[PATCH 15/15] Provide ChangeLog and README files
Ric Claus claus at slac.stanford.edu
Tue Nov 27 03:26:53 UTC 2012
 c/src/lib/libbsp/powerpc/virtex4/ChangeLog |   14 +++++
 c/src/lib/libbsp/powerpc/virtex4/README    |   86 ++++++++++++++++++++++++++++
 c/src/lib/libbsp/powerpc/virtex5/ChangeLog |   15 +++++
 c/src/lib/libbsp/powerpc/virtex5/README    |   86 ++++++++++++++++++++++++++++
 4 files changed, 201 insertions(+), 0 deletions(-)
 create mode 100644 c/src/lib/libbsp/powerpc/virtex4/ChangeLog
 create mode 100644 c/src/lib/libbsp/powerpc/virtex4/README
 create mode 100644 c/src/lib/libbsp/powerpc/virtex5/ChangeLog
 create mode 100644 c/src/lib/libbsp/powerpc/virtex5/README
diff --git a/c/src/lib/libbsp/powerpc/virtex4/ChangeLog b/c/src/lib/libbsp/powerpc/virtex4/ChangeLog
new file mode 100644
index 0000000..97e3ee2
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/virtex4/ChangeLog
@@ -0,0 +1,14 @@
+2012-10-18 Sergio Maldonado <smaldona at slac.stanford.edu>
+   * Changelog, Makefile.am, libc:
+            Added libc/memcpy.c, optimized memcpy to replace libc memcpy.
+            Added libc/fastcopy.S, optimized block copy.
+2012-05-25	Ric Claus <claus at slac.stanford.edu>
+	* Changelog, Makefile.am, mmu, bspstart.c, linkcmds, start.S:
+	        Added mmu, based vector table at 0x100, fixed bugs.
+2011-03-04	Ric Claus <claus at slac.stanford.edu>
+	* ChangeLog, virtex4.cfg: added files.
diff --git a/c/src/lib/libbsp/powerpc/virtex4/README b/c/src/lib/libbsp/powerpc/virtex4/README
index 0000000..68a0c24
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/virtex4/README
@@ -0,0 +1,86 @@
+# Adapted from virtex BSP
+BSP NAME:           virtex4
+BOARD:              N/A
+BUS:                N/A
+CPU FAMILY:         ppc
+CPU:                PowerPC 405D5
+COPROCESSORS:       N/A
+MODE:               32 bit mode
+DEBUG MONITOR:
+PERIPHERALS
+TIMERS:             405 internal
+SERIAL PORTS:       none
+REAL-TIME CLOCK:    none
+DMA:                Xilinx virtex internal
+VIDEO:              none
+SCSI:               none
+NETWORKING:         none
+DRIVER INFORMATION
+CLOCK DRIVER:       PPC Decrementer
+IOSUPP DRIVER:      N/A
+SHMSUPP:            N/A
+TIMER DRIVER:       N/A
+TTY DRIVER:         N/A
+STDIO
+PORT:               N/A
+ELECTRICAL:         N/A
+BAUD:               N/A
+BITS PER CHARACTER: N/A
+PARITY:             N/A
+STOP BITS:          N/A
+Notes
+Board description
+clock rate:	350 MHz
+ROM:		N/A
+RAM:		128MByte DRAM
+Virtex only supports single processor operations.
+Porting
+This board support package is written for a naked Virtex 4/PPC FPGA
+system. The rough features of such a board are described above.
+The BSP itself makes no assumptions on what is loaded in the FPGA,
+other than that the CPU has access to some memory, either on-board
+or external, from which code can be run.
+This BSP has been constructed so that an application of both firmware
+and software can be layered on top of it by supplying implementations
+for the various 'weak' symbols.  These symbols are prefaced with the
+term 'app_'.  Applications can thus be built outside of the RTEMS
+directory tree by linking with the appropriate libraries.
+The linkcmds file describes the memory layout.  Included in this
+definition is a section of memory named MsgArea.  Output sent to
+stdout is recorded in this area and can be dumped using the JTAG
+interface, for example.
+For adapting this BSP to other boards, the following files should be
+modified:
+- c/src/lib/libbsp/powerpc/virtex4/startup/linkcmds
+	for the memory layout required
+- c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c
+	Here you can select the clock source for the timers and the
+        serial interface (system clock or external clock pin), the
+        clock rates, etc.
+- c/src/lib/libbsp/powerpc/virtex4/include/bsp.h
+	some BSP-related constants
+- c/src/lib/libbsp/powerpc/virtex4/*
+	well, they should be generic, so there _should_ be no reason
+	to mess around there (but who knows...)
diff --git a/c/src/lib/libbsp/powerpc/virtex5/ChangeLog b/c/src/lib/libbsp/powerpc/virtex5/ChangeLog
index 0000000..8b106a2
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/virtex5/ChangeLog
@@ -0,0 +1,15 @@
+            Enabled GDCBT and GICBT ccr0 bits in start.S.
+	* ChangeLog, virtex5.cfg: added files.
diff --git a/c/src/lib/libbsp/powerpc/virtex5/README b/c/src/lib/libbsp/powerpc/virtex5/README
index 0000000..a68bd23
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/virtex5/README
@@ -0,0 +1,86 @@
+BSP NAME:           virtex5
+BOARD:              N/A
+BUS:                N/A
+CPU FAMILY:         ppc
+CPU:                PowerPC 440x5
+COPROCESSORS:       N/A
+MODE:               32 bit mode
+DEBUG MONITOR:
+PERIPHERALS
+TIMERS:             440 internal
+SERIAL PORTS:       none
+VIDEO:              none
+SCSI:               none
+NETWORKING:         none
+DRIVER INFORMATION
+IOSUPP DRIVER:      N/A
+SHMSUPP:            N/A
+TIMER DRIVER:       N/A
+TTY DRIVER:         N/A
+STDIO
+PORT:               N/A
+ELECTRICAL:         N/A
+BAUD:               N/A
+PARITY:             N/A
+STOP BITS:          N/A
+Notes
+Board description
+clock rate:	465 MHz
+ROM:		N/A
+RAM:		4GByte DRAM
+Porting
+This board support package is written for a naked Virtex 5/PPC FPGA
+modified:
+- c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds
+- c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
+        clock rates, etc.
+- c/src/lib/libbsp/powerpc/virtex5/include/bsp.h
+- c/src/lib/libbsp/powerpc/virtex5/*
1.7.1
