[rtems commit] bsps/sparc: Add BSP_INITIAL_EXTENSION to <bsp.h>
Fri Nov 16 08:32:56 UTC 2012
Sebastian Huber wrote:
>>> +++ b/c/src/lib/libbsp/sparc/shared/startup/bspfatalextension.c
>> Not an score or even cpukit header yet is references ...
>>> + Internal_errors_Source source,
>> ... which is defined internally.
> This problem is present since day one of the user extensions.
Yes I checked after posting and found this is the case. It does not make
it ok nor specifically your problem.
> Due to that I added
> http://git.rtems.org/rtems/commit/?id=e4b40531f3c4b9a6c12be10cc18a9d0f84570230
I noticed and this is a good move. It was just the order I reviewed the
patches.
>> This should not be done this way. Looks like we need an external
>> interface to
>> guard the score internals.
> In this case this will not help since this enum is part of the public
> interface.
Yes. I created a bug to capture this issue.
Given the fact this is part of the C User manual the patches are fine.
