[PATCH 4/4] score: Add CPU_Exception_frame
Mon Nov 26 17:17:05 UTC 2012
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions.  Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
 c/src/aclocal/bsp-bspcleanup-options.m4            |    7 ++-
 .../lib/libbsp/mips/shared/irq/vectorexceptions.c  |    6 +-
 c/src/lib/libbsp/powerpc/psim/configure.ac         |    2 +-
 c/src/lib/libbsp/shared/bspclean.c                 |    8 ++-
 c/src/lib/libbsp/sparc/erc32/configure.ac          |    2 +-
 c/src/lib/libbsp/sparc/erc32/startup/spurious.c    |   35 +++++----
 c/src/lib/libbsp/sparc/leon2/startup/spurious.c    |   35 +++++----
 c/src/lib/libbsp/sparc/leon3/startup/spurious.c    |   36 +++++----
 c/src/lib/libcpu/powerpc/Makefile.am               |    3 +-
 .../bspsupport/ppc_exc_global_handler.c            |    2 +-
 .../new-exceptions/bspsupport/ppc_exc_print.c      |    2 +-
 .../powerpc/new-exceptions/bspsupport/vectors.h    |    2 -
 cpukit/sapi/include/rtems/fatal.h                  |   17 ++++
 cpukit/score/cpu/arm/Makefile.am                   |    2 +
 cpukit/score/cpu/arm/arm-exception-frame-print.c   |   28 +++++++
 .../score/cpu/arm/armv7m-exception-frame-print.c   |   28 +++++++
 cpukit/score/cpu/arm/rtems/score/cpu.h             |    5 +
 cpukit/score/cpu/avr/Makefile.am                   |    1 +
 cpukit/score/cpu/avr/avr-exception-frame-print.c   |   24 ++++++
 cpukit/score/cpu/avr/rtems/score/cpu.h             |    5 +
 cpukit/score/cpu/bfin/Makefile.am                  |    1 +
 cpukit/score/cpu/bfin/bfin-exception-frame-print.c |   24 ++++++
 cpukit/score/cpu/bfin/rtems/score/cpu.h            |    5 +
 cpukit/score/cpu/h8300/Makefile.am                 |    1 +
 .../score/cpu/h8300/h8300-exception-frame-print.c  |   24 ++++++
 cpukit/score/cpu/h8300/rtems/score/cpu.h           |    5 +
 cpukit/score/cpu/i386/cpu.c                        |   12 ++-
 cpukit/score/cpu/i386/rtems/score/cpu.h            |    2 +
 cpukit/score/cpu/lm32/Makefile.am                  |    1 +
 cpukit/score/cpu/lm32/lm32-exception-frame-print.c |   24 ++++++
 cpukit/score/cpu/lm32/rtems/score/cpu.h            |    5 +
 cpukit/score/cpu/m32c/Makefile.am                  |    1 +
 cpukit/score/cpu/m32c/m32c-exception-frame-print.c |   24 ++++++
 cpukit/score/cpu/m32c/rtems/score/cpu.h            |    5 +
 cpukit/score/cpu/m32r/Makefile.am                  |    1 +
 cpukit/score/cpu/m32r/m32r-exception-frame-print.c |   24 ++++++
 cpukit/score/cpu/m32r/rtems/score/cpu.h            |    5 +
 cpukit/score/cpu/m68k/Makefile.am                  |    1 +
 cpukit/score/cpu/m68k/m68k-exception-frame-print.c |   24 ++++++
 cpukit/score/cpu/m68k/rtems/score/cpu.h            |    2 +
 cpukit/score/cpu/mips/rtems/score/cpu.h            |   13 +++
 cpukit/score/cpu/nios2/Makefile.am                 |    1 +
 .../score/cpu/nios2/nios2-exception-frame-print.c  |   24 ++++++
 cpukit/score/cpu/nios2/rtems/score/cpu.h           |    2 +
 cpukit/score/cpu/no_cpu/rtems/score/cpu.h          |   22 +++++
 cpukit/score/cpu/powerpc/rtems/score/cpu.h         |    9 ++
 cpukit/score/cpu/sh/Makefile.am                    |    1 +
 cpukit/score/cpu/sh/rtems/score/cpu.h              |    4 +
 cpukit/score/cpu/sh/sh-exception-frame-print.c     |   24 ++++++
 cpukit/score/cpu/sparc/rtems/score/cpu.h           |   14 +++
 cpukit/score/cpu/sparc64/Makefile.am               |    1 +
 cpukit/score/cpu/sparc64/rtems/score/cpu.h         |    5 +
 .../cpu/sparc64/sparc64-exception-frame-print.c    |   24 ++++++
 cpukit/score/cpu/v850/Makefile.am                  |    1 +
 cpukit/score/cpu/v850/rtems/score/cpu.h            |    5 +
 cpukit/score/cpu/v850/v850-exception-frame-print.c |   24 ++++++
 cpukit/score/include/rtems/score/interr.h          |    6 +-
 doc/user/fatal.t                                   |   27 ++++++
 testsuites/sptests/Makefile.am                     |    1 +
 testsuites/sptests/configure.ac                    |    1 +
 testsuites/sptests/spfatal26/Makefile.am           |   19 +++++
 testsuites/sptests/spfatal26/init.c                |   85 ++++++++++++++++++++
 testsuites/sptests/spfatal26/spfatal26.doc         |   11 +++
 testsuites/sptests/spfatal26/spfatal26.scn         |    2 +
 64 files changed, 702 insertions(+), 65 deletions(-)
 create mode 100644 cpukit/score/cpu/arm/arm-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/arm/armv7m-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/avr/avr-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/bfin/bfin-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/h8300/h8300-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/lm32/lm32-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/m32c/m32c-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/m32r/m32r-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/m68k/m68k-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/nios2/nios2-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/sh/sh-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/v850/v850-exception-frame-print.c
 create mode 100644 testsuites/sptests/spfatal26/Makefile.am
 create mode 100644 testsuites/sptests/spfatal26/init.c
 create mode 100644 testsuites/sptests/spfatal26/spfatal26.doc
 create mode 100644 testsuites/sptests/spfatal26/spfatal26.scn
diff --git a/c/src/aclocal/bsp-bspcleanup-options.m4 b/c/src/aclocal/bsp-bspcleanup-options.m4
index cac8d55..00bc0fb 100644
--- a/c/src/aclocal/bsp-bspcleanup-options.m4
+++ b/c/src/aclocal/bsp-bspcleanup-options.m4
@@ -9,10 +9,11 @@ dnl
 dnl To be used in bsp-configure scripts
 dnl USAGE:
-dnl    RTEMS_BSP_CLEANUP_OPTIONS([0|1], [0|1])
+dnl    RTEMS_BSP_CLEANUP_OPTIONS([0|1], [0|1], [0|1])
 dnl WHERE:
 dnl    argument 1 indicates the default value for BSP_PRESS_KEY_FOR_RESET
 dnl    argument 2 indicates the default value for BSP_RESET_BOARD_AT_EXIT
+dnl    argument 3 indicates the default value for BSP_PRINT_EXCEPTION_CONTEXT
 AC_DEFUN([RTEMS_BSP_CLEANUP_OPTIONS],[
 RTEMS_BSPOPTS_SET([BSP_PRESS_KEY_FOR_RESET],[*],[$1])
@@ -23,4 +24,8 @@ RTEMS_BSPOPTS_HELP([BSP_PRESS_KEY_FOR_RESET],
 RTEMS_BSPOPTS_SET([BSP_RESET_BOARD_AT_EXIT],[*],[$2])
 RTEMS_BSPOPTS_HELP([BSP_RESET_BOARD_AT_EXIT],
 [If defined, reset the board when the application exits.])
+RTEMS_BSPOPTS_SET([BSP_PRINT_EXCEPTION_CONTEXT],[*],[$3])
+RTEMS_BSPOPTS_HELP([BSP_PRINT_EXCEPTION_CONTEXT],
+[If defined, prints the exception context when an unexpected exception occurs.])
diff --git a/c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c b/c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c
index 91ecf33..e0e175c 100644
--- a/c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c
+++ b/c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c
@@ -24,9 +24,7 @@
 #include <rtems/bspIo.h>
 #include <bsp/irq-generic.h>
-void mips_vector_exceptions( CPU_Interrupt_frame *frame );
-static const char *cause_strings[32] =
+static const char *const cause_strings[32] =
   /*  0 */ "Int",
   /*  1 */ "TLB Mods",
@@ -79,7 +77,7 @@ static const struct regdef dumpregs[]= {
   { R_EPC,"R_EPC"}, { -1, NULL }
-static void mips_dump_exception_frame( CPU_Interrupt_frame *frame )
+void _BSP_Exception_frame_print( const CPU_Exception_frame *frame )
   uint32_t *frame_u32;
   int   i, j;
diff --git a/c/src/lib/libbsp/powerpc/psim/configure.ac b/c/src/lib/libbsp/powerpc/psim/configure.ac
index c21b7ec..4d6c453 100644
--- a/c/src/lib/libbsp/powerpc/psim/configure.ac
+++ b/c/src/lib/libbsp/powerpc/psim/configure.ac
@@ -45,7 +45,7 @@ Note that the policy can still be defined by the application
 CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK this feature is removed
 and a little memory is saved.])
-RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
+RTEMS_BSP_CLEANUP_OPTIONS(0, 1, 1)
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile])
diff --git a/c/src/lib/libbsp/shared/bspclean.c b/c/src/lib/libbsp/shared/bspclean.c
index 1d6f08a..3e48c29 100644
--- a/c/src/lib/libbsp/shared/bspclean.c
+++ b/c/src/lib/libbsp/shared/bspclean.c
@@ -16,7 +16,7 @@
 void bsp_fatal_extension(
   rtems_fatal_source source,
   bool is_internal,
-  rtems_fatal_code error
+  rtems_fatal_code code
   #if (BSP_PRESS_KEY_FOR_RESET)
@@ -31,6 +31,12 @@ void bsp_fatal_extension(
     printk("\n");
   #endif
+  #if (BSP_PRINT_EXCEPTION_CONTEXT)
+    if ( source == RTEMS_FATAL_SOURCE_EXCEPTION ) {
+      rtems_exception_frame_print( (const rtems_exception_frame *) code );
+  #endif
    *  Check both conditions -- if you want to ask for reboot, then
    *  you must have meant to reset the board.
diff --git a/c/src/lib/libbsp/sparc/erc32/configure.ac b/c/src/lib/libbsp/sparc/erc32/configure.ac
index 5f1317c..8155514 100644
--- a/c/src/lib/libbsp/sparc/erc32/configure.ac
+++ b/c/src/lib/libbsp/sparc/erc32/configure.ac
@@ -42,7 +42,7 @@ RTEMS_BSPOPTS_HELP([ENABLE_SIS_QUIRKS],
  BSP will be enabled.  In particular, SIS requires special
  initialization not used on real ERC32 hardware.])
-RTEMS_BSP_CLEANUP_OPTIONS(0,1)
+RTEMS_BSP_CLEANUP_OPTIONS(0,1,1)
diff --git a/c/src/lib/libbsp/sparc/erc32/startup/spurious.c b/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
index bbf6cca..b74f0c7 100644
--- a/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
+++ b/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
@@ -16,20 +16,15 @@
 #include <bsp.h>
- *  bsp_spurious_handler
- *  Print a message on the debug console and then die
-rtems_isr bsp_spurious_handler(
-   rtems_vector_number trap,
-   CPU_Interrupt_frame *isf
-  uint32_t         real_trap;
+  uint32_t                   trap;
+  uint32_t                   real_trap;
+  const CPU_Interrupt_frame *isf;
+  trap = frame->trap;
   real_trap = SPARC_REAL_TRAP_NUMBER(trap);
+  isf = frame->isf;
   printk( "Unexpected trap (%2d) at address 0x%08x\n", real_trap, isf->tpc);
@@ -121,12 +116,22 @@ rtems_isr bsp_spurious_handler(
     default:
       break;
-   *  What else can we do but stop ...
+rtems_isr bsp_spurious_handler(
+   rtems_vector_number trap,
+   CPU_Interrupt_frame *isf
+  CPU_Exception_frame frame = {
+    .trap = trap,
+    .isf = isf
-  __asm__ volatile( "mov 1, %g1; ta 0x0" );
+  rtems_fatal(
+    RTEMS_FATAL_SOURCE_EXCEPTION,
+    (rtems_fatal_code) &frame
diff --git a/c/src/lib/libbsp/sparc/leon2/startup/spurious.c b/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
index c4bdf79..c0500c7 100644
--- a/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
+++ b/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
@@ -16,20 +16,15 @@
 #include <bsp.h>
+  uint32_t                   trap;
+  isf = frame->isf;
@@ -102,12 +97,22 @@ rtems_isr bsp_spurious_handler(
     default:
       break;
+    .trap = trap,
+    .isf = isf
+  rtems_fatal(
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
index f060e28..e12ac01 100644
--- a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
+++ b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
@@ -18,23 +18,17 @@
 #include <bsp.h>
+  uint32_t                   trap;
+  isf = frame->isf;
   printk( "Unexpected trap (0x%02x) at address 0x%08x\n", real_trap, isf->tpc);
@@ -113,12 +107,22 @@ rtems_isr bsp_spurious_handler(
     default:
       break;
+    .trap = trap,
+    .isf = isf
+  rtems_fatal(
diff --git a/c/src/lib/libcpu/powerpc/Makefile.am b/c/src/lib/libcpu/powerpc/Makefile.am
index 4401b5f..febcc6b 100644
--- a/c/src/lib/libcpu/powerpc/Makefile.am
+++ b/c/src/lib/libcpu/powerpc/Makefile.am
@@ -188,7 +188,8 @@ mpc5xx_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 include_libcpu_HEADERS += mpc5xx/vectors/vectors.h
 noinst_PROGRAMS += mpc5xx/vectors.rel
-mpc5xx_vectors_rel_SOURCES = mpc5xx/vectors/vectors_init.c mpc5xx/vectors/vectors.S
+mpc5xx_vectors_rel_SOURCES = mpc5xx/vectors/vectors_init.c mpc5xx/vectors/vectors.S \
+    new-exceptions/bspsupport/ppc_exc_print.c
 mpc5xx_vectors_rel_CPPFLAGS = $(AM_CPPFLAGS)
 mpc5xx_vectors_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 endif
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c
index 30c7d9e..463f429 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c
@@ -22,7 +22,7 @@
 void C_exception_handler(BSP_Exception_frame *excPtr)
   rtems_fatal(
-    RTEMS_FATAL_SOURCE_POWERPC_EXCEPTION,
     (rtems_fatal_code) excPtr
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c
index e1bbf12..34233ba 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c
@@ -85,7 +85,7 @@ void BSP_printStackTrace(const BSP_Exception_frame *excPtr)
-void ppc_exc_print_frame_and_context(const BSP_Exception_frame *excPtr)
+void _BSP_Exception_frame_print(const CPU_Exception_frame *excPtr)
   const Thread_Control *executing = _Thread_Executing;
   bool synch = (int) excPtr->_EXC_number >= 0;
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
index 9925845..2f1ec37 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h
@@ -271,8 +271,6 @@ extern exception_handler_t globalExceptHdl;
 void C_exception_handler(BSP_Exception_frame* excPtr);
-void ppc_exc_print_frame_and_context(const BSP_Exception_frame *excPtr);
 void BSP_printStackTrace(const BSP_Exception_frame *excPtr);
diff --git a/cpukit/sapi/include/rtems/fatal.h b/cpukit/sapi/include/rtems/fatal.h
index 6692605..64344b3 100644
--- a/cpukit/sapi/include/rtems/fatal.h
+++ b/cpukit/sapi/include/rtems/fatal.h
@@ -37,6 +37,23 @@ extern "C" {
+ * @brief Exception frame.
+typedef CPU_Exception_frame rtems_exception_frame;
+ *  @brief Prints the exception frame via printk().
+ *  @see rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
+static inline void rtems_exception_frame_print(
+  const rtems_exception_frame *frame
+  _CPU_Exception_frame_print( frame );
  * @brief Invokes the internal error handler with a source of
  * INTERNAL_ERROR_RTEMS_API and is internal set to false.
diff --git a/cpukit/score/cpu/arm/Makefile.am b/cpukit/score/cpu/arm/Makefile.am
index 0da1984..f0ddbd6 100644
--- a/cpukit/score/cpu/arm/Makefile.am
+++ b/cpukit/score/cpu/arm/Makefile.am
@@ -18,9 +18,11 @@ libscorecpu_a_SOURCES += arm_exc_abort.S
 libscorecpu_a_SOURCES += arm_exc_interrupt.S
 libscorecpu_a_SOURCES += arm_exc_handler_low.S
 libscorecpu_a_SOURCES += arm_exc_handler_high.c
+libscorecpu_a_SOURCES += arm-exception-frame-print.c
 libscorecpu_a_SOURCES += armv7m-context-initialize.c
 libscorecpu_a_SOURCES += armv7m-context-restore.c
 libscorecpu_a_SOURCES += armv7m-context-switch.c
+libscorecpu_a_SOURCES += armv7m-exception-frame-print.c
 libscorecpu_a_SOURCES += armv7m-exception-handler-get.c
 libscorecpu_a_SOURCES += armv7m-exception-handler-set.c
 libscorecpu_a_SOURCES += armv7m-exception-priority-get.c
diff --git a/cpukit/score/cpu/arm/arm-exception-frame-print.c b/cpukit/score/cpu/arm/arm-exception-frame-print.c
new file mode 100644
index 0000000..4d89f69
--- /dev/null
+++ b/cpukit/score/cpu/arm/arm-exception-frame-print.c
@@ -0,0 +1,28 @@
+ * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Obere Lagerstr. 30
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/score/cpu.h>
+#ifdef ARM_MULTILIB_ARCH_V4
+void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
+  /* TODO */
+#endif /* ARM_MULTILIB_ARCH_V4 */
diff --git a/cpukit/score/cpu/arm/armv7m-exception-frame-print.c b/cpukit/score/cpu/arm/armv7m-exception-frame-print.c
index 0000000..86931b2
--- /dev/null
+++ b/cpukit/score/cpu/arm/armv7m-exception-frame-print.c
@@ -0,0 +1,28 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+#ifdef ARM_MULTILIB_ARCH_V7M
+  /* TODO */
+#endif /* ARM_MULTILIB_ARCH_V7M */
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index 1528533..e69f803 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -582,8 +582,13 @@ typedef CPU_Exception_frame CPU_Interrupt_frame;
 typedef void CPU_Interrupt_frame;
+/* FIXME */
+typedef CPU_Interrupt_frame CPU_Exception_frame;
 #endif /* !defined(ARM_MULTILIB_ARCH_V4) */
+void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/cpu/avr/Makefile.am b/cpukit/score/cpu/avr/Makefile.am
index 4079b69..efaf36e 100644
--- a/cpukit/score/cpu/avr/Makefile.am
+++ b/cpukit/score/cpu/avr/Makefile.am
@@ -161,6 +161,7 @@ include_rtems_avr_HEADERS += avr/wdt.h
 noinst_LIBRARIES = libscorecpu.a
 libscorecpu_a_SOURCES = cpu.c cpu_asm.S
+libscorecpu_a_SOURCES += avr-exception-frame-print.c
 libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
 include $(srcdir)/preinstall.am
diff --git a/cpukit/score/cpu/avr/avr-exception-frame-print.c b/cpukit/score/cpu/avr/avr-exception-frame-print.c
index 0000000..5ae4979
--- /dev/null
+++ b/cpukit/score/cpu/avr/avr-exception-frame-print.c
@@ -0,0 +1,24 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+  /* TODO */
diff --git a/cpukit/score/cpu/avr/rtems/score/cpu.h b/cpukit/score/cpu/avr/rtems/score/cpu.h
index 5436c21..2bfcbce 100644
--- a/cpukit/score/cpu/avr/rtems/score/cpu.h
+++ b/cpukit/score/cpu/avr/rtems/score/cpu.h
@@ -1112,6 +1112,11 @@ void _CPU_Context_restore_fp(
   Context_Control_fp **fp_context_ptr
+/* FIXME */
 /*  The following routine swaps the endian format of an unsigned int.
  *  It must be static because it is referenced indirectly.
diff --git a/cpukit/score/cpu/bfin/Makefile.am b/cpukit/score/cpu/bfin/Makefile.am
index dfec9ea..c8a7cf7 100644
--- a/cpukit/score/cpu/bfin/Makefile.am
+++ b/cpukit/score/cpu/bfin/Makefile.am
@@ -16,6 +16,7 @@ include_rtems_score_HEADERS += rtems/score/types.h
+libscorecpu_a_SOURCES += bfin-exception-frame-print.c
diff --git a/cpukit/score/cpu/bfin/bfin-exception-frame-print.c b/cpukit/score/cpu/bfin/bfin-exception-frame-print.c
--- /dev/null
+++ b/cpukit/score/cpu/bfin/bfin-exception-frame-print.c
@@ -0,0 +1,24 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+  /* TODO */
diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
index a8cfc17..85d5cd8 100644
--- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
@@ -1204,6 +1204,11 @@ void _CPU_Context_restore_fp(
+/* FIXME */
  *  @ingroup CPUEndian
diff --git a/cpukit/score/cpu/h8300/Makefile.am b/cpukit/score/cpu/h8300/Makefile.am
index 8ac7e76..5a3a8cc 100644
--- a/cpukit/score/cpu/h8300/Makefile.am
+++ b/cpukit/score/cpu/h8300/Makefile.am
@@ -10,6 +10,7 @@ include_rtems_score_HEADERS += rtems/score/types.h
+libscorecpu_a_SOURCES += h8300-exception-frame-print.c
diff --git a/cpukit/score/cpu/h8300/h8300-exception-frame-print.c b/cpukit/score/cpu/h8300/h8300-exception-frame-print.c
--- /dev/null
+++ b/cpukit/score/cpu/h8300/h8300-exception-frame-print.c
@@ -0,0 +1,24 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+  /* TODO */
diff --git a/cpukit/score/cpu/h8300/rtems/score/cpu.h b/cpukit/score/cpu/h8300/rtems/score/cpu.h
index 1811ce7..f8f41a8 100644
--- a/cpukit/score/cpu/h8300/rtems/score/cpu.h
+++ b/cpukit/score/cpu/h8300/rtems/score/cpu.h
@@ -1095,6 +1095,11 @@ void _CPU_Context_restore_fp(
+/* FIXME */
diff --git a/cpukit/score/cpu/i386/cpu.c b/cpukit/score/cpu/i386/cpu.c
index acd2768..15ff3c7 100644
--- a/cpukit/score/cpu/i386/cpu.c
+++ b/cpukit/score/cpu/i386/cpu.c
@@ -117,7 +117,7 @@ struct Frame_ {
 	uintptr_t		pc;
-static void _defaultExcHandler (CPU_Exception_frame *ctx)
+void _CPU_Exception_frame_print (const CPU_Exception_frame *ctx)
   unsigned int faultAddr = 0;
   printk("----------------------------------------------------------\n");
@@ -148,7 +148,6 @@ static void _defaultExcHandler (CPU_Exception_frame *ctx)
      * because the eip points to the faulty instruction so...
     printk("Exception while executing ISR!!!. System locked\n");
-    _CPU_Fatal_halt(faultAddr);
   else {
   	struct Frame_ *fp = (struct Frame_*)ctx->ebp;
@@ -171,10 +170,17 @@ static void _defaultExcHandler (CPU_Exception_frame *ctx)
     printk(" ************ FAULTY THREAD WILL BE SUSPENDED **************\n");
     rtems_task_suspend(_Thread_Executing->Object.id);
 #endif
-    bsp_reset();
+static void _defaultExcHandler (CPU_Exception_frame *ctx)
+  rtems_fatal(
+    (rtems_fatal_code) ctx
 cpuExcHandlerType _currentExcHandler = _defaultExcHandler;
 extern void rtems_exception_prologue_0(void);
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index 2a48711..03d6209 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -665,6 +665,8 @@ void _CPU_Context_restore_fp(
   } while (0)
 #endif
 #endif /* ASM */
 #ifdef __cplusplus
diff --git a/cpukit/score/cpu/lm32/Makefile.am b/cpukit/score/cpu/lm32/Makefile.am
index d3b49bf..c03e11c 100644
--- a/cpukit/score/cpu/lm32/Makefile.am
+++ b/cpukit/score/cpu/lm32/Makefile.am
@@ -11,6 +11,7 @@ include_rtems_score_HEADERS += rtems/score/types.h
 libscorecpu_a_SOURCES = cpu.c cpu_asm.S irq.c
+libscorecpu_a_SOURCES += lm32-exception-frame-print.c
diff --git a/cpukit/score/cpu/lm32/lm32-exception-frame-print.c b/cpukit/score/cpu/lm32/lm32-exception-frame-print.c
--- /dev/null
+++ b/cpukit/score/cpu/lm32/lm32-exception-frame-print.c
@@ -0,0 +1,24 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+  /* TODO */
diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
index 9f0876a..7f10a53 100644
--- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
@@ -1195,6 +1195,11 @@ void _CPU_Context_restore_fp(
+/* FIXME */
diff --git a/cpukit/score/cpu/m32c/Makefile.am b/cpukit/score/cpu/m32c/Makefile.am
index f836c58..4d63dfd 100644
--- a/cpukit/score/cpu/m32c/Makefile.am
+++ b/cpukit/score/cpu/m32c/Makefile.am
@@ -14,6 +14,7 @@ include_rtems_score_HEADERS += rtems/score/types.h
 libscorecpu_a_SOURCES = cpu.c cpu_asm.c context_switch.S context_init.c \
     varvects.S
+libscorecpu_a_SOURCES += m32c-exception-frame-print.c
diff --git a/cpukit/score/cpu/m32c/m32c-exception-frame-print.c b/cpukit/score/cpu/m32c/m32c-exception-frame-print.c
--- /dev/null
+++ b/cpukit/score/cpu/m32c/m32c-exception-frame-print.c
@@ -0,0 +1,24 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+  /* TODO */
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index d83e93d..10cdc5b 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -1131,6 +1131,11 @@ void _CPU_Context_restore(
   Context_Control *new_context
 ) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
+/* FIXME */
diff --git a/cpukit/score/cpu/m32r/Makefile.am b/cpukit/score/cpu/m32r/Makefile.am
index 37b49ed..9db2c89 100644
--- a/cpukit/score/cpu/m32r/Makefile.am
+++ b/cpukit/score/cpu/m32r/Makefile.am
@@ -13,6 +13,7 @@ include_rtems_score_HEADERS += rtems/score/types.h
+libscorecpu_a_SOURCES += m32r-exception-frame-print.c
diff --git a/cpukit/score/cpu/m32r/m32r-exception-frame-print.c b/cpukit/score/cpu/m32r/m32r-exception-frame-print.c
--- /dev/null
+++ b/cpukit/score/cpu/m32r/m32r-exception-frame-print.c
@@ -0,0 +1,24 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+  /* TODO */
diff --git a/cpukit/score/cpu/m32r/rtems/score/cpu.h b/cpukit/score/cpu/m32r/rtems/score/cpu.h
index 02bc928..df5b196 100644
--- a/cpukit/score/cpu/m32r/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32r/rtems/score/cpu.h
@@ -1189,6 +1189,11 @@ void _CPU_Context_restore_fp(
+/* FIXME */
diff --git a/cpukit/score/cpu/m68k/Makefile.am b/cpukit/score/cpu/m68k/Makefile.am
index 319cbdd..5669177 100644
--- a/cpukit/score/cpu/m68k/Makefile.am
+++ b/cpukit/score/cpu/m68k/Makefile.am
@@ -18,6 +18,7 @@ include_rtems_score_HEADERS += rtems/score/m68k.h
+libscorecpu_a_SOURCES += m68k-exception-frame-print.c
 include $(top_srcdir)/automake/local.am
diff --git a/cpukit/score/cpu/m68k/m68k-exception-frame-print.c b/cpukit/score/cpu/m68k/m68k-exception-frame-print.c
--- /dev/null
+++ b/cpukit/score/cpu/m68k/m68k-exception-frame-print.c
@@ -0,0 +1,24 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+  /* TODO */
diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
index 89b0295..fb970eb 100644
--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
@@ -709,6 +709,8 @@ void _CPU_Context_restore_fp(
 #if (M68K_HAS_FPSP_PACKAGE == 1)
  *  Hooks for the Floating Point Support Package (FPSP) provided by Motorola
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index 9aa72d4..1da23db 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -609,6 +609,8 @@ typedef struct
 } CPU_Interrupt_frame;
  *  This variable is optional.  It is used on CPUs on which it is difficult
  *  to generate an "uninitialized" FP context.  It is filled in by
@@ -703,6 +705,8 @@ extern unsigned int mips_interrupt_number_of_vectors;
 #define CPU_STACK_ALIGNMENT        CPU_ALIGNMENT
+void mips_vector_exceptions( CPU_Interrupt_frame *frame );
  *  ISR handler macros
@@ -1112,6 +1116,15 @@ void _CPU_Context_restore_fp(
+void _BSP_Exception_frame_print( const CPU_Exception_frame *frame );
+static inline void _CPU_Exception_frame_print(
+  const CPU_Exception_frame *frame
+  _BSP_Exception_frame_print( frame );
diff --git a/cpukit/score/cpu/nios2/Makefile.am b/cpukit/score/cpu/nios2/Makefile.am
index f662946..c2947dd 100644
--- a/cpukit/score/cpu/nios2/Makefile.am
+++ b/cpukit/score/cpu/nios2/Makefile.am
@@ -24,6 +24,7 @@ libscorecpu_a_SOURCES += nios2-context-initialize.c
 libscorecpu_a_SOURCES += nios2-context-switch.S
 libscorecpu_a_SOURCES += nios2-eic-il-low-level.S
 libscorecpu_a_SOURCES += nios2-eic-rsie-low-level.S
+libscorecpu_a_SOURCES += nios2-exception-frame-print.c
 libscorecpu_a_SOURCES += nios2-fatal-halt.c
 libscorecpu_a_SOURCES += nios2-iic-low-level.S
 libscorecpu_a_SOURCES += nios2-initialize.c
diff --git a/cpukit/score/cpu/nios2/nios2-exception-frame-print.c b/cpukit/score/cpu/nios2/nios2-exception-frame-print.c
--- /dev/null
+++ b/cpukit/score/cpu/nios2/nios2-exception-frame-print.c
@@ -0,0 +1,24 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+  /* TODO */
diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h b/cpukit/score/cpu/nios2/rtems/score/cpu.h
index 4d61c42..68ab01d 100644
--- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
@@ -338,6 +338,8 @@ void _CPU_Context_restore(
 static inline uint32_t CPU_swap_u32( uint32_t value )
   uint32_t byte1, byte2, byte3, byte4, swapped;
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index 9ab1f26..fe63aea 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -1264,6 +1264,28 @@ void _CPU_Context_restore_fp(
+ *  @brief The set of registers that specifies the complete processor state.
+ *  The CPU exception frame may be available in fatal error conditions like for
+ *  example illegal opcodes, instruction fetch errors, or data access errors.
+ *  @see rtems_fatal(), RTEMS_FATAL_SOURCE_EXCEPTION, and
+ *  rtems_exception_frame_print().
+typedef struct {
+  uint32_t processor_state_register;
+  uint32_t integer_registers [1];
+  double float_registers [1];
+} CPU_Exception_frame;
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 290f0db..e776f3c 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -1036,6 +1036,15 @@ typedef struct {
   PPC_GPR_TYPE GPR31;
  * _CPU_Initialize_altivec()
diff --git a/cpukit/score/cpu/sh/Makefile.am b/cpukit/score/cpu/sh/Makefile.am
index 8e148d8..a524dfc 100644
--- a/cpukit/score/cpu/sh/Makefile.am
+++ b/cpukit/score/cpu/sh/Makefile.am
@@ -11,6 +11,7 @@ include_rtems_score_HEADERS += rtems/score/sh_io.h
 libscorecpu_a_SOURCES = cpu.c context.c
+libscorecpu_a_SOURCES += sh-exception-frame-print.c
diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
index 789024e..9a61b5e 100644
--- a/cpukit/score/cpu/sh/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
@@ -885,6 +885,10 @@ void _CPU_Context_restore_fp(
+/* FIXME */
 #ifdef __cplusplus
diff --git a/cpukit/score/cpu/sh/sh-exception-frame-print.c b/cpukit/score/cpu/sh/sh-exception-frame-print.c
--- /dev/null
+++ b/cpukit/score/cpu/sh/sh-exception-frame-print.c
@@ -0,0 +1,24 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+  /* TODO */
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index d92b63c..2e1e718 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -1221,6 +1221,20 @@ void _CPU_Context_restore_fp(
+typedef struct {
+  uint32_t trap;
+  CPU_Interrupt_frame *isf;
  *  @brief SPARC Specific Method to Endian Swap an uint32_t
diff --git a/cpukit/score/cpu/sparc64/Makefile.am b/cpukit/score/cpu/sparc64/Makefile.am
index 33ba844..2897a46 100644
--- a/cpukit/score/cpu/sparc64/Makefile.am
+++ b/cpukit/score/cpu/sparc64/Makefile.am
 libscorecpu_a_SOURCES = context.S cpu.c
+libscorecpu_a_SOURCES += sparc64-exception-frame-print.c
diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
index f821e96..f78400f 100644
--- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
@@ -1024,6 +1024,11 @@ void _CPU_Context_restore_fp(
+/* FIXME */
  *  CPU_swap_u32
diff --git a/cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c b/cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c
--- /dev/null
+++ b/cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c
@@ -0,0 +1,24 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+  /* TODO */
diff --git a/cpukit/score/cpu/v850/Makefile.am b/cpukit/score/cpu/v850/Makefile.am
index 2119f62..6f1ce67 100644
--- a/cpukit/score/cpu/v850/Makefile.am
+++ b/cpukit/score/cpu/v850/Makefile.am
@@ -11,6 +11,7 @@ include_rtems_score_HEADERS += rtems/score/cpu_asm.h rtems/score/types.h
 libscorecpu_a_SOURCES += cpu_asm.S
+libscorecpu_a_SOURCES += v850-exception-frame-print.c
diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
index 371bc32..d77344b 100644
--- a/cpukit/score/cpu/v850/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
@@ -1124,6 +1124,11 @@ void _CPU_Context_restore_fp(
 #endif
+/* FIXME */
diff --git a/cpukit/score/cpu/v850/v850-exception-frame-print.c b/cpukit/score/cpu/v850/v850-exception-frame-print.c
--- /dev/null
+++ b/cpukit/score/cpu/v850/v850-exception-frame-print.c
@@ -0,0 +1,24 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+  /* TODO */
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 367c1ab..e325e68 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -98,13 +98,13 @@ typedef enum {
   RTEMS_FATAL_SOURCE_STACK_CHECKER,
-   * @brief Fatal source of the PowerPC exceptions.
+   * @brief Fatal source of the exceptions.
    * The fatal code is the pointer value of the exception frame pointer.
-   * @see BSP_Exception_frame.
+   * @see rtems_exception_frame and rtems_exception_frame_print().
    * @brief The last available fatal source.
diff --git a/doc/user/fatal.t b/doc/user/fatal.t
index 42a2432..1b725e8 100644
--- a/doc/user/fatal.t
+++ b/doc/user/fatal.t
@@ -203,6 +203,33 @@ false.  See also @code{@value{DIRPREFIX}fatal_error_occurred}.
 @c
 @c
 @page
+ at subsection EXCEPTION_FRAME_PRINT - Prints the exception frame
+ at cindex exception frame
+ at subheading CALLING SEQUENCE:
+ at ifset is-C
+ at findex rtems_exception_frame_print
+ at example
+void rtems_exception_frame_print(
+ at end example
+ at end ifset
+ at subheading DIRECTIVE STATUS CODES
+NONE
+ at subheading DESCRIPTION:
+Prints the exception frame via printk().
+ at c
+ at c
+ at c
+ at page
 @subsection INTERNAL_ERROR_DESCRIPTION - Returns a description for an internal error code
 @cindex fatal error
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 1e183eb..c00d73c 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -28,6 +28,7 @@ SUBDIRS = \
     spsimplesched01 spsimplesched02 spsimplesched03 spnsext01 \
     spedfsched01 spedfsched02 spedfsched03 \
     spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01
+SUBDIRS += spfatal26
 SUBDIRS += speventtransient01
 SUBDIRS += speventsystem01
 SUBDIRS += spinternalerror01
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index a71746f..6d899a3 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -27,6 +27,7 @@ AC_CHECK_SIZEOF([time_t])
+spfatal26/Makefile
 spinternalerror02/Makefile
 spinternalerror01/Makefile
 speventsystem01/Makefile
diff --git a/testsuites/sptests/spfatal26/Makefile.am b/testsuites/sptests/spfatal26/Makefile.am
index 0000000..9cc5dba
--- /dev/null
+++ b/testsuites/sptests/spfatal26/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spfatal26
+spfatal26_SOURCES = init.c
+dist_rtems_tests_DATA = spfatal26.scn spfatal26.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spfatal26_OBJECTS)
+LINK_LIBS = $(spfatal26_LDLIBS)
+spfatal26$(EXEEXT): $(spfatal26_OBJECTS) $(spfatal26_DEPENDENCIES)
+	@rm -f spfatal26$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spfatal26/init.c b/testsuites/sptests/spfatal26/init.c
index 0000000..556410f
--- /dev/null
+++ b/testsuites/sptests/spfatal26/init.c
@@ -0,0 +1,85 @@
+ *  82178 Puchheim
+ *  Germany
+#endif
+#include "tmacros.h"
+#include <limits.h>
+#include <rtems.h>
+static void provoke_aligment_or_data_access_exception( void )
+  uintptr_t one = 1;
+  int i = sizeof(void *) * CHAR_BIT;
+  uintptr_t n = 1;
+  uintptr_t base = 0;
+  uintptr_t inc;
+  *(volatile uint64_t *) base;
+  do {
+    int j;
+    --i;
+    base = one << i;
+    inc = base << 1;
+    for (j = 0; j < n; ++j, base += inc) {
+    n <<= 1;
+  } while (i > 0);
+static void Init( rtems_task_argument arg )
+  printk( "\n\n*** TEST SPFATAL 26 ***\n" );
+  provoke_aligment_or_data_access_exception();
+  rtems_test_assert( 0 );
+static void fatal_extension(
+  rtems_fatal_source source,
+  bool is_internal,
+  rtems_test_assert( source == RTEMS_FATAL_SOURCE_EXCEPTION );
+  rtems_test_assert( !is_internal );
+  printk( "*** END OF TEST SPFATAL 26 ***\n" );
+#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = fatal_extension }
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spfatal26/spfatal26.doc b/testsuites/sptests/spfatal26/spfatal26.doc
index 0000000..fb9097c
--- /dev/null
+++ b/testsuites/sptests/spfatal26/spfatal26.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spfatal26
+directives:
+  - rtems_exception_frame_print
+concepts:
+  - Ensure that we get an fatal condition with RTEMS_FATAL_SOURCE_EXCEPTION.
diff --git a/testsuites/sptests/spfatal26/spfatal26.scn b/testsuites/sptests/spfatal26/spfatal26.scn
index 0000000..0dfa62a
--- /dev/null
+++ b/testsuites/sptests/spfatal26/spfatal26.scn
@@ -0,0 +1,2 @@
+*** TEST SPFATAL 26 ***
+*** END OF TEST SPFATAL 26 ***
1.7.7
