[rtems commit] score: Add RTEMS_FATAL_SOURCE_APPLICATION
Chris Johns
chrisj at rtems.org
Thu Nov 15 18:54:54 UTC 2012
This seems wrong because the file is ...
> cpukit/score/include/rtems/score/interr.h
.. and that name means internal error and ...
> + * @brief Fatal source for application specific errors.
> + * The fatal code is application specific.
> + RTEMS_FATAL_SOURCE_APPLICATION,
adding application or non-internal errors to the Internal_errors_Source enum seems wrong.
Why are you adding non-internal errors to the internal error list ?
What is the use case ?
The same goes for the other additions.
Also the comment in the doxygen section of the file states ...
* This handler encapsulates functionality which provides the foundation
* Semaphore services used in all of the APIs supported by RTEMS.
.. which is a little confusing for an internal header file. Cut and paste error in the past ?
