[PATCH] Virtex5 BSP: Various updates and improvements.
Ric Claus
claus at slac.stanford.edu
Fri Nov 30 23:58:32 UTC 2012
This BSP now uses the MPC6xx clock driver instead of a modified PPC403 clock
driver. Support for the MMU has been added, but is not enabled by default.
c/src/lib/libbsp/powerpc/virtex5/Makefile.am | 14 +-
c/src/lib/libbsp/powerpc/virtex5/README | 86 +++
.../libbsp/powerpc/virtex5/console/dummy_console.c | 102 ----
c/src/lib/libbsp/powerpc/virtex5/include/irq.h | 4 +
c/src/lib/libbsp/powerpc/virtex5/include/mmu.h | 287 ++++++++++
c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c | 37 +-
c/src/lib/libbsp/powerpc/virtex5/mmu/mmu.c | 581 ++++++++++++++++++++
c/src/lib/libbsp/powerpc/virtex5/preinstall.am | 4 +
.../lib/libbsp/powerpc/virtex5/startup/bspstart.c | 104 +++--
c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds | 11 +-
c/src/lib/libbsp/powerpc/virtex5/startup/start.S | 101 ++--
c/src/lib/libcpu/powerpc/configure.ac | 8 +-
12 files changed, 1125 insertions(+), 214 deletions(-)
create mode 100644 c/src/lib/libbsp/powerpc/virtex5/README
delete mode 100644 c/src/lib/libbsp/powerpc/virtex5/console/dummy_console.c
create mode 100644 c/src/lib/libbsp/powerpc/virtex5/include/mmu.h
create mode 100644 c/src/lib/libbsp/powerpc/virtex5/mmu/mmu.c
diff --git a/c/src/lib/libbsp/powerpc/virtex5/Makefile.am b/c/src/lib/libbsp/powerpc/virtex5/Makefile.am
index 31d3987..0781369 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/virtex5/Makefile.am
@@ -35,14 +35,14 @@ libbsp_a_SOURCES = startup/bspclean.c \
startup/bspstart.c \
../../shared/bootcard.c \
../../shared/sbrk.c \
- ../../shared/gnatinstallhandler.c
+ ../../shared/gnatinstallhandler.c \
+ ../shared/src/memcpy.c
# start
libbsp_a_SOURCES += startup/start.S
# clock & timer
-libbsp_a_SOURCES += ../../../libcpu/@RTEMS_CPU@/ppc403/clock/clock.c
-libbsp_a_SOURCES += ../../../libcpu/@RTEMS_CPU@/ppc403/timer/timer.c
+libbsp_a_SOURCES += ../../powerpc/shared/clock/p_clock.c
# console
libbsp_a_SOURCES += startup/dummy_console.c \
@@ -52,6 +52,10 @@ libbsp_a_SOURCES += startup/dummy_console.c \
include_bsp_HEADERS += include/irq.h
libbsp_a_SOURCES += irq/irq_init.c
+# mmu
+include_bsp_HEADERS += include/mmu.h
+libbsp_a_SOURCES += mmu/mmu.c
#vectors
include_bsp_HEADERS += ../../../libcpu/@RTEMS_CPU@/@exceptions@/bspsupport/vectors.h
include_bsp_HEADERS += ../../../libcpu/@RTEMS_CPU@/@exceptions@/bspsupport/irq_supp.h
@@ -59,7 +63,9 @@ include_bsp_HEADERS += ../../../libcpu/@RTEMS_CPU@/@exceptions@/bspsupport/irq_s
libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/@exceptions@/rtems-cpu.rel \
../../../libcpu/@RTEMS_CPU@/@exceptions@/exc_bspsupport.rel \
../../../libcpu/@RTEMS_CPU@/shared/cache.rel \
- ../../../libcpu/@RTEMS_CPU@/shared/cpuIdent.rel
+ ../../../libcpu/@RTEMS_CPU@/shared/cpuIdent.rel \
+ ../../../libcpu/@RTEMS_CPU@/e500/clock.rel \
+ ../../../libcpu/@RTEMS_CPU@/e500/timer.rel
EXTRA_DIST = times
diff --git a/c/src/lib/libbsp/powerpc/virtex5/README b/c/src/lib/libbsp/powerpc/virtex5/README
new file mode 100644
index 0000000..a68bd23
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/virtex5/README
@@ -0,0 +1,86 @@
+# Adapted from virtex BSP
+BSP NAME: virtex5
+BOARD: N/A
+BUS: N/A
+CPU FAMILY: ppc
+CPU: PowerPC 440x5
+COPROCESSORS: N/A
+MODE: 32 bit mode
+DEBUG MONITOR:
+PERIPHERALS
+TIMERS: 440 internal
+SERIAL PORTS: none
+REAL-TIME CLOCK: none
+DMA: Xilinx virtex internal
+VIDEO: none
+SCSI: none
+NETWORKING: none
+DRIVER INFORMATION
+CLOCK DRIVER: PPC Decrementer
+IOSUPP DRIVER: N/A
+SHMSUPP: N/A
+TIMER DRIVER: N/A
+TTY DRIVER: N/A
+STDIO
+PORT: N/A
+ELECTRICAL: N/A
+BAUD: N/A
+BITS PER CHARACTER: N/A
+PARITY: N/A
+STOP BITS: N/A
+Notes
+Board description
+clock rate: 465 MHz
+ROM: N/A
+RAM: 4GByte DRAM
+Virtex only supports single processor operations.
+Porting
+This board support package is written for a naked Virtex 5/PPC FPGA
+system. The rough features of such a board are described above.
+The BSP itself makes no assumptions on what is loaded in the FPGA,
+other than that the CPU has access to some memory, either on-board
+or external, from which code can be run.
+This BSP has been constructed so that an application of both firmware
+and software can be layered on top of it by supplying implementations
+for the various 'weak' symbols. These symbols are prefaced with the
+term 'app_'. Applications can thus be built outside of the RTEMS
+directory tree by linking with the appropriate libraries.
+The linkcmds file describes the memory layout. Included in this
+definition is a section of memory named MsgArea. Output sent to
+stdout is recorded in this area and can be dumped using the JTAG
+interface, for example.
+For adapting this BSP to other boards, the following files should be
+modified:
+- c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds
+ for the memory layout required
+- c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
+ Here you can select the clock source for the timers and the
+ serial interface (system clock or external clock pin), the
+ clock rates, etc.
+- c/src/lib/libbsp/powerpc/virtex5/include/bsp.h
+ some BSP-related constants
+- c/src/lib/libbsp/powerpc/virtex5/*
+ well, they should be generic, so there _should_ be no reason
+ to mess around there (but who knows...)
diff --git a/c/src/lib/libbsp/powerpc/virtex5/console/dummy_console.c b/c/src/lib/libbsp/powerpc/virtex5/console/dummy_console.c
deleted file mode 100644
index 048133d..0000000
--- a/c/src/lib/libbsp/powerpc/virtex5/console/dummy_console.c
+++ /dev/null
@@ -1,102 +0,0 @@
-#include <rtems.h>
-#include <rtems/libio.h>
-#include <string.h>
-ssize_t app_memory_write(int minor, const char* buf, size_t len)
-__attribute__(( weak, alias("__bsp_memory_write") ));
-ssize_t __bsp_memory_write(int minor, const char* buf, size_t len);
-rtems_device_driver console_initialize(rtems_device_major_number major,
- rtems_device_minor_number minor,
- void* arg);
-rtems_device_driver console_open(rtems_device_major_number major,
- void* arg);
-rtems_device_driver console_close(rtems_device_major_number major,
- void* arg);
-rtems_device_driver console_read(rtems_device_major_number major,
- void* arg);
-rtems_device_driver console_write(rtems_device_major_number major,
- void* arg);
-rtems_device_driver console_control(rtems_device_major_number major,
- void* arg);
- const char* const last = buf+len;
- while (buf < last)
- BSP_output_char(*buf++);
- return len;
-static rtems_termios_callbacks gMemCallbacks = {
- 0, /* firstOpen */
- 0, /* lastClose */
- 0, /* PollRead */
- app_memory_write, /* write */
- 0, /* SetAttr */
- 0, /* stopRemoteTx */
- 0, /* startRemoteTx */
- 0 /* outputUsesInterrupts */
- void* arg)
- rtems_status_code status;
- rtems_termios_initialize();
- status = rtems_io_register_name("/dev/console", major, 0);
- if (status != RTEMS_SUCCESSFUL) rtems_fatal_error_occurred (status);
- return RTEMS_SUCCESSFUL;
- void* arg)
- rtems_status_code sc;
- sc = rtems_termios_open (major, minor, arg, &gMemCallbacks);
- return sc;
- void* arg)
- return rtems_termios_close(arg);
- void* arg)
- return rtems_termios_read(arg);
- void* arg)
- return rtems_termios_write(arg);
- void* arg)
- return rtems_termios_ioctl(arg);
diff --git a/c/src/lib/libbsp/powerpc/virtex5/include/irq.h b/c/src/lib/libbsp/powerpc/virtex5/include/irq.h
index 2edf6aa..a87562f 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/include/irq.h
+++ b/c/src/lib/libbsp/powerpc/virtex5/include/irq.h
@@ -71,6 +71,10 @@ extern "C" {
#ifdef __cplusplus
+#define BSP_DEC BSP_PIT
+#define BSP_DECREMENTER BSP_PIT
#endif
#endif /* ASM */
diff --git a/c/src/lib/libbsp/powerpc/virtex5/include/mmu.h b/c/src/lib/libbsp/powerpc/virtex5/include/mmu.h
index 0000000..a3fb32b
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/virtex5/include/mmu.h
@@ -0,0 +1,287 @@
+#ifndef RTEMS_VIRTEX5_MMU_H
+#define RTEMS_VIRTEX5_MMU_H
+ * @file
+ * @ingroup Virtex5MMU
+ * @brief Routines to manipulate the PPC 440 MMU.
+ * Authorship
+ * This software was created by
+ * Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
+ * Stanford Linear Accelerator Center, Stanford University.
+ * and was transcribed for the PPC 440 by
+ * R. Claus <claus at slac.stanford.edu>, 2012,
+ * Stanford Linear Accelerator Center, Stanford University,
+ * Acknowledgement of sponsorship
+ * This software was produced by
+ * the Stanford Linear Accelerator Center, Stanford University,
+ * under Contract DE-AC03-76SFO0515 with the Department of Energy.
+ * Government disclaimer of liability
+ * Neither the United States nor the United States Department of Energy,
+ * nor any of their employees, makes any warranty, express or implied, or
+ * assumes any legal liability or responsibility for the accuracy,
+ * completeness, or usefulness of any data, apparatus, product, or process
+ * disclosed, or represents that its use would not infringe privately owned
+ * rights.
+ * Stanford disclaimer of liability
+ * Stanford University makes no representations or warranties, express or
+ * implied, nor assumes any liability for the use of this software.
+ * Stanford disclaimer of copyright
+ * Stanford University, owner of the copyright, hereby disclaims its
+ * copyright and all other rights in this software. Hence, anyone may
+ * freely use it for any purpose without restriction.
+ * Maintenance of notices
+ * In the interest of clarity regarding the origin and status of this
+ * SLAC software, this and all the preceding Stanford University notices
+ * are to remain affixed to any copy or derivative of this software made
+ * or distributed by the recipient and are to be affixed to any copy of
+ * software made or distributed by the recipient that contains a copy or
+ * derivative of this software.
+ * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
+#include <rtems.h>
+#include <inttypes.h>
+#include <stdio.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup Virtex5MMU Virtex 5 - MMU Support
+ * @brief MMU support.
+/* Some routines require or return an index 'key'.
+typedef int bsp_tlb_idx_t;
+/* Cache the relevant TLB entries so that we can make sure the user cannot
+ * create conflicting (overlapping) entries. Keep them public for informational
+ * purposes.
+typedef struct {
+ struct {
+ uint32_t pad:24;
+ uint32_t tid:8; /** Translation ID */
+ } id;
+ struct {
+ uint32_t epn:22; /** Effective page number */
+ uint32_t v:1; /** Valid */
+ uint32_t ts:1; /** Translation Address Space */
+ uint32_t size:4; /** Page size */
+ uint32_t tpar:4; /** Tag parity */
+ } w0;
+ struct {
+ uint32_t rpn:22; /** The real (translated) page number. */
+ uint32_t par1:2; /** For matching the TLB array parity */
+ uint32_t pad:4;
+ uint32_t erpn:4; /** Extended Real Page Number */
+ } w1;
+ struct {
+ uint32_t par2:2; /** Parity for TLB word 2 */
+ uint32_t pad1:14;
+ uint32_t att:4; /** User-defined attributes */
+ uint32_t wimge:5; /** Write-Through/Caching Inhibited/Memory Coherent/Guarded/Endian */
+ uint32_t pad2:1;
+ uint32_t perm:6; /** User-State Executable/Writeable/Readable Supervisor-State Executable/Writeable/Readable */
+ } w2;
+} bsp_tlb_entry_t;
+#define NTLBS 64
+extern bsp_tlb_entry_t* bsp_mmu_cache;
+// These constants will have to be shifted right by 20 bits before
+// being inserted the high word of the TLB.
+#define MMU_M_SIZE_1K (0x00000000U)
+#define MMU_M_SIZE_4K (0x08000000U)
+#define MMU_M_SIZE_16K (0x10000000U)
+#define MMU_M_SIZE_64K (0x18000000U)
+#define MMU_M_SIZE_256K (0x20000000U)
+#define MMU_M_SIZE_1M (0x28000000U)
+#define MMU_M_SIZE_16M (0x38000000U)
+#define MMU_M_SIZE_256M (0x48000000U)
+#define MMU_M_SIZE_MIN (MMU_M_SIZE_1K)
+#define MMU_M_SIZE_MAX (MMU_M_SIZE_256M)
+#define MMU_M_SIZE (0x78000000U)
+#define MMU_V_SIZE (27)
+// These constants have the same bit positions they'll occupy
+// in low word of the TLB.
+#define MMU_M_ATTR_USER0 (0x00010000U)
+#define MMU_M_ATTR_USER1 (0x00008000U)
+#define MMU_M_ATTR_USER2 (0x00004000U)
+#define MMU_M_ATTR_USER3 (0x00002000U)
+#define MMU_M_ATTR (0x0001e000U)
+#define MMU_V_ATTR (13)
+#define MMU_M_PROP_WRITE_THROUGH (0x00001000U)
+#define MMU_M_PROP_UNCACHED (0x00000800U)
+#define MMU_M_PROP_MEM_COHERENT (0x00000400U)
+#define MMU_M_PROP_GUARDED (0x00000200U)
+#define MMU_M_PROP_LITTLE_ENDIAN (0x00000100U)
+#define MMU_M_PROP (0x00000f00U)
+#define MMU_V_PROP (8)
+#define MMU_M_PERM_USER_EXEC (0x00000020U)
+#define MMU_M_PERM_USER_WRITE (0x00000010U)
+#define MMU_M_PERM_USER_READ (0x00000008U)
+#define MMU_M_PERM_SUPER_EXEC (0x00000004U)
+#define MMU_M_PERM_SUPER_WRITE (0x00000002U)
+#define MMU_M_PERM_SUPER_READ (0x00000001U)
+#define MMU_M_PERM (0x0000003fU)
+#define MMU_V_PERM (0)
+ * Dump (cleartext) content info from cached TLB entries
+ * to a file (stdout if f==NULL).
+void
+bsp_mmu_dump_cache(FILE *f);
+/* Read a TLB entry from the hardware and store the settings in the
+ * bsp_mmu_cache[] structure.
+ * The routine can perform this operation quietly or
+ * print information to a file.
+ * 'key': TLB entry index.
+ * 'quiet': perform operation silently (no info printed) if nonzero.
+ * 'f': open FILE where to print information. May be NULL, in
+ * which case 'stdout' is used.
+ * RETURNS:
+ * 0: success; TLB entry is VALID
+ * +1: success but TLB entry is INVALID
+ * < 0: error (-1: invalid argument)
+ * (-2: driver not initialized)
+int
+bsp_mmu_update(bsp_tlb_idx_t key, bool quiet, FILE *f);
+/* Initialize cache. Should be done only once although this is not enforced.
+ * RETURNS: zero on success, nonzero on error; in this case the driver will
+ * refuse to change TLB entries (other than disabling them).
+int
+bsp_mmu_initialize(void);
+/* Find first free TLB entry by examining all entries' valid bit. The first
+ * entry without the valid bit set is returned.
+ * RETURNS: A free TLB entry number. -1 if no entry can be found.
+bsp_tlb_idx_t
+bsp_mmu_find_first_free(void);
+/* Write a TLB entry (can also be used to disable an entry).
+ * The routine checks against the cached data in bsp_mmu_cache[]
+ * to prevent the user from generating overlapping entries.
+ * 'idx': TLB entry # to manipulate
+ * 'ea': Effective address (must be page aligned)
+ * 'pa': Physical address (must be page aligned)
+ * 'sz': Page size selector; page size is 1024 * 2^(2*sz) bytes.
+ * 'sz' may also be one of the following:
+ * - page size in bytes ( >= 1024 ); the selector
+ * value is then computed by this routine.
+ * However, 'sz' must be a valid page size
+ * or -1 will be returned.
+ * - a value < 0 to invalidate/disable the
+ * TLB entry.
+ * 'flgs': Page's User-defined flags, permissions and WIMGE page attributes
+ * 'tid': Translation ID
+ * 'ts': Translation Space
+ * 'erpn': Extended Real Page Number
+ * RETURNS: 0 on success, nonzero on error:
+ * >0: requested mapping would overlap with
+ * existing mapping in another entry. Return
+ * value gives conflicting entry + 1; i.e.,
+ * if a value of 4 is returned then the request
+ * conflicts with existing mapping in entry 3.
+ * -1: invalid argument
+ * -3: driver not initialized (or initialization failed).
+ * <0: other error
+bsp_tlb_idx_t
+bsp_mmu_write(bsp_tlb_idx_t idx, uint32_t ea, uint32_t pa, int sz,
+ uint32_t flgs, uint32_t tid, uint32_t ts, uint32_t erpn);
+/* Check if a ea/tid/ts/sz mapping overlaps with an existing entry.
+ * 'ea': The Effective Address to match against
+ * 'sz': The 'logarithmic' size selector; the page size
+ * is 1024*2^(2*sz).
+ * RETURNS:
+ * >= 0: index of TLB entry that already provides a mapping
+ * which overlaps within the ea range.
+ * -1: SUCCESS (no conflicting entry found)
+ * <=-2: ERROR (invalid input)
+bsp_tlb_idx_t
+bsp_mmu_match(uint32_t ea, int sz, uint32_t tid, uint32_t ts);
+/* Find TLB index that maps 'ea/tid/ts' combination
+ * 'ea': Effective address to match against
+ * RETURNS: index 'key'; i.e., the index number.
+ * On error (no mapping) -1 is returned.
+bsp_tlb_idx_t
+bsp_mmu_find(uint32_t ea, uint32_t tid, uint32_t ts);
+/* Mark TLB entry as invalid ('disabled').
+ * RETURNS: zero on success, nonzero on error (TLB unchanged).
+ * NOTE: If a TLB entry is disabled the associated
+ * entry in bsp_tlb_cache[] is also marked as disabled.
+int
+bsp_mmu_invalidate(bsp_tlb_idx_t key);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c b/c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c
index ffcfe4c..7096512 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c
@@ -35,21 +35,21 @@ rtems_irq_global_settings* BSP_rtems_irq_config;
* these functions just do nothing fulfill the semantic
* requirements to enable/disable a certain interrupt or exception
-void BSP_irq_nop_func(const rtems_irq_connect_data *unused)
+static void BSP_irq_nop_func(const rtems_irq_connect_data *unused)
* nothing to do
-void BSP_irq_nop_hdl(void *hdl)
+static void BSP_irq_nop_hdl(void *hdl)
* nothing to do
-int BSP_irq_isOn_func(const rtems_irq_connect_data *unused)
+static int BSP_irq_isOn_func(const rtems_irq_connect_data *unused)
* nothing to do
@@ -64,7 +64,7 @@ int BSP_irq_isOn_func(const rtems_irq_connect_data *unused)
* functions to enable/disable/query external/critical interrupts
-void BSP_irqexc_on_fnc(rtems_irq_connect_data *conn_data)
+void BSP_irqexc_on_fnc(const rtems_irq_connect_data *conn_data)
uint32_t msr_value;
@@ -76,7 +76,7 @@ void BSP_irqexc_on_fnc(rtems_irq_connect_data *conn_data)
_CPU_MSR_SET(msr_value);
-void BSP_irqexc_off_fnc(rtems_irq_connect_data *unused)
+void BSP_irqexc_off_fnc(const rtems_irq_connect_data *unused)
uint32_t msr_value;
@@ -88,6 +88,20 @@ void BSP_irqexc_off_fnc(rtems_irq_connect_data *unused)
+SPR_RW(BOOKE_TSR)
+int C_dispatch_dec_handler (BSP_Exception_frame *frame, unsigned int excNum)
+ /* Acknowledge the interrupt */
+ _write_BOOKE_TSR( BOOKE_TSR_DIS );
+ /* Handle the interrupt */
+ BSP_rtems_irq_tbl[BSP_DEC].hdl(BSP_rtems_irq_tbl[BSP_DEC].handle);
+ return 0;
* High level IRQ handler called from shared_raw_irq_code_entry
@@ -100,9 +114,12 @@ int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
case ASM_EXT_VECTOR:
BSP_rtems_irq_tbl[BSP_EXT].hdl(BSP_rtems_irq_tbl[BSP_EXT].handle);
break;
+#if 0 /* Dealt with by C_dispatch_dec_handler(), above */
case ASM_BOOKE_DEC_VECTOR:
- BSP_rtems_irq_tbl[BSP_PIT].hdl(BSP_rtems_irq_tbl[BSP_PIT].handle);
break;
+#endif
#if 0 /* Critical interrupts not yet supported */
case ASM_BOOKE_CRIT_VECTOR:
BSP_rtems_irq_tbl[BSP_CRIT].hdl(BSP_rtems_irq_tbl[BSP_CRIT].handle);
@@ -275,7 +292,7 @@ int BSP_rtems_irq_mngt_set(rtems_irq_global_settings* config)
* dummy for an empty IRQ handler entry
static rtems_irq_connect_data emptyIrq = {
- 0, /* Irq Name */
+ 0, /* IRQ Name */
BSP_irq_nop_hdl, /* handler function */
NULL, /* handle passed to handler */
BSP_irq_nop_func, /* on function */
@@ -284,8 +301,8 @@ static rtems_irq_connect_data emptyIrq = {
static rtems_irq_global_settings initialConfig = {
- BSP_IRQ_NUMBER, /* irqNb */
- { 0, /* Irq Name */
+ BSP_IRQ_NUMBER, /* IRQ number */
+ { 0, /* IRQ Name */
@@ -305,7 +322,7 @@ void BSP_rtems_irq_mngt_init(unsigned cpuId)
* connect all exception vectors needed
ppc_exc_set_handler(ASM_EXT_VECTOR, C_dispatch_irq_handler);
- ppc_exc_set_handler(ASM_BOOKE_DEC_VECTOR, C_dispatch_irq_handler);
+ ppc_exc_set_handler(ASM_BOOKE_DEC_VECTOR, C_dispatch_dec_handler);
* setup interrupt handlers table
diff --git a/c/src/lib/libbsp/powerpc/virtex5/mmu/mmu.c b/c/src/lib/libbsp/powerpc/virtex5/mmu/mmu.c
index 0000000..990cb99
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/virtex5/mmu/mmu.c
@@ -0,0 +1,581 @@
+ * @file
+ * @brief Implementation of routines to manipulate the PPC 440 MMU.
+ * Since this is a real-time OS we want to stay away from
+ * software TLB replacement.
+ * Authorship
+ * rights.
+/* 440 MSR definitions; note that there are *substantial* differences
+ * compared to classic powerpc; in particular, IS/DS are *different*
+ * from IR/DR; the ppc440 MMU cannot be switched off!
+ * Also: To disable/enable all external interrupts, CE and EE must both be
+ * controlled.
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include <rtems/powerpc/powerpc.h>
+#include <stdio.h>
+#include <bsp/mmu.h>
+#ifdef DEBUG
+#define STATIC
+#else
+#define STATIC static
+#endif
+bsp_tlb_entry_t* bsp_mmu_cache = 0;
+/* Since it is likely that these routines are used during
+ * early initialization when stdio is not available yet
+ * we provide a helper that resorts to 'printk()'
+static void
+myprintf(FILE *f, char *fmt, ...)
+ va_list ap;
+ va_start(ap, fmt);
+ if (!f || !_impure_ptr->__sdidinit) {
+ /* Might be called at an early stage when stdio is not yet initialized. */
+ vprintk(fmt,ap);
+ } else {
+ vfprintf(f,fmt,ap);
+ va_end(ap);
+void
+ bsp_tlb_idx_t idx;
+ if ( !bsp_mmu_cache ) {
+ myprintf(stderr,"MMU TLB cache not initialized\n");
+ return;
+ for ( idx=0; idx<NTLBS; idx++ ) {
+ bsp_tlb_entry_t *tlb = bsp_mmu_cache + idx;
+ if ( !tlb->w0.v )
+ continue;
+ myprintf(f, "#%2i: EA 0x%08x .. 0x%08x, TID 0x%03x, TS %i\n",
+ idx,
+ tlb->w0.epn<<10,
+ (tlb->w0.epn<<10) + (1024<<(2*tlb->w0.size))-1,
+ tlb->id.tid,
+ tlb->w0.ts);
+ myprintf(f, " PA 0x%08"PRIx32", U0-3 0x%01x, WIMGE 0x%02x, PERM 0x%03x\n",
+ tlb->w1.rpn<<10,
+ tlb->w2.att,
+ tlb->w2.wimge,
+ tlb->w2.perm);
+static void
+fetch(bsp_tlb_idx_t key, bsp_tlb_entry_t* tlb)
+ register uint32_t tmp;
+ __asm__ volatile ("mfpid %[tmp] \n\t"
+ "stw %[tmp],0(%[tlb]) \n\t"
+ "tlbre %[tmp],%[key],0 \n\t"
+ "stw %[tmp],4(%[tlb]) \n\t"
+ "tlbre %[tmp],%[key],1 \n\t"
+ "stw %[tmp],8(%[tlb]) \n\t"
+ "tlbre %[tmp],%[key],2 \n\t"
+ "stw %[tmp],12(%[tlb]) \n\t"
+ "sync \n\t"
+ : [tmp]"=&r"(tmp)
+ : [key]"r"(key),
+ [tlb]"b"(tlb)
+static void
+store(bsp_tlb_idx_t key, bsp_tlb_entry_t* tlb)
+ __asm__ volatile ("lwz %[tmp],0(%[tlb]) \n\t"
+ "mtpid %[tmp] \n\t"
+ "lwz %[tmp],4(%[tlb]) \n\t"
+ "tlbwe %[tmp],%[idx],0 \n\t"
+ "lwz %[tmp],8(%[tlb]) \n\t"
+ "tlbwe %[tmp],%[idx],1 \n\t"
+ "lwz %[tmp],12(%[tlb]) \n\t"
+ "tlbwe %[tmp],%[idx],2 \n\t"
+ : [tmp]"=&r"(tmp)
+ : [tlb]"b"(tlb),
+ [idx]"r"(key)
+static void
+commit(void)
+ __asm__ volatile("isync \n\t");
+ * Read a TLB entry from the hardware store the current settings in the
+ * 'idx': which TLB entry to access.
+ * if nonzero.
+ * NULL in which case 'stdout' is used.
+ * RETURNS:
+int
+ rtems_interrupt_level lvl;
+ bsp_tlb_entry_t* tlb;
+ int idx;
+ idx = key;
+ if ( idx < 0 || idx > NTLBS-1 )
+ return -1;
+ if (!bsp_mmu_cache)
+ return -2;
+ tlb = bsp_mmu_cache + idx;
+ rtems_interrupt_disable(lvl);
+ fetch(idx, tlb);
+ rtems_interrupt_enable(lvl);
+ if ( tlb->w0.v ) {
+ if ( !quiet ) {
+ "TLB Entry # 0 spans EA range 0x00000000 - 0x00000000
+ "Mapping: VA [TS 0 / TID 0x00 / EPN 0x00000] -> RPN 0x00000"
+ "Size: TSIZE 0x0 (4^sz KB = 000000 KB = 0x00000000 B)
+ "Attributes: PERM 0x000 (ux/uw/ur/sx/sw/sr) WIMGE 0x00 U0-3 0x0"
+ myprintf(f,
+ "TLB Entry # %2d spans EA range 0x%08x - 0x%08x\n",
+ idx,
+ (tlb->w0.epn << 10),
+ (tlb->w0.epn << 10) + (1024<<(2*tlb->w0.size)) - 1
+ myprintf(f,
+ "Mapping: VA [TS %d / TID 0x%02x / EPN 0x%05x] -> RPN 0x%05"PRIx32"\n",
+ tlb->w0.ts, tlb->id.tid, tlb->w0.epn, tlb->w1.rpn
+ myprintf(f,
+ "Size: TSIZE 0x%x (4^sz KB = %6d KB = 0x%08x B)\n",
+ tlb->w0.size, (1<<(2*tlb->w0.size)), (1024<<(2*tlb->w0.size))
+ myprintf(f,
+ "Properties: PERM 0x%03x (ux/uw/ur/sx/sw/sr) WIMGE 0x%02x U0-3 0x%01x\n",
+ tlb->w2.perm, tlb->w2.wimge, tlb->w2.att
+ } else {
+ if ( !quiet ) {
+ myprintf(f, "TLB Entry # %2d <OFF> (size 0x%x = 0x%xb)\n",
+ idx, tlb->w0.size, (1024<<(2*tlb->w0.size)));
+ return 1;
+ return 0;
+int
+bsp_mmu_initialize()
+ static bsp_tlb_entry_t mmu_cache[NTLBS];
+ bsp_tlb_entry_t* tlb = mmu_cache; /* Should malloc if it's not too early */
+ for (idx=0; idx<NTLBS; tlb++, idx++)
+ fetch(idx, tlb);
+ bsp_mmu_cache = mmu_cache;
+ return 0;
+bsp_tlb_idx_t
+bsp_mmu_find_first_free()
+ bsp_tlb_entry_t entry;
+ for (idx=0; idx<NTLBS; idx++) {
+ __asm__ volatile ("tlbre %[tmp],%[idx],0 \n\t"
+ "stw %[tmp],4(%[tlb]) \n\t" /* entry.w0 */
+ "sync \n\t"
+ : [tmp]"=&r"(tmp)
+ : [idx]"r"(idx),
+ [tlb]"b"(&entry)
+ : "memory"
+ if (!(entry.w0.v))
+ break;
+ return (idx < NTLBS) ? idx : -1;
+ * Write TLB entry (can also be used to disable an entry).
+ * bsp_mmu_cache[] to prevent the user from generating
+ * overlapping entries.
+ * 1024 * 2^(2*sz) bytes.
+ * TLB entry.
+ * existing mapping in other entry. Return
+ * <0: other error
+bsp_tlb_idx_t
+ bsp_tlb_entry_t tlb;
+ uint32_t msk;
+ bsp_tlb_idx_t lkup;
+ if ( sz >= 1024 ) {
+ /* Assume they literally specify a size */
+ msk = sz;
+ sz = 0;
+ while ( msk != (1024<<(sz+sz)) ) {
+ if ( ++sz > 15 ) {
+ return -1;
+ /* OK, acceptable */
+ msk = sz > 0 ? (1024<<(sz+sz)) - 1 : 0;
+ if ( !bsp_mmu_cache && sz > 0 ) {
+ myprintf(stderr,"MMU driver not initialized; refusing to enable any entry\n");
+ return -3;
+ if ( (ea & msk) || (pa & msk) ) {
+ myprintf(stderr,"Misaligned EA (%08x) or PA (%08x) (mask is %08x)\n", ea, pa, msk);
+ return -1;
+ return -1;
+ /* Not all 16 possible sizes are supported */
+ if ( sz == 6 || sz == 8 || sz > 9 ) {
+ myprintf(stderr,"Invalid size %u = %08x = %u KB\n", sz, 1024<<(sz+sz), (1024<<(sz+sz))/1024);
+ return -1;
+ if ( sz >=0 ) {
+ lkup = bsp_mmu_match(ea, sz, tid, ts);
+ if ( lkup < -1 ) {
+ /* some error */
+ return lkup;
+ if ( lkup >= 0 && lkup != idx && (bsp_mmu_cache[lkup].w0.v != 0) ) {
+ myprintf(stderr,"TLB #%i overlaps with requested mapping\n", lkup);
+ bsp_mmu_update( lkup, false, stderr);
+ return lkup+1;
+ /* OK to proceed */
+ tlb.id.tid = tid;
+ tlb.w0.v = sz >= 0;
+ tlb.w0.ts = ts;
+ tlb.w0.size = sz;
+ tlb.w0.epn = (ea & (0xfffffc00 << (sz+sz))) >> 10;
+ if (sz < 11) {
+ tlb.w1.rpn = (pa & (0xfffffc00 << (sz+sz))) >> 10;
+ tlb.w1.erpn = erpn;
+ else {
+ sz -= 11;
+ tlb.w1.rpn = 0;
+ tlb.w1.erpn = (erpn & (0xf << (sz+sz))) & 0xf;
+ tlb.w2.att = (flgs & MMU_M_ATTR) >> MMU_V_ATTR;
+ tlb.w2.wimge = (flgs & MMU_M_PROP) >> MMU_V_PROP;
+ tlb.w2.perm = (flgs & MMU_M_PERM) >> MMU_V_PERM;
+ store(idx, &tlb);
+ commit();
+ /* update cache */
+ bsp_mmu_update(idx, true, 0);
+ return 0;
+ * Check if a ea/tid/ts/sz mapping overlaps with an existing entry.
+ * RETURNS:
+ * >= 0: index of the TLB entry that already provides a mapping
+bsp_tlb_idx_t
+ uint32_t m,a;
+ if ( sz < 0 || sz == 6 || sz == 8 || sz > 9 )
+ return -4;
+ sz = (1024<<(2*sz));
+ /* cache not initialized */
+ return -3;
+ if ( ea & (sz-1) ) {
+ /* misaligned ea */
+ return -2;
+ for ( idx=0, tlb=bsp_mmu_cache; idx<NTLBS; idx++, tlb++ ) {
+ if ( ! tlb->w0.v )
+ continue;
+ if ( tlb->id.tid && tlb->id.tid != tid )
+ continue;
+ if ( tlb->w0.ts != ts )
+ continue;
+ /* TID and TS match a valid entry */
+ m = (1024<<(2*tlb->w0.size)) - 1;
+ /* calculate starting address of this entry */
+ a = tlb->w0.epn<<10;
+ if ( ea <= a + m && ea + sz -1 >= a ) {
+ /* overlap */
+ return idx;
+ return -1;
+ * RETURNS: index 'key' which indicates whether
+ * the mapping was found.
+bsp_tlb_idx_t
+ register uint32_t mmucr;
+ register bsp_tlb_idx_t idx;
+ register int failure;
+ __asm__ volatile ("mfspr %[mmucr],0x3b2 \n\t" /* Save MMUCR */
+ : [mmucr]"=r"(mmucr)
+ __asm__ volatile ("mtspr 0x3b2,%[tid] \n\t"
+ "tlbsx. %[idx],0,%[ea] \n\t" /* Failure changes the index reg randomly. */
+ "mfcr %[failure] \n\t"
+ "mtspr 0x3b2,%[mmucr] \n\t" /* Restore MMUCR */
+ : [idx]"=&r"(idx),
+ [failure]"=&r"(failure)
+ : [tid]"r"((mmucr & 0xfffeff00) | (ts << 16) | tid),
+ [ea]"r"(ea),
+ [mmucr]"r"(mmucr)
+ : "cc"
+ return (failure & 0x20000000) ? idx : -1;
+ * 'key': TLB entry (index).
+ * entry in bsp_mmu_cache[] is also
+ * marked as disabled.
+int
+ bsp_tlb_idx_t k0;
+ /* minimal guard against bad key */
+ if ( key < 0 || key > NTLBS-1 )
+ return -1;
+ /* Must not invalidate page 0 which holds vectors, text etc... */
+ k0 = bsp_mmu_find(0, 0, 0);
+ if ( -1 == k0 ) {
+ myprintf(stderr,"No mapping for address 0 found\n");
+ return -2;
+ /* NOTE: we assume PID is ignored */
+ if ( k0 == key ) {
+ myprintf(stderr,"Cannot invalidate page holding address 0 (always needed)\n");
+ return -3;
+ fetch(key, &tlb);
+ /* Invalidate old entries */
+ tlb.w0.v = 0;
+ store(key, &tlb);
+ commit();
+ /* Update cache */
+ bsp_mmu_cache[ key ].w0.v = tlb.w0.v;
+ return 0;
diff --git a/c/src/lib/libbsp/powerpc/virtex5/preinstall.am b/c/src/lib/libbsp/powerpc/virtex5/preinstall.am
index 34b03f1..e441f38 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/preinstall.am
+++ b/c/src/lib/libbsp/powerpc/virtex5/preinstall.am
@@ -69,6 +69,10 @@ $(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
+$(PROJECT_INCLUDE)/bsp/mmu.h: include/mmu.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mmu.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mmu.h
$(PROJECT_INCLUDE)/bsp/vectors.h: ../../../libcpu/@RTEMS_CPU@/@exceptions@/bspsupport/vectors.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/vectors.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/vectors.h
diff --git a/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c b/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
index 8847dc8..4aa89f7 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
@@ -54,20 +54,23 @@
* Modifications for PPC405GP by Dennis Ehlin
* Modifications for Virtex5 by Richard Claus <claus at slac.stanford.edu>
-#include <fcntl.h>
-#include <bsp.h>
-#include <bsp/irq.h>
-#include <bsp/vectors.h>
+#include <rtems.h>
+#include <rtems/config.h>
#include <rtems/libcsupport.h>
-#include <rtems/sptables.h> /* for RTEMS_VERSION */
#include <libcpu/cpuIdent.h>
#include <libcpu/spr.h>
+#include <bsp.h>
+#include <bsp/vectors.h>
+#include <bsp/bootcard.h>
+#include <bsp/irq.h>
+#include <string.h>
+#include <fcntl.h>
#define DO_DOWN_ALIGN(x,a) ((x) & ~((a)-1))
#define DO_UP_ALIGN(x,a) DO_DOWN_ALIGN(((x) + (a) - 1 ),a)
@@ -76,13 +79,6 @@
#define CPU_UP_ALIGN(x) DO_UP_ALIGN(x, CPU_ALIGNMENT)
-/* Expected by clock.c */
-uint32_t bsp_clicks_per_usec;
-bool bsp_timer_internal_clock; /* true, when timer runs with CPU clk */
-uint32_t bsp_timer_least_valid;
-uint32_t bsp_timer_average_overhead;
/* Defined in linkcmds linker script */
LINKER_SYMBOL(RamBase);
LINKER_SYMBOL(RamSize);
@@ -96,35 +92,37 @@ LINKER_SYMBOL(WorkAreaBase);
LINKER_SYMBOL(MsgAreaBase);
LINKER_SYMBOL(MsgAreaSize);
LINKER_SYMBOL(__phy_ram_end);
+LINKER_SYMBOL(bsp_exc_vector_base);
+/* Expected by clock.c */
+uint32_t bsp_clicks_per_usec;
+bool bsp_timer_internal_clock; /* true, when timer runs with CPU clk */
+uint32_t bsp_timer_least_valid;
+uint32_t bsp_timer_average_overhead;
- * Provide weak aliases so that RTEMS distribution builds
+ * Bus Frequency
-static void _noopfun(void) {}
-static void _bsp_start(void)
- uintptr_t intrStackStart = CPU_UP_ALIGN((uint32_t)__bsp_ram_start);
- uintptr_t intrStackSize = rtems_configuration_get_interrupt_stack_size();
+unsigned int BSP_bus_frequency;
+ * processor clock frequency
+unsigned int BSP_processor_frequency;
- * Initialize default raw exception handlers.
- * This BSP does not assume anything about firmware possibly loaded in the
- * FPGA, so the external interrupt should not be enabled in order to avoid
- * spurious interrupts.
- ppc_exc_initialize(PPC_INTERRUPT_DISABLE_MASK_DEFAULT & ~MSR_EE,
- intrStackStart,
- intrStackSize);
+ * Time base divisior (bus freq / TB clock)
+unsigned int BSP_time_base_divisor;
- /* Install our own set of exception vectors */
- BSP_rtems_irq_mngt_init(0);
+ * Provide weak aliases so that RTEMS distribution builds
+static void _noopfun(void) {}
void app_bsp_start(void)
-__attribute__(( weak, alias("_bsp_start") ));
+__attribute__(( weak, alias("_noopfun") ));
void app_bsp_pretasking_hook(void)
@@ -147,20 +145,31 @@ static void __bsp_outchar_to_memory(char c)
void BSP_ask_for_reset(void)
printk("\nSystem stopped, issue RESET");
for(;;);
void BSP_panic(char *s)
- printk("\n%s PANIC %s\n", _RTEMS_version, s);
+ rtems_interrupt_level level;
+ rtems_interrupt_disable(level);
+ printk("\n%s PANIC %s\n", rtems_get_version_string(), s);
BSP_ask_for_reset();
void _BSP_Fatal_error(unsigned int v)
- printk("\n%s FATAL ERROR %x\n", _RTEMS_version, v);
+ printk("\n%s FATAL ERROR %x\n", rtems_get_version_string(), v);
@@ -176,13 +185,14 @@ void bsp_start(void)
uintptr_t intrStackStart;
uintptr_t intrStackSize;
ppc_cpu_id_t myCpu;
ppc_cpu_revision_t myCpuRevision;
/* Set the character output function; The application may override this */
BSP_output_char = __bsp_outchar_to_memory;
- printk("\nWelcome to RTEMS %s\n", _RTEMS_version );
+ printk("RTEMS %s\n", rtems_get_version_string());
* Get CPU identification dynamically. Note that the get_ppc_cpu_type()
@@ -197,8 +207,13 @@ void bsp_start(void)
* Initialize the device driver parameters
+ /* For mpc6xx clock driver: */
+ BSP_bus_frequency = 465000000;
+ BSP_processor_frequency = 465000000; /* Measured with a DPM 440 2012/8/13 */
+ BSP_time_base_divisor = 1000;
/* Timebase register ticks/microsecond; The application may override these */
- bsp_clicks_per_usec = 450;
+ bsp_clicks_per_usec = BSP_bus_frequency/(BSP_time_base_divisor * 1000);
bsp_timer_internal_clock = true;
bsp_timer_average_overhead = 2;
bsp_timer_least_valid = 3;
@@ -208,6 +223,12 @@ void bsp_start(void)
+ ppc_exc_initialize(PPC_INTERRUPT_DISABLE_MASK_DEFAULT,
+ intrStackStart,
+ intrStackSize);
+ /* Let the user know what parameters we were compiled with */
printk(" Base/Start End Size\n"
"RAM: 0x%08x 0x%x\n"
"RTEMS: 0x%08x\n"
@@ -224,6 +245,11 @@ void bsp_start(void)
(uint32_t)MsgAreaBase, (uint32_t)MsgAreaSize,
(uint32_t)__phy_ram_end);
+ * Initialize RTEMS IRQ system
+ BSP_rtems_irq_mngt_init(0);
/* Continue with application-specific initialization */
app_bsp_start();
diff --git a/c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds b/c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds
index 20d4095..a92d9a1 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds
+++ b/c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds
@@ -20,16 +20,17 @@ HeapSize = DEFINED(HeapSize) ? HeapSize : 0; /* 0=Use def */
MEMORY
- VECTORS : ORIGIN = 0x00000000, LENGTH = 8K
- RAM : ORIGIN = 0x00002000, LENGTH = 2048M - 8K
+ VECTORS : ORIGIN = 0x00000000, LENGTH = 512
+ RAM : ORIGIN = 0x00000200, LENGTH = 2048M - 512
SECTIONS
- __exeentry = download_entry;
- __exestart = 0x100;
- .vectors __exestart : { *(.vectors) } > VECTORS
+ bsp_exc_vector_base = 0;
+ __exeentry = download_entry;
+ __exestart = bsp_exc_vector_base;
+ .vectors bsp_exc_vector_base : { *(.vectors) } > VECTORS
/* Read-only sections, merged into text segment: */
.interp : { *(.interp) } > RAM
diff --git a/c/src/lib/libbsp/powerpc/virtex5/startup/start.S b/c/src/lib/libbsp/powerpc/virtex5/startup/start.S
index 1afa587..40938e5 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/startup/start.S
+++ b/c/src/lib/libbsp/powerpc/virtex5/startup/start.S
@@ -61,6 +61,7 @@
#include <rtems/asm.h>
+#include <rtems/powerpc/registers.h>
#define V_TS_SZ_I 0x0290 // V,TS=0(Inst),SIZE=9,TID=0
#define V_TS_SZ_D 0x0390 // V,TS=1(Data),SIZE=9,TID=0
@@ -154,43 +155,44 @@ first: li r0,0 // Clear r0
* Set Core Configuration Register 0 as follows:
- * sum: 0x00200000
+ * sum: 0x00206000
* bit 1 off Parity Recovery Enable
* bit 4 off Cache Read Parity Enable
* bit 10 on Disable Store Gathering
* bit 11 off Disable APU Instruction Broadcast
* bit 16 off Disable Trace Broadcast
- * bit 17:18 off Specifies behaviour of icbt,dcbt/dcbtst insts
+ * bit 17:18 on Specifies behaviour of icbt,dcbt/dcbtst insts
* bit 23 off Force Load/Store Alignment
* bit 28:29 off Instruction Cache Speculative Line Count
* bit 30:31 off Instruction Cache Speculative Line Threshold
* NB: UG200/pg 21: Spec. prefetching must be disabled
- lis r2,0x0020 // 7. Set CCR0: DSTG
- mtccr0 r2 // Configure CCR0
+ lis r2, 0x00206000 at h // 7. Set CCR0: DSTG
+ ori r2,r2,0x00206000 at l // Set CCR0: GDCBT, GICBT
+ mtccr0 r2 // Configure CCR0
- mtspr ccr1,r0 // 8. Clear CCR1
+ mtspr PPC440_CCR1,r0 // 8. Clear CCR1
* 9. Configure cache regions
- mtspr inv0,r0
- mtspr inv1,r0
- mtspr inv2,r0
- mtspr inv3,r0
- mtspr dnv0,r0
- mtspr dnv1,r0
- mtspr dnv2,r0
- mtspr dnv3,r0
- mtspr itv0,r0
- mtspr itv1,r0
- mtspr itv2,r0
- mtspr itv3,r0
- mtspr dtv0,r0
- mtspr dtv1,r0
- mtspr dtv2,r0
- mtspr dtv3,r0
+ mtspr PPC440_INV0,r0
+ mtspr PPC440_INV1,r0
+ mtspr PPC440_INV2,r0
+ mtspr PPC440_INV3,r0
+ mtspr PPC440_DNV0,r0
+ mtspr PPC440_DNV1,r0
+ mtspr PPC440_DNV2,r0
+ mtspr PPC440_DNV3,r0
+ mtspr PPC440_ITV0,r0
+ mtspr PPC440_ITV1,r0
+ mtspr PPC440_ITV2,r0
+ mtspr PPC440_ITV3,r0
+ mtspr PPC440_DTV0,r0
+ mtspr PPC440_DTV1,r0
+ mtspr PPC440_DTV2,r0
+ mtspr PPC440_DTV3,r0
* Cache victim limits
@@ -198,8 +200,8 @@ first: li r0,0 // Clear r0
lis r2, 0x0001f800 at h
ori r2,r2,0x0001f800 at l
- mtspr ivlim,r2
- mtspr dvlim,r2
+ mtspr PPC440_IVLIM,r2
+ mtspr PPC440_DVLIM,r2
* Configure instruction and data cache regions:
@@ -241,7 +243,7 @@ first: li r0,0 // Clear r0
* 31 SR 1 1 Supervisor State Read Enable
- mtspr mmucr,r0 // 10a. Clear MMUCR
+ mtspr PPC440_MMUCR,r0 // 10a. Clear MMUCR
li r7,WIMG_U_S_1 // Word 2: Pages are NOT cache inhibited
lis r6, PAGE_SZ at h // Page size constant
ori r6,r6,PAGE_SZ at l
@@ -255,9 +257,9 @@ first: li r0,0 // Clear r0
* Select whether Wait Enable, interrupts/exceptions and which address
* spaces should be enabled when application starts
- lis r0, 0x00000000 at h // 10d. MSR[IS]=0 MSR[DS]=0
- ori r0,r0,0x00000000 at l
- mtsrr1 r0
+ lis r3, 0x00000000 at h // 10d. MSR[IS]=0 MSR[DS]=0
+ ori r3,r3,0x00000000 at l
+ mtsrr1 r3
mtsrr0 r28 // Return address
rfi // Context synchronize to invalidate shadow TLB contents
@@ -275,43 +277,43 @@ startupDL:
* 11. Tell the processor where the exception vector table will be
.extern SYM(__vectors)
- lis r2, __vectors at h /* set EVPR exc. vector prefix */
- mtspr ivpr,r2
+ lis r1, __vectors at h /* set EVPR exc. vector prefix */
+ mtspr BOOKE_IVPR,r1
* Set up default exception and interrupt vectors
- li r1,0x100
+ li r1,0
mtivor0 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor1 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor2 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor3 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor4 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor5 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor6 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor7 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor8 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor9 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor10 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor11 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor12 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor13 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor14 r1
- addi r1,r1,0x100
+ addi r1,r1,0x10
mtivor15 r1
@@ -336,16 +338,15 @@ startupDL:
* 13. Configure timer facilities
mtdec r0 // Clear Decrementer to prevent exception
- mttbu r0 // Clear Timebase to prevent Fixed Interval..
- mttbl r0 // ..timer and Watchdog Timer exceptions
+ mttbl r0 // Clear Timebase to prevent Fixed Interval..
+ mttbu r0 // ..timer and Watchdog Timer exceptions
mtpit r0 // Programmable interval timer
- li r1,-1 // -1 to clear TSR
- mttsr r1 // Timer status register
+ li r2,-1 // -1 to clear TSR
+ mttsr r2 // Timer status register
* Clear out stale values in certain registers to avoid confusion
- li r0,0
mtcrf 0xff,r0 // Need for simulation
mtctr r0 // Counter register
mtxer r0 // Fixed-point exception register
diff --git a/c/src/lib/libcpu/powerpc/configure.ac b/c/src/lib/libcpu/powerpc/configure.ac
index 6190517..86fb4f4 100644
--- a/c/src/lib/libcpu/powerpc/configure.ac
+++ b/c/src/lib/libcpu/powerpc/configure.ac
@@ -57,7 +57,7 @@ AM_CONDITIONAL(mpc6xx, test "$RTEMS_CPU_MODEL" = "mpc6xx" \
|| test "$RTEMS_CPU_MODEL" = "mpc750" \
|| test "$RTEMS_CPU_MODEL" = "mpc8240" \
|| test "$RTEMS_CPU_MODEL" = "mpc8245" \
-|| test "$RTEMS_CPU_MODEL" = "mpc83xx" )
+|| test "$RTEMS_CPU_MODEL" = "mpc83xx")
AM_CONDITIONAL(mpc8xx, test "$RTEMS_CPU_MODEL" = "mpc8xx" \
|| test "$RTEMS_CPU_MODEL" = "mpc821" \
|| test "$RTEMS_CPU_MODEL" = "mpc860" )
@@ -65,15 +65,15 @@ AM_CONDITIONAL(mpc8260, test "$RTEMS_CPU_MODEL" = "mpc8260")
AM_CONDITIONAL(mpc83xx, test "$RTEMS_CPU_MODEL" = "mpc83xx")
AM_CONDITIONAL(qoriq, test "$RTEMS_CPU_MODEL" = "qoriq")
-# the ppc405 and ppc440 share files with the ppc403
+# the ppc405 share files with the ppc403
AM_CONDITIONAL(ppc403, test "$RTEMS_CPU_MODEL" = "ppc403")
AM_CONDITIONAL(ppc405, test "$RTEMS_CPU_MODEL" = "ppc405")
AM_CONDITIONAL(ppc440, test "$RTEMS_CPU_MODEL" = "ppc440")
AM_CONDITIONAL(ppc4xx, test "$RTEMS_CPU_MODEL" = "ppc403" \
-|| test "$RTEMS_CPU_MODEL" = "ppc405" \
-|| test "$RTEMS_CPU_MODEL" = "ppc440")
+|| test "$RTEMS_CPU_MODEL" = "ppc405")
AM_CONDITIONAL(e500, test "$RTEMS_CPU_MODEL" = "e500" \
+|| test "$RTEMS_CPU_MODEL" = "ppc440" \
|| test "$RTEMS_CPU_MODEL" = "qoriq" )
RTEMS_CHECK_NETWORKING
1.7.1
