[PATCH 1/8] libblock: Add sparse disk
Ralf Kirchner
ralf.kirchner at embedded-brains.de
Thu Nov 29 14:32:39 UTC 2012
cpukit/Makefile.am | 1 +
cpukit/libblock/Makefile.am | 1 +
cpukit/libblock/include/rtems/sparse-disk.h | 139 +++++++
cpukit/libblock/src/sparse-disk.c | 372 +++++++++++++++++
cpukit/preinstall.am | 4 +
testsuites/libtests/Makefile.am | 1 +
testsuites/libtests/configure.ac | 1 +
testsuites/libtests/sparsedisk01/Makefile.am | 19 +
testsuites/libtests/sparsedisk01/init.c | 439 +++++++++++++++++++++
testsuites/libtests/sparsedisk01/sparsedisk01.doc | 11 +
10 Dateien geändert, 988 Zeilen hinzugefügt(+)
create mode 100644 cpukit/libblock/include/rtems/sparse-disk.h
create mode 100644 cpukit/libblock/src/sparse-disk.c
create mode 100644 testsuites/libtests/sparsedisk01/Makefile.am
create mode 100644 testsuites/libtests/sparsedisk01/init.c
create mode 100644 testsuites/libtests/sparsedisk01/sparsedisk01.doc
create mode 100644 testsuites/libtests/sparsedisk01/sparsedisk01.scn
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index b5569fa..5b11e7e 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -124,6 +124,7 @@ include_rtems_HEADERS += libblock/include/rtems/flashdisk.h
include_rtems_HEADERS += libblock/include/rtems/ramdisk.h
include_rtems_HEADERS += libblock/include/rtems/nvdisk.h
include_rtems_HEADERS += libblock/include/rtems/nvdisk-sram.h
+include_rtems_HEADERS += libblock/include/rtems/sparse-disk.h
include_rtems_HEADERS += libblock/include/rtems/ide_part_table.h
include_rtems_HEADERS += libblock/include/rtems/bdpart.h
include_rtems_HEADERS += libblock/include/rtems/media.h
diff --git a/cpukit/libblock/Makefile.am b/cpukit/libblock/Makefile.am
index d07eb5e..0f720f2 100644
--- a/cpukit/libblock/Makefile.am
+++ b/cpukit/libblock/Makefile.am
@@ -31,6 +31,7 @@ libblock_a_SOURCES = src/bdbuf.c \
src/media-server.c \
src/media-desc.c \
src/media-dev-ident.c \
+ src/sparse-disk.c \
include/rtems/bdbuf.h include/rtems/blkdev.h \
include/rtems/diskdevs.h include/rtems/flashdisk.h \
include/rtems/ramdisk.h include/rtems/nvdisk.h include/rtems/nvdisk-sram.h \
diff --git a/cpukit/libblock/include/rtems/sparse-disk.h b/cpukit/libblock/include/rtems/sparse-disk.h
new file mode 100644
index 0000000..54e3fe9
--- /dev/null
+++ b/cpukit/libblock/include/rtems/sparse-disk.h
@@ -0,0 +1,139 @@
+ * @file
+ * @ingroup rtems_sparse_disk
+ * @brief Sparse disk block device API.
+ * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Obere Lagerstr. 30
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifndef SPARSE_DISK_H
+#define SPARSE_DISK_H
+#include <stddef.h>
+#include <stdint.h>
+#include <rtems.h>
+#include <rtems/diskdevs.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup rtems_sparse_disk Sparse Disk Device
+ * @ingroup rtems_blkdev
+typedef struct {
+ rtems_blkdev_bnum block;
+ void *data;
+} rtems_sparse_disk_key;
+typedef struct rtems_sparse_disk *sparse_disk_ptr;
+typedef struct {
+ rtems_id mutex;
+ rtems_blkdev_bnum blocks_allocated;
+ size_t used_count;
+ uint32_t block_size;
+ void *delete_hdlr;
+ uint8_t fill_pattern;
+ rtems_sparse_disk_key *key_table;
+} rtems_sparse_disk;
+typedef void (*rtems_sparse_disk_delete_hdlr)(rtems_sparse_disk *sparse_disk);
+ * @brief Allocates a sparse disk.
+ * The block size will be @a block_size.
+ * The disk storage will be allocated. The number of actually
+ * allocated blocks will be @a blocks_allocated.
+ * The disk will get allocated to the address pointed to by
+ * @a sparse_disk
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_NUMBER Block size or block count is not positive.
+ * @retval RTEMS_INVALID_ADDRESS Invalid sparse disk address.
+ * @retval RTEMS_NO_MEMORY Not enough memory.
+rtems_status_code rtems_sparse_disk_create(
+ uint32_t block_size,
+ rtems_blkdev_bnum blocks_allocated,
+ rtems_sparse_disk **sparse_disk
+ * @brief Deallocates a sparse disk.
+ * A disk created with rtems_sparse_disk_create() and pointed to
+ * by @a sparse_disk will get deallocated
+void rtems_sparse_disk_delete(
+ rtems_sparse_disk *sparse_disk
+ * @brief Initializes and registers a sparse disk.
+ * Registers a device node with disk name path @a device_file_name.
+ * Initialization and registration will be done with the structure
+ * pointed to by @a sparse_disk.
+ * The block size will be @a block_size. The block count will be
+ * @a block_count. The number of actually allocated blocks will
+ * be @a blocks_allocated.
+ * The data in the allocated blocks will get initialized with @a fill_pattern.
+ * @a sparse_disk_delete is a pointer to a method to be called
+ * for deleting the sparse disk. If the sparse disk was allocated
+ * with method rtems_sparse_disk_create() you can pass rtems_sparse_disk_delete().
+ * Alternatively you can pass your own delete method.
+ * @retval RTEMS_TOO_MANY Can not create semaphore
+ * @retval RTEMS_UNSATISFIED Cannot create generic device node.
+rtems_status_code rtems_sparse_disk_register(
+ const char *device_file_name,
+ rtems_sparse_disk *sparse_disk,
+ rtems_blkdev_bnum block_count,
+ rtems_sparse_disk_delete_hdlr sparse_disk_delete,
+#ifdef __cplusplus
+#endif /* SPARSE_DISK_H */
diff --git a/cpukit/libblock/src/sparse-disk.c b/cpukit/libblock/src/sparse-disk.c
index 0000000..f6038e9
--- /dev/null
+++ b/cpukit/libblock/src/sparse-disk.c
@@ -0,0 +1,372 @@
+ * @file
+ * @brief Sparse disk block device implementation.
+ * 82178 Puchheim
+ * Germany
+#include <stdlib.h>
+#include <errno.h>
+#include <string.h>
+#include <rtems.h>
+#include <rtems/blkdev.h>
+#include <rtems/fatal.h>
+#include "rtems/sparse-disk.h"
+ * Allocate RAM for sparse disk
+static rtems_sparse_disk*
+ sparse_disk_allocate(
+ const uint32_t block_size,
+ const rtems_blkdev_bnum blocks_allocated
+ size_t const key_table_size = blocks_allocated * sizeof(rtems_sparse_disk_key);
+ size_t const data_size = blocks_allocated * block_size;
+ size_t const alloc_size = sizeof(rtems_sparse_disk) + key_table_size + data_size;
+ uint8_t* data = malloc(alloc_size);
+ rtems_sparse_disk *const sd = (rtems_sparse_disk *) data;
+ if (data == NULL) {
+ return NULL;
+ return sd;
+ * Initialize sparse disk data
+static rtems_status_code
+ sparse_disk_initialize (rtems_sparse_disk* sd,
+ const rtems_blkdev_bnum blocks_allocated,
+ const rtems_sparse_disk_delete_hdlr sparse_disk_delete,
+ const uint8_t fill_pattern)
+ rtems_status_code sc;
+ size_t i;
+ if (NULL == sd)
+ return RTEMS_INVALID_ADDRESS;
+ uint8_t *data = (uint8_t *) sd;
+ memset(data, 0, sizeof(rtems_sparse_disk) + key_table_size);
+ sd->fill_pattern = fill_pattern;
+ memset((uint8_t*)(data + sizeof(rtems_sparse_disk) + key_table_size), sd->fill_pattern, data_size);
+ sd->delete_hdlr = sparse_disk_delete;
+ sc = rtems_semaphore_create(
+ rtems_build_name('S', 'P', 'A', 'R'),
+ 1,
+ RTEMS_PRIORITY | RTEMS_BINARY_SEMAPHORE | RTEMS_INHERIT_PRIORITY,
+ 0,
+ &sd->mutex
+ if (sc != RTEMS_SUCCESSFUL) {
+ return sc;
+ data += sizeof(rtems_sparse_disk);
+ sd->blocks_allocated = blocks_allocated;
+ sd->key_table = (rtems_sparse_disk_key *) data;
+ data += key_table_size;
+ for (i = 0; i < blocks_allocated; ++i, data += block_size) {
+ sd->key_table [i].data = data;
+ sd->block_size = block_size;
+ return RTEMS_SUCCESSFUL;
+ * Block comparison
+static int
+ sparse_disk_compare(const void *aa, const void *bb)
+ const rtems_sparse_disk_key *a = aa;
+ const rtems_sparse_disk_key *b = bb;
+ if (a->block < b->block) {
+ return -1;
+ } else if (a->block == b->block) {
+ return 0;
+ } else {
+ return 1;
+static rtems_sparse_disk_key *
+ sparse_disk_get_new_block(
+ rtems_sparse_disk_key *key;
+ if (sparse_disk->used_count < sparse_disk->blocks_allocated) {
+ key = &sparse_disk->key_table [sparse_disk->used_count];
+ key->block = block;
+ ++sparse_disk->used_count;
+ qsort(sparse_disk->key_table, sparse_disk->used_count, sizeof(rtems_sparse_disk_key), sparse_disk_compare);
+ } else
+ return NULL;
+ return key;
+static int
+ sparse_disk_read_block(
+ const rtems_sparse_disk *sparse_disk,
+ const rtems_blkdev_bnum block,
+ uint8_t *buffer,
+ const size_t buffer_size
+ rtems_sparse_disk_key block_key = {
+ .block = block,
+ .data = NULL
+ size_t bytes_to_copy = sparse_disk->block_size;
+ if (buffer_size < bytes_to_copy)
+ bytes_to_copy = buffer_size;
+ key = bsearch(
+ &block_key,
+ sparse_disk->key_table,
+ sparse_disk->used_count,
+ sizeof(rtems_sparse_disk_key),
+ if (NULL != key)
+ memcpy (buffer, key->data, bytes_to_copy);
+ else
+ memset (buffer, sparse_disk->fill_pattern, buffer_size);
+ return bytes_to_copy;
+static int
+ sparse_disk_write_block(
+ const uint8_t *buffer,
+ unsigned int i;
+ bool block_needs_writing = false;
+ .block = block,
+ .data = NULL
+ /* we only need to write the block if it is different from the fill pattern.
+ * If the read method does not find a block it will deliver the fill pattern anyway.
+ key = bsearch(
+ &block_key,
+ if (NULL == key) {
+ for (i = 0; (! block_needs_writing) && (i < bytes_to_copy); ++i) {
+ if (buffer[i] != sparse_disk->fill_pattern)
+ block_needs_writing = true;
+ if (block_needs_writing) {
+ key = sparse_disk_get_new_block (sparse_disk, block);
+ if (NULL != key)
+ memcpy (key->data, buffer, bytes_to_copy);
+ else if (block_needs_writing)
+ return -1;
+ * Read/write handling
+static int
+ sparse_disk_read_write(
+ rtems_blkdev_request *req,
+ const bool read)
+ int rv = 0;
+ uint32_t req_buffer;
+ rtems_blkdev_sg_buffer *scatter_gather;
+ uint8_t *buff;
+ size_t buff_size;
+ unsigned int bytes_handled;
+ rtems_semaphore_obtain(sparse_disk->mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ for (req_buffer = 0; (0 <= rv) && (req_buffer < req->bufnum); ++req_buffer) {
+ scatter_gather = &req->bufs [req_buffer];
+ bytes_handled = 0;
+ buff = (uint8_t*)scatter_gather->buffer;
+ block = scatter_gather->block;
+ buff_size = scatter_gather->length;
+ while ((0 <= rv) && (0 < buff_size))
+ if (read)
+ rv = sparse_disk_read_block (sparse_disk, block, &buff[bytes_handled], buff_size);
+ else
+ rv = sparse_disk_write_block (sparse_disk, block, &buff[bytes_handled], buff_size);
+ ++block;
+ bytes_handled += rv;
+ buff_size -= rv;
+ rtems_semaphore_release(sparse_disk->mutex);
+ if (0 > rv)
+ rtems_blkdev_request_done (req, RTEMS_IO_ERROR);
+ else
+ rtems_blkdev_request_done (req, RTEMS_SUCCESSFUL);
+ return 0;
+ * ioctl handler to be passed to the block device handler
+static int
+ sparse_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
+ rtems_sparse_disk *sd = rtems_disk_get_driver_data(dd);
+ if (RTEMS_BLKIO_REQUEST == req) {
+ rtems_blkdev_request *r = argp;
+ switch (r->req) {
+ case RTEMS_BLKDEV_REQ_READ:
+ case RTEMS_BLKDEV_REQ_WRITE:
+ return sparse_disk_read_write(sd, r, r->req == RTEMS_BLKDEV_REQ_READ);
+ default:
+ break;
+ } else if (RTEMS_BLKIO_DELETED == req) {
+ sc = rtems_semaphore_delete(sd->mutex);
+ if (RTEMS_SUCCESSFUL != sc)
+ rtems_fatal_error_occurred(0xdeadbeef);
+ sd->mutex = RTEMS_ID_NONE;
+ if (NULL != sd->delete_hdlr)
+ ((rtems_sparse_disk_delete_hdlr)sd->delete_hdlr)(sd);
+ return 0;
+ }else {
+ return rtems_blkdev_ioctl(dd, req, argp);
+ errno = EINVAL;
+ return -1;
+ * De-allocate the sparse disk
+void
+ rtems_sparse_disk_delete(rtems_sparse_disk *sd)
+ if (NULL != sd)
+ free(sd);
+ *sparse_disk = sparse_disk_allocate(
+ block_size,
+ blocks_allocated
+ if (NULL == *sparse_disk)
+ return RTEMS_NO_MEMORY;
+ const rtems_blkdev_bnum block_count,
+ sc = sparse_disk_initialize(
+ sparse_disk,
+ block_size,
+ blocks_allocated,
+ sparse_disk_delete,
+ fill_pattern
+ if (RTEMS_SUCCESSFUL != sc) {
+ return sc;
+ sc = rtems_blkdev_create(
+ device_file_name,
+ block_size,
+ block_count,
+ sparse_disk_ioctl,
+ sparse_disk
+ return sc;
diff --git a/cpukit/preinstall.am b/cpukit/preinstall.am
index f6d24bb..26b90ec 100644
--- a/cpukit/preinstall.am
+++ b/cpukit/preinstall.am
@@ -272,6 +272,10 @@ $(PROJECT_INCLUDE)/rtems/nvdisk-sram.h: libblock/include/rtems/nvdisk-sram.h $(P
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/nvdisk-sram.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/nvdisk-sram.h
+$(PROJECT_INCLUDE)/rtems/sparse-disk.h: libblock/include/rtems/sparse-disk.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/sparse-disk.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/sparse-disk.h
$(PROJECT_INCLUDE)/rtems/ide_part_table.h: libblock/include/rtems/ide_part_table.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/ide_part_table.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/ide_part_table.h
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index afd8605..1197742 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -1,6 +1,7 @@
ACLOCAL_AMFLAGS = -I ../aclocal
SUBDIRS = POSIX
+SUBDIRS += sparsedisk01
SUBDIRS += block16
SUBDIRS += block15
SUBDIRS += block14
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 83e22ed..b8be927 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -43,6 +43,7 @@ AM_CONDITIONAL(HAS_POSIX,test x"${rtems_cv_RTEMS_POSIX_API}" = x"yes")
# Explicitly list all Makefiles here
AC_CONFIG_FILES([Makefile
+sparsedisk01/Makefile
block16/Makefile
mghttpd01/Makefile
block15/Makefile
diff --git a/testsuites/libtests/sparsedisk01/Makefile.am b/testsuites/libtests/sparsedisk01/Makefile.am
index 0000000..3a836c8
--- /dev/null
+++ b/testsuites/libtests/sparsedisk01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = sparsedisk01
+sparsedisk01_SOURCES = init.c
+dist_rtems_tests_DATA = sparsedisk01.scn sparsedisk01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(sparsedisk01_OBJECTS)
+LINK_LIBS = $(sparsedisk01_LDLIBS)
+sparsedisk01$(EXEEXT): $(sparsedisk01_OBJECTS) $(sparsedisk01_DEPENDENCIES)
+ @rm -f sparsedisk01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/libtests/sparsedisk01/init.c b/testsuites/libtests/sparsedisk01/init.c
index 0000000..a76738f
--- /dev/null
+++ b/testsuites/libtests/sparsedisk01/init.c
@@ -0,0 +1,439 @@
+ * 82178 Puchheim
+ * Germany
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <fcntl.h>
+#include "tmacros.h"
+/* Number of bytes for test pattern within a sparse disk container */
+#define STATIC_PATTERN_SIZE 4096
+/* Block size used for the sparse disk in a sparse disk container */
+#define STATIC_BLOCK_SIZE 4096
+/* Number of block allocated for the sparse disk in a sparse disk container */
+#define STATIC_ALLOCATED_BLOCK_COUNT 1
+/* Blocks simulated by the sparse disk in a disk container */
+#define STATIC_SIMULATED_BLOCK_COUNT 4096
+ * Container which cotains a sparse disk + memory for key table and data as would get
+ * allocated by rtems_sparse_disk_create() + memory for a memory test pattern
+ * By using this container white box testing of a sparse disk becomes possible
+typedef struct {
+ rtems_sparse_disk sparse_disk;
+ rtems_sparse_disk_key keytable[STATIC_ALLOCATED_BLOCK_COUNT];
+ uint8_t data[STATIC_BLOCK_SIZE * STATIC_ALLOCATED_BLOCK_COUNT];
+ uint8_t pattern[STATIC_PATTERN_SIZE];
+} sparse_disk_container;
+ * Black box test the disk parameters of a sparse disk
+static void
+ test_disk_params(
+ const int file_descriptor,
+ const uint32_t media_block_size,
+ const rtems_blkdev_bnum block_number
+ int rv;
+ uint32_t value = 0;
+ rtems_disk_device *fd_dd = NULL;
+ rtems_blkdev_bnum block_count = 0;
+ rv = rtems_disk_fd_get_media_block_size(file_descriptor, &value);
+ rtems_test_assert(0 == rv);
+ rtems_test_assert(media_block_size == value);
+ value = 0;
+ rv = rtems_disk_fd_get_block_size(file_descriptor, &value);
+ rtems_test_assert(block_size == value);
+ block_count = 0;
+ rv = rtems_disk_fd_get_block_count(file_descriptor, &block_count);
+ rtems_test_assert(block_number == block_count);
+ rv = rtems_disk_fd_get_disk_device(file_descriptor, &fd_dd);
+ rtems_test_assert(NULL != fd_dd);
+ * Verify that writing to a sparse disk delivers expected results
+static void
+ test_writing(
+ int rv;
+ unsigned int byte_count;
+ off_t file_pos;
+ uint8_t buff[block_size];
+ // Write a pattern to all allocated blocks
+ for (block_count = 0; block_count < blocks_allocated; block_count++) {
+ file_pos = (off_t)block_count * block_size;
+ rv = lseek(file_descriptor, file_pos, SEEK_SET);
+ rtems_test_assert(file_pos == rv);
+ rv = read(file_descriptor, buff, block_size);
+ rtems_test_assert(block_size == rv);
+ for (byte_count = 0; byte_count < (block_size / sizeof(byte_count)); byte_count++) {
+ memcpy (buff + (byte_count * sizeof(byte_count)), &byte_count, sizeof(byte_count));
+ rv = write(file_descriptor, buff, block_size);
+ * Verify that black box reading for a sparse disk delivers expected results
+static void
+ test_reading(
+ int rv;
+ off_t file_pos;
+ rv = fsync(file_descriptor);
+ // Read back the patterns
+ value = lseek (file_descriptor, file_pos, SEEK_SET);
+ rtems_test_assert(file_pos == value);
+ rv = read (file_descriptor, &buff, block_size);
+ rtems_test_assert(block_size <= rv);
+ rv = memcmp(buff + (byte_count * sizeof(byte_count)), &byte_count, sizeof(byte_count));
+ // Try to read from unallocated block
+ for (byte_count = 0; byte_count < block_size; ++byte_count)
+ rtems_test_assert(fill_pattern == buff[byte_count]);
+ * Do black box io testing on a sparse disk
+static void
+ test_device_io (const char *device_name,
+ const rtems_blkdev_bnum block_number,
+ int rv;
+ int file_descriptor;
+ file_descriptor = open (device_name, O_RDWR);
+ rtems_test_assert(0 <= file_descriptor);
+ test_disk_params (
+ file_descriptor,
+ block_size,
+ media_block_size,
+ block_number
+ test_writing (
+ file_descriptor,
+ block_size,
+ blocks_allocated
+ test_reading(
+ file_descriptor,
+ block_size,
+ blocks_allocated,
+ fill_pattern
+ rv = close (file_descriptor);
+ * In white box testing verify the key table of the sparse disk is correct
+static void
+ test_static_key_table(
+ const sparse_disk_container *disk_container,
+ unsigned int i;
+ for (i = 0; i < blocks_allocated; ++i)
+ rtems_test_assert(i == disk_container->keytable[i].block);
+ rtems_test_assert(&disk_container->data[i * block_size] == disk_container->keytable[i].data);
+ * Verify the test pattern used in white box testing is as expected
+static void
+ test_static_pattern(
+ const unsigned int pattern_size,
+ const uint8_t *pattern
+ unsigned int i;
+ for (i = 0; i < pattern_size; ++i)
+ rtems_test_assert(((uint8_t)(pattern_size -1 - i)) == pattern[i]);
+ * Read write testing with a statically allocated disk. Thus white box testing can be done
+static void
+ test_with_whitebox(const char *device_name)
+ int rv;
+ unsigned int i;
+ sparse_disk_container disk_container;
+ uint8_t fill_pattern = 0;
+ memset (&disk_container.data, 0, sizeof(disk_container.data));
+ memset (&disk_container.keytable, 0, sizeof(disk_container.keytable));
+ for (i = 0; i < STATIC_PATTERN_SIZE; ++i)
+ disk_container.pattern[i] = (uint8_t)(STATIC_PATTERN_SIZE -1 - i);
+ sc = rtems_sparse_disk_register(
+ "/dev/sda1",
+ &disk_container.sparse_disk,
+ STATIC_BLOCK_SIZE,
+ STATIC_SIMULATED_BLOCK_COUNT,
+ STATIC_ALLOCATED_BLOCK_COUNT,
+ NULL,
+ fill_pattern
+ rtems_test_assert(RTEMS_SUCCESSFUL == sc);
+ &disk_container,
+ STATIC_BLOCK_SIZE
+ for (i = 0; i < (STATIC_BLOCK_SIZE * STATIC_ALLOCATED_BLOCK_COUNT); ++i)
+ rtems_test_assert(0 == disk_container.data[i]);
+ STATIC_PATTERN_SIZE,
+ &disk_container.pattern[0]
+ file_descriptor,
+ test_writing (
+ file_descriptor,
+ test_reading(
+ file_descriptor,
+ fill_pattern
+ &disk_container,
+ STATIC_BLOCK_SIZE
+ for (block_count = 0; block_count < STATIC_ALLOCATED_BLOCK_COUNT; block_count++) {
+ for (byte_count = 0; byte_count < (STATIC_BLOCK_SIZE / sizeof(byte_count)); byte_count++) {
+ rv = memcmp(&disk_container.data[byte_count * sizeof(byte_count)], &byte_count, sizeof(byte_count));
+ * The test sequence
+static
+ void test(void)
+ int rv;
+ char device_name[] = "/dev/sda1";
+ rtems_blkdev_bnum block_number;
+ rtems_sparse_disk *sparse_disk_ptr = NULL;
+ sc = rtems_disk_io_initialize();
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ block_size = 512;
+ block_number = 4 * 2 * 1024;
+ blocks_allocated = 8;
+ sc = rtems_sparse_disk_create(
+ block_size,
+ blocks_allocated,
+ &sparse_disk_ptr
+ "/dev/sda1",
+ sparse_disk_ptr,
+ block_size,
+ block_number,
+ blocks_allocated,
+ rtems_sparse_disk_delete,
+ fill_pattern
+ // Test reading and writing with sector size 512 and 8 such sectors allocated. Block size will default to 512
+ test_device_io (
+ device_name,
+ block_size,
+ block_size,
+ block_number,
+ blocks_allocated,
+ fill_pattern
+ rv = rtems_disk_fd_set_block_size(file_descriptor, blocks_allocated * block_size);
+ // Block size was increased to 4k. Thus all to allocated disk space corresponds to one block. Repeat the read write tests
+ test_device_io (
+ device_name,
+ block_size * blocks_allocated,
+ block_size,
+ block_number,
+ 1,
+ fill_pattern
+ rv = unlink (device_name);
+ // Do testing with a statically allocated disk. This permits white box testing
+ test_with_whitebox(device_name);
+static void Init(rtems_task_argument arg)
+ (void) arg;
+ puts("\n\n*** TEST sparsedisk01 ***");
+ test();
+ puts("*** END OF TEST sparsedisk01 ***");
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_INIT_TASK_STACK_SIZE (16 * 1024)
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/sparsedisk01/sparsedisk01.doc b/testsuites/libtests/sparsedisk01/sparsedisk01.doc
index 0000000..e73746a
--- /dev/null
+++ b/testsuites/libtests/sparsedisk01/sparsedisk01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: sparsedisk01
+directives:
+ TBD
+concepts:
+ TBD
diff --git a/testsuites/libtests/sparsedisk01/sparsedisk01.scn b/testsuites/libtests/sparsedisk01/sparsedisk01.scn
index 0000000..e69de29
1.7.10.4
