[PATCH 14/23] sapi: Use rtems_*_get_user_multiprocessing_table
Sebastian Huber
Tue Nov 6 12:56:36 UTC 2012
c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c | 2 +-
c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c | 2 +-
cpukit/sapi/src/exinit.c | 2 +-
3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c b/c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c
index d60513f..b1153a2 100644
--- a/c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c
+++ b/c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c
@@ -63,7 +63,7 @@ void bsp_start( void )
#if defined(RTEMS_MULTIPROCESSING)
node_number = (uint8_t)
- (Configuration.User_multiprocessing_table->node - 1) & 0xF;
+ (rtems_configuration_get_user_multiprocessing_table()->node - 1) & 0xF;
#else
node_number = 1;
#endif
diff --git a/c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c b/c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c
index 7e35352..60b47ca 100644
--- a/c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c
+++ b/c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c
@@ -124,7 +124,7 @@ void Shm_Get_configuration(
if (LEON3_Cpu_Index == 0) {
tmp = 0;
for (i = 1;
- i < (Configuration.User_multiprocessing_table)->maximum_nodes; i++)
+ i < (rtems_configuration_get_user_multiprocessing_table())->maximum_nodes; i++)
tmp |= (1 << i);
LEON3_IrqCtrl_Regs->mpstat = tmp;
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 1aa7e54..7335128 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -79,7 +79,7 @@ void rtems_initialize_data_structures(void)
* In an MP configuration, internally we view single processor
* systems as a very restricted multiprocessor system.
- _Configuration_MP_table = Configuration.User_multiprocessing_table;
+ _Configuration_MP_table = rtems_configuration_get_user_multiprocessing_table();
if ( _Configuration_MP_table == NULL ) {
1.7.7
