpu/nios2/rtems/score/cpu.h   |    2 +
 cpukit/score/cpu/no_cpu/rtems/score/cpu.h  |    9 +++
 cpukit/score/cpu/powerpc/rtems/score/cpu.h |    2 +
 cpukit/score/cpu/sh/rtems/score/cpu.h      |    2 +
 cpukit/score/cpu/sparc/rtems/score/cpu.h   |    2 +
 cpukit/score/cpu/sparc64/rtems/score/cpu.h |    2 +
 cpukit/score/cpu/v850/rtems/score/cpu.h    |    2 +
 cpukit/score/include/rtems/score/percpu.h  |   23 ++++----
 cpukit/score/src/percpuasm.c               |   91 ++++++++++++++++++++++++++++
 21 files changed, 154 insertions(+), 20 deletions(-)
 create mode 100644 cpukit/score/src/percpuasm.c
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index d0d957d..e3c4dd4 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -154,10 +154,6 @@ rtems_major=`echo _RTEMS_VERSION | sed "s/\..*//"`
 rtems_minor=`echo _RTEMS_VERSION | sed "s/[[0-9]][[0-9]]*\.//;s/\..*//"`
 rtems_revision=`echo _RTEMS_VERSION | sed "s/[[0-9]][[0-9]]*\.//;s/[[0-9]][[0-9]]*\.//;s/\..*//"`
-## This is needed to generate the field offsets of the per CPU
-## data structure so they can be accessed from assembly code.
-AC_CHECK_SIZEOF([void *])
 _RTEMS_CPUOPT_INIT
 RTEMS_CPUOPT([RTEMS_DEBUG],
@@ -233,11 +229,6 @@ RTEMS_CPUOPT([__RTEMS_ADA__],
 ## Then we propagate a private copy of the value into cpuopts.h
 ## so it is always available to the RTEMS header files.
-RTEMS_CPUOPT([__RTEMS_SIZEOF_VOID_P__],
-  [true],
-  [$ac_cv_sizeof_void_p],
-  [Size of a void * pointer])
 RTEMS_CPUOPT([__RTEMS_MAJOR__],
   [true],
   [$rtems_major],
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index d259acb..ac82895 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -157,6 +157,7 @@ libscore_a_SOURCES += src/coremutex.c src/coremutexflush.c \
 ## CORE_PERCPU_C_FILES
 libscore_a_SOURCES += src/percpu.c
+libscore_a_SOURCES += src/percpuasm.c
 ## CORE_RWLOCK_C_FILES
 if HAS_PTHREADS
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index b12133f0..813295f 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -185,6 +185,9 @@
 #define CPU_STACK_MINIMUM_SIZE (1024 * 4)
 /* AAPCS, section 4.1, Fundamental Data Types */
+#define CPU_SIZEOF_POINTER 4
+/* AAPCS, section 4.1, Fundamental Data Types */
 #define CPU_ALIGNMENT 8
 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
diff --git a/cpukit/score/cpu/avr/rtems/score/cpu.h b/cpukit/score/cpu/avr/rtems/score/cpu.h
index f085cf4..5436c21 100644
--- a/cpukit/score/cpu/avr/rtems/score/cpu.h
+++ b/cpukit/score/cpu/avr/rtems/score/cpu.h
@@ -527,6 +527,8 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
 #define CPU_PRIORITY_MAXIMUM             15
+#define CPU_SIZEOF_POINTER 2
  *  CPU's worst alignment requirement for data types on a byte boundary.  This
  *  alignment does not take into account the requirements for the stack.
diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
index 479311d..a8cfc17 100644
--- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
@@ -615,6 +615,8 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
 #define CPU_STACK_MINIMUM_SIZE          (1024*8)
diff --git a/cpukit/score/cpu/h8300/rtems/score/cpu.h b/cpukit/score/cpu/h8300/rtems/score/cpu.h
index ea9d443..1811ce7 100644
--- a/cpukit/score/cpu/h8300/rtems/score/cpu.h
+++ b/cpukit/score/cpu/h8300/rtems/score/cpu.h
@@ -497,6 +497,12 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
 #define CPU_STACK_MINIMUM_SIZE          (1536)
+#if defined(__H8300H__) || defined(__H8300S__) || defined(__H8300SX__)
+  #define CPU_SIZEOF_POINTER 4
+#else
+  #define CPU_SIZEOF_POINTER 2
+#endif
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index a8d23f9..2a48711 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -323,6 +323,8 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
 #define CPU_STACK_MINIMUM_SIZE          4096
  *  i386 is pretty tolerant of alignment.  Just put things on 4 byte boundaries.
diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
index 19f3017..9f0876a 100644
--- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
 #define CPU_STACK_MINIMUM_SIZE          (1024*4)
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index c1d1db8..d83e93d 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -575,6 +575,12 @@ typedef struct {
 #define CPU_STACK_MINIMUM_SIZE          (2048L)
+#ifdef __m32cm_cpu__
+#else
+#endif
diff --git a/cpukit/score/cpu/m32r/rtems/score/cpu.h b/cpukit/score/cpu/m32r/rtems/score/cpu.h
index 4e4c01f..02bc928 100644
--- a/cpukit/score/cpu/m32r/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32r/rtems/score/cpu.h
@@ -622,6 +622,8 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
 #define CPU_STACK_MINIMUM_SIZE          (1024)
diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
index 013f1b5..89b0295 100644
--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
@@ -380,6 +380,8 @@ SCORE_EXTERN _CPU_ISR_handler_entry _CPU_ISR_jump_table[256];
 #define CPU_PRIORITY_MAXIMUM             M68K_CPU_PRIORITY_MAXIMUM
  *  m68k is pretty tolerant of alignment.  Just put things on 4 byte boundaries.
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index d0f7c05..3d6b540 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -655,6 +655,8 @@ extern unsigned int mips_interrupt_number_of_vectors;
 #define CPU_STACK_MINIMUM_SIZE          (8 * 1024)
diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h b/cpukit/score/cpu/nios2/rtems/score/cpu.h
index 0632aa9..4d61c42 100644
--- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
@@ -73,6 +73,8 @@ extern "C" {
 #define CPU_STACK_MINIMUM_SIZE (4 * 1024)
  * Alignment value according to "Nios II Processor Reference" chapter 7
  * "Application Binary Interface" section "Memory Alignment".
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index 8a00c19..9ab1f26 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -684,6 +684,15 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
+ *  Size of a pointer.
+ *  This must be an integer literal that can be used by the assembler.  This
+ *  value will be used to calculate offsets of structure members.  These
+ *  offsets will be used in assembler code.
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 840df7a..a38f9a4 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -668,6 +668,8 @@ void _BSP_Fatal_error(unsigned int);
diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
index 29319da..789024e 100644
--- a/cpukit/score/cpu/sh/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
@@ -456,6 +456,8 @@ SCORE_EXTERN void CPU_delay( uint32_t   microseconds );
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index 06bb26e..d92b63c 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -874,6 +874,8 @@ extern const CPU_Trap_table_entry _CPU_Trap_slot_template;
diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
index 0f69c6d..f821e96 100644
--- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
@@ -696,6 +696,8 @@ extern const CPU_Trap_table_entry _CPU_Trap_slot_template;
+#define CPU_SIZEOF_POINTER 8
diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
index 875f160..371bc32 100644
--- a/cpukit/score/cpu/v850/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
@@ -581,6 +581,8 @@ typedef struct {
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 50dd2e6..ed08f8a 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -150,12 +150,13 @@ typedef struct {
 } Per_CPU_Control;
 #endif
-#ifdef ASM
+#if defined(ASM) || defined(_RTEMS_PERCPU_DEFINE_OFFSETS)
 #if defined(RTEMS_SMP)
   #define PER_CPU_LOCK     0
-  #define PER_CPU_STATE    (1 * __RTEMS_SIZEOF_VOID_P__)
-  #define PER_CPU_MESSAGE  (2 * __RTEMS_SIZEOF_VOID_P__)
-  #define PER_CPU_END_SMP  (3 * __RTEMS_SIZEOF_VOID_P__)
+  #define PER_CPU_STATE    (1 * CPU_SIZEOF_POINTER)
+  #define PER_CPU_MESSAGE  (2 * CPU_SIZEOF_POINTER)
+  #define PER_CPU_END_SMP  (3 * CPU_SIZEOF_POINTER)
 #else
   #define PER_CPU_END_SMP  0
 #endif
@@ -168,9 +169,9 @@ typedef struct {
   #define PER_CPU_INTERRUPT_STACK_LOW   PER_CPU_END_SMP
   #define PER_CPU_INTERRUPT_STACK_HIGH  \
-          PER_CPU_INTERRUPT_STACK_LOW + (1 * __RTEMS_SIZEOF_VOID_P__)
+          PER_CPU_INTERRUPT_STACK_LOW + (1 * CPU_SIZEOF_POINTER)
   #define PER_CPU_END_STACK             \
-          PER_CPU_INTERRUPT_STACK_HIGH + (1 * __RTEMS_SIZEOF_VOID_P__)
+          PER_CPU_INTERRUPT_STACK_HIGH + (1 * CPU_SIZEOF_POINTER)
 #else
   #define PER_CPU_END_STACK             PER_CPU_END_SMP
 #endif
@@ -181,13 +182,13 @@ typedef struct {
 #define PER_CPU_ISR_NEST_LEVEL \
           PER_CPU_END_STACK + 0
 #define PER_CPU_EXECUTING \
-          PER_CPU_END_STACK + (1 * __RTEMS_SIZEOF_VOID_P__)
+          PER_CPU_END_STACK + (1 * CPU_SIZEOF_POINTER)
 #define PER_CPU_HEIR \
-          PER_CPU_END_STACK + (2 * __RTEMS_SIZEOF_VOID_P__)
+          PER_CPU_END_STACK + (2 * CPU_SIZEOF_POINTER)
 #define PER_CPU_IDLE \
-          PER_CPU_END_STACK + (3 * __RTEMS_SIZEOF_VOID_P__)
+          PER_CPU_END_STACK + (3 * CPU_SIZEOF_POINTER)
 #define PER_CPU_DISPATCH_NEEDED \
-	  PER_CPU_END_STACK + (4 * __RTEMS_SIZEOF_VOID_P__)
+	  PER_CPU_END_STACK + (4 * CPU_SIZEOF_POINTER)
 #define ISR_NEST_LEVEL \
          (SYM(_Per_CPU_Information) + PER_CPU_ISR_NEST_LEVEL)
@@ -205,7 +206,7 @@ typedef struct {
       (SYM(_Per_CPU_Information) + PER_CPU_INTERRUPT_STACK_HIGH)
 #endif
-#endif
+#endif /* defined(ASM) || defined(_RTEMS_PERCPU_DEFINE_OFFSETS) */
 #ifndef ASM
diff --git a/cpukit/score/src/percpuasm.c b/cpukit/score/src/percpuasm.c
new file mode 100644
index 0000000..4aa3b61
--- /dev/null
+++ b/cpukit/score/src/percpuasm.c
@@ -0,0 +1,91 @@
+ * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Obere Lagerstr. 30
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/score/cpu.h>
+#define _RTEMS_PERCPU_DEFINE_OFFSETS
+#include <rtems/score/percpu.h>
+RTEMS_STATIC_ASSERT(
+  sizeof(void *) == CPU_SIZEOF_POINTER,
+  CPU_SIZEOF_POINTER
+#ifdef __SIZEOF_POINTER__
+  RTEMS_STATIC_ASSERT(
+    CPU_SIZEOF_POINTER == __SIZEOF_POINTER__,
+    __SIZEOF_POINTER__
+#endif
+  offsetof(Per_CPU_Control, isr_nest_level) == PER_CPU_ISR_NEST_LEVEL,
+  offsetof(Per_CPU_Control, executing) == PER_CPU_EXECUTING,
+  PER_CPU_EXECUTING
+  offsetof(Per_CPU_Control, heir) == PER_CPU_HEIR,
+  PER_CPU_HEIR
+  offsetof(Per_CPU_Control, idle) == PER_CPU_IDLE,
+  PER_CPU_IDLE
+  offsetof(Per_CPU_Control, dispatch_necessary) == PER_CPU_DISPATCH_NEEDED,
+  PER_CPU_DISPATCH_NEEDED
+#if CPU_ALLOCATE_INTERRUPT_STACK == TRUE \
+  || CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE
+    offsetof(Per_CPU_Control, interrupt_stack_low)
+      == PER_CPU_INTERRUPT_STACK_LOW,
+    offsetof(Per_CPU_Control, interrupt_stack_high)
+      == PER_CPU_INTERRUPT_STACK_HIGH,
+#endif
+#ifdef RTEMS_SMP
+    offsetof(Per_CPU_Control, lock) == PER_CPU_LOCK,
+    PER_CPU_LOCK
+    offsetof(Per_CPU_Control, state) == PER_CPU_STATE,
+    PER_CPU_STATE
+    offsetof(Per_CPU_Control, message) == PER_CPU_MESSAGE,
+    PER_CPU_MESSAGE
+#endif
1.7.7
