PowerPC Book E ESR missing from exception frame
Thu Nov 22 19:20:30 UTC 2012
The answer is probably simpler than you expect :)
My recollection is that whoever write it didn't use a 40x CPU. Till likely was the last one to touch this code. Please enhance as you see fit.
Happy Thanksgiving
"Claus, Ric" <claus at slac.stanford.edu> wrote:
>On the PPC 405 and PPC 440, it is often useful to look at the Exception Syndrome Register (SPR 62), especially after a program exception.  Would the PowerPC gurus please comment on why it is missing from the register dump and/or whether it would be agreeable to add it?  I volunteer to do the work.
>Thanks,
>            Ric Claus (SLAC)
>_______________________________________________
>rtems-devel mailing list
>rtems-devel at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-devel
