[rtems commit] bsps/sparc: Add BSP_INITIAL_EXTENSION to <bsp.h>
Fri Nov 16 08:20:21 UTC 2012
On 11/15/2012 09:37 PM, Chris Johns wrote:
> Sebastian Huber wrote:
>> +++ b/c/src/lib/libbsp/sparc/shared/startup/bspfatalextension.c
> Not an score or even cpukit header yet is references ...
>> +  Internal_errors_Source source,
> ... which is defined internally.
This problem is present since day one of the user extensions.  Due to that I added
http://git.rtems.org/rtems/commit/?id=e4b40531f3c4b9a6c12be10cc18a9d0f84570230
> This should not be done this way. Looks like we need an external interface to
> guard the score internals.
In this case this will not help since this enum is part of the public interface.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
