[PATCH 6/8] fstests/fsdosfsformat01: New test
Ralf Kirchner ralf.kirchner at embedded-brains.de
Thu Nov 29 14:32:44 UTC 2012
 testsuites/fstests/Makefile.am                     |    3 +-
 testsuites/fstests/configure.ac                    |    1 +
 testsuites/fstests/fsdosfsformat01/Makefile.am     |   19 +
 .../fstests/fsdosfsformat01/fsdosfsformat01.doc    |   11 +
 testsuites/fstests/fsdosfsformat01/init.c          |  462 ++++++++++++++++++++
 5 Dateien geändert, 495 Zeilen hinzugefügt(+), 1 Zeile entfernt(-)
 create mode 100644 testsuites/fstests/fsdosfsformat01/Makefile.am
 create mode 100644 testsuites/fstests/fsdosfsformat01/fsdosfsformat01.doc
 create mode 100644 testsuites/fstests/fsdosfsformat01/fsdosfsformat01.scn
 create mode 100644 testsuites/fstests/fsdosfsformat01/init.c
diff --git a/testsuites/fstests/Makefile.am b/testsuites/fstests/Makefile.am
index 9bba757..7cf6571 100644
--- a/testsuites/fstests/Makefile.am
+++ b/testsuites/fstests/Makefile.am
@@ -1,6 +1,7 @@
 ACLOCAL_AMFLAGS = -I ../aclocal
-SUBDIRS =
+SUBDIRS =
+SUBDIRS += fsdosfsformat01
 SUBDIRS += fsfseeko01
 SUBDIRS += fsdosfssync01
 SUBDIRS += imfs_fserror
diff --git a/testsuites/fstests/configure.ac b/testsuites/fstests/configure.ac
index 6dd15ac..3496de4 100644
--- a/testsuites/fstests/configure.ac
+++ b/testsuites/fstests/configure.ac
@@ -77,6 +77,7 @@ AC_CHECK_SIZEOF([blkcnt_t])
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+fsdosfsformat01/Makefile
 fsfseeko01/Makefile
 fsdosfssync01/Makefile
 imfs_fserror/Makefile
diff --git a/testsuites/fstests/fsdosfsformat01/Makefile.am b/testsuites/fstests/fsdosfsformat01/Makefile.am
new file mode 100644
index 0000000..d7c91f0
--- /dev/null
+++ b/testsuites/fstests/fsdosfsformat01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = fsdosfsformat01
+fsdosfsformat01_SOURCES = init.c
+dist_rtems_tests_DATA = fsdosfsformat01.scn fsdosfsformat01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(fsdosfsformat01_OBJECTS)
+LINK_LIBS = $(fsdosfsformat01_LDLIBS)
+fsdosfsformat01$(EXEEXT): $(fsdosfsformat01_OBJECTS) $(fsdosfsformat01_DEPENDENCIES)
+	@rm -f fsdosfsformat01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/fstests/fsdosfsformat01/fsdosfsformat01.doc b/testsuites/fstests/fsdosfsformat01/fsdosfsformat01.doc
index 0000000..6cdb669
--- /dev/null
+++ b/testsuites/fstests/fsdosfsformat01/fsdosfsformat01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: fsdosfsformat01
+directives:
+  TBD
+concepts:
+  TBD
diff --git a/testsuites/fstests/fsdosfsformat01/fsdosfsformat01.scn b/testsuites/fstests/fsdosfsformat01/fsdosfsformat01.scn
index 0000000..e69de29
diff --git a/testsuites/fstests/fsdosfsformat01/init.c b/testsuites/fstests/fsdosfsformat01/init.c
index 0000000..14de46f
--- /dev/null
+++ b/testsuites/fstests/fsdosfsformat01/init.c
@@ -0,0 +1,462 @@
+ * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Obere Lagerstr. 30
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * The license and distribution terms for this file_name may be
+ * found in the file_name LICENSE in this distribution or at
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include "tmacros.h"
+#include <fcntl.h>
+#include <sys/statvfs.h>
+#include <rtems/libio.h>
+#include <rtems/blkdev.h>
+#include <rtems/dosfs.h>
+#include <rtems/sparse-disk.h>
+#define MAX_PATH_LENGTH                        100  /* Maximum number of characters per path */
+#define SECTOR_SIZE                            512  /* sector size (bytes) */
+#define FAT12_MAX_CLN                         4085  /* maximum + 1 number of clusters for FAT12 */
+#define FAT16_MAX_CLN                        65525  /* maximum + 1 number of clusters for FAT16 */
+#define FAT12_DEFAULT_SECTORS_PER_CLUSTER        8  /* Default number of sectors per cluster for FAT12 */
+#define FAT16_DEFAULT_SECTORS_PER_CLUSTER       32  /* Default number of sectors per cluster for FAT16 */
+static void
+test_disk_params (
+ const char* dev_name,
+ const char* mount_dir,
+ const blksize_t sector_size,
+ const blksize_t cluster_size,
+ const blkcnt_t sectors_per_cluster
+  int rv;
+  int fildes;
+  struct stat stat_buff;
+  char file_name[MAX_PATH_LENGTH +1];
+  ssize_t num_bytes;
+  unsigned int value = (unsigned int) -1;
+  snprintf (file_name, MAX_PATH_LENGTH, "%s/file1.txt", mount_dir);
+  memset (&stat_buff, 0, sizeof(stat_buff));
+  rv = mount (dev_name, mount_dir, RTEMS_FILESYSTEM_TYPE_DOSFS, RTEMS_FILESYSTEM_READ_WRITE, NULL);
+  rtems_test_assert(0 == rv);
+  fildes = open (file_name, O_RDWR | O_CREAT | O_TRUNC, S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH);
+  rtems_test_assert(-1 != fildes);
+  num_bytes = write (fildes, &value, sizeof(value));
+  rtems_test_assert(sizeof(value) == num_bytes);
+  rv = fstat (fildes, &stat_buff);
+  rtems_test_assert(S_ISREG(stat_buff.st_mode));
+  rtems_test_assert(sizeof(value) == stat_buff.st_size);
+  rtems_test_assert(cluster_size == stat_buff.st_blksize);
+  rtems_test_assert(sectors_per_cluster == (stat_buff.st_blocks * sector_size / 512));
+  rtems_test_assert((((stat_buff.st_size + cluster_size - 1) / cluster_size) * cluster_size / 512) == stat_buff.st_blocks);
+  rv = close (fildes);
+  rv = unmount (mount_dir);
+static void
+ test_file_creation (
+  const unsigned int number_of_files
+  int rv;
+  int file_idx = 0;
+  int fildes[number_of_files + 1];
+  unsigned int files_created;
+  /* Create as many files as should be supported */
+  do {
+    snprintf (file_name, MAX_PATH_LENGTH, "%s/file%u.txt", mount_dir, file_idx);
+    fildes[file_idx] = open (file_name, O_RDWR | O_CREAT | O_TRUNC, S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH);
+    rtems_test_assert(-1 != fildes[file_idx]);
+    ++file_idx;
+  while (number_of_files > file_idx);
+  /* Try to create another file which should fail */
+  rtems_test_assert(-1 == fildes[file_idx]);
+  /* Tidy up again by closing and deleting all files */
+  files_created = file_idx;
+  for (file_idx = 0; file_idx < files_created; file_idx++)
+    rv = close(fildes[file_idx]);
+    rv = unlink (file_name);
+static void
+ test(void)
+  rtems_status_code sc;
+  int rv;
+  const char dev_name[] = "/dev/rda";
+  const char mount_dir[] = "/mnt";
+  msdos_format_request_param_t rqdata;
+  rtems_sparse_disk *sparse_disk = NULL;
+  memset (&rqdata, 0, sizeof(rqdata));
+  sc = rtems_disk_io_initialize();
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  rv = mkdir(mount_dir, S_IRWXU | S_IRWXG | S_IRWXO);
+  // FAT12
+  // For 1.44 MB disks
+  sc = rtems_sparse_disk_create(
+    SECTOR_SIZE,
+    64L,
+    &sparse_disk
+  rtems_test_assert(RTEMS_SUCCESSFUL == sc);
+  sc = rtems_sparse_disk_register(
+    dev_name,
+    sparse_disk,
+    SECTOR_SIZE,
+    2880,
+    64L,
+    rtems_sparse_disk_delete,
+    0
+  // Optimized for disk space
+  rqdata.OEMName             = NULL;
+  rqdata.VolLabel            = NULL;
+  rqdata.sectors_per_cluster = 1;
+  rqdata.fat_num             = 1;
+  rqdata.files_per_root_dir  = 32;
+  rqdata.media               = 0; /* Media code. 0 == Default */
+  rqdata.quick_format        = true;
+  rqdata.skip_alignment      = true;
+  rv = msdos_format(dev_name, &rqdata);
+  rtems_test_assert(rv == 0);
+  test_disk_params (dev_name, mount_dir, SECTOR_SIZE, SECTOR_SIZE, 1);
+  test_file_creation (dev_name, mount_dir, rqdata.files_per_root_dir);
+  // Try formatting with invalid values
+  rqdata.fat_num             = 7; /* Invalid number of fats */
+  rtems_test_assert(rv != 0);
+  rqdata.media               = 0x11; /* Invalid media code */
+  rqdata.sectors_per_cluster = 16; /* Invalid number of sectors per cluster for FAT12 */
+  rqdata.skip_alignment      = false;
+  // Optimized for read/write speed
+  rqdata.sectors_per_cluster = 8;
+  rqdata.fat_num             = 0;
+  rqdata.files_per_root_dir  = 0;
+  test_disk_params (dev_name, mount_dir, SECTOR_SIZE, SECTOR_SIZE * rqdata.sectors_per_cluster, rqdata.sectors_per_cluster);
+  rv = unlink (dev_name);
+  // Largest FAT12 disk
+    SECTOR_SIZE,
+    64L,
+    &sparse_disk
+    dev_name,
+    sparse_disk,
+    SECTOR_SIZE,
+    (FAT12_MAX_CLN * FAT12_DEFAULT_SECTORS_PER_CLUSTER) -1L,
+    64L,
+    0
+  // Default parameters (corresponds to optimization for read/write speed)
+  rv = msdos_format(dev_name, NULL);
+  test_disk_params (dev_name, mount_dir, SECTOR_SIZE, SECTOR_SIZE * FAT12_DEFAULT_SECTORS_PER_CLUSTER, FAT12_DEFAULT_SECTORS_PER_CLUSTER);
+  // FAT16
+    SECTOR_SIZE,
+    1024L,
+    &sparse_disk
+    dev_name,
+    sparse_disk,
+    SECTOR_SIZE,
+    (FAT16_MAX_CLN * FAT16_DEFAULT_SECTORS_PER_CLUSTER) - 1L,
+    1024L,
+    0
+    SECTOR_SIZE,
+    1024L,
+    &sparse_disk
+    dev_name,
+    sparse_disk,
+    SECTOR_SIZE,
+    1024L,
+    0
+  rqdata.sectors_per_cluster = 64;
+  test_disk_params (dev_name, mount_dir, SECTOR_SIZE, SECTOR_SIZE * FAT16_DEFAULT_SECTORS_PER_CLUSTER, FAT16_DEFAULT_SECTORS_PER_CLUSTER);
+    SECTOR_SIZE,
+    1024L,
+    &sparse_disk
+    dev_name,
+    sparse_disk,
+    SECTOR_SIZE,
+    (FAT16_MAX_CLN + 10) * 64,
+    1024L,
+    0
+  // FAT32
+    SECTOR_SIZE,
+    1024L,
+    &sparse_disk
+    dev_name,
+    sparse_disk,
+    SECTOR_SIZE,
+    (FAT16_MAX_CLN * FAT16_DEFAULT_SECTORS_PER_CLUSTER) + 41L,
+    1024L,
+    0
+    SECTOR_SIZE,
+    1024L,
+    &sparse_disk
+    dev_name,
+    sparse_disk,
+    SECTOR_SIZE,
+    (FAT16_MAX_CLN + 20) * 64,
+    1024L,
+    0
+static void Init(rtems_task_argument arg)
+  puts("\n\n*** TEST fsdosfsformat01 ***");
+  test();
+  puts("*** END OF TEST fsdosfsformat01 ***");
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+/* 32 root_dir entries tested for file creation + 1 mount_dir + stdin + stdout + stderr + device file when mounted */
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS (32 + 5)
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_FILESYSTEM_DOSFS
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE (32 * 1024)
+#include <rtems/confdefs.h>
1.7.10.4
