[PATCH] score: PR1607: Add and use CPU_SIZEOF_POINTER
Ralf Corsepius ralf.corsepius at rtems.org
Mon Nov 5 03:26:28 UTC 2012
On 11/04/2012 09:41 PM, Joel Sherrill wrote:
> I am pretty sure the h8300 pointer size varies by mulitilib variant.
Yes - It is one of targets, where this applies.
> I am not at home to run checks.
Sebastian's CPU_SIZEOF_POINTER suffers from the same flaws as your
__RTEMS_SIZEOF_VOID_P__.
They vary between targets and can vary between multilib variants of a
targets.
I.e. using any of these defines in a global per-target header does not work.
=> This patch is not OK with me.
Ralf
