[PATCH 1/3] powerpc: Delete _CPU_Install_interrupt_stack()
Sebastian Huber
Tue Nov 13 16:55:36 UTC 2012
This function is only used if CPU_HAS_HARDWARE_INTERRUPT_STACK == TRUE.
c/src/lib/libcpu/powerpc/new-exceptions/cpu.c | 9 ---------
cpukit/score/cpu/powerpc/rtems/score/cpu.h | 11 -----------
2 files changed, 0 insertions(+), 20 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c b/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c
index 5c0f8d1..cb944ba 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c
@@ -133,15 +133,6 @@ void _CPU_Context_Initialize(
#endif
-/*PAGE
- * _CPU_Install_interrupt_stack
-void _CPU_Install_interrupt_stack( void )
/* _CPU_ISR_install_vector
* This kernel routine installs the RTEMS handler for the
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index a38f9a4..31b4e7c 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -947,17 +947,6 @@ void _CPU_ISR_install_vector(
- * This routine installs the hardware interrupt stack pointer.
- * NOTE: It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
- * is TRUE.
-void _CPU_Install_interrupt_stack( void );
* _CPU_Context_switch
* This routine switches from the run context to the heir context.
1.7.7
