[PATCH 03/16] sapi: Add rtems_fatal_source and rtems_fatal_code
Wed Nov 14 15:46:57 UTC 2012
 .../shared/include/default-initial-extension.h     |    4 ++--
 cpukit/sapi/include/rtems/extension.h              |    4 ++++
 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/c/src/lib/libbsp/shared/include/default-initial-extension.h b/c/src/lib/libbsp/shared/include/default-initial-extension.h
index 618a097..44938c8 100644
--- a/c/src/lib/libbsp/shared/include/default-initial-extension.h
+++ b/c/src/lib/libbsp/shared/include/default-initial-extension.h
@@ -22,9 +22,9 @@ extern "C" {
 #endif /* __cplusplus */
 void bsp_fatal_extension(
-  Internal_errors_Source source,
+  rtems_fatal_source source,
   bool is_internal,
-  Internal_errors_t error
+  rtems_fatal_code error
 #define BSP_INITIAL_EXTENSION \
diff --git a/cpukit/sapi/include/rtems/extension.h b/cpukit/sapi/include/rtems/extension.h
index bc213b7..f9f1ae1 100644
--- a/cpukit/sapi/include/rtems/extension.h
+++ b/cpukit/sapi/include/rtems/extension.h
@@ -182,6 +182,10 @@ typedef User_extensions_fatal_extension           rtems_fatal_extension;
 typedef User_extensions_Table                     rtems_extensions_table;
+typedef Internal_errors_Source rtems_fatal_source;
+typedef Internal_errors_t rtems_fatal_code;
  * @brief Creates an extension set object.
1.7.7
