[PATCH 16/23] bsp/nds: Do not change configuration
Tue Nov 6 12:56:38 UTC 2012
 c/src/lib/libbsp/arm/nds/startup/bspstart.c |    3 ---
 1 files changed, 0 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/arm/nds/startup/bspstart.c b/c/src/lib/libbsp/arm/nds/startup/bspstart.c
index 59c074e..b57d758 100644
--- a/c/src/lib/libbsp/arm/nds/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/nds/startup/bspstart.c
@@ -42,9 +42,6 @@ void bsp_start (void)
   /* set the cpu mode to system user */
   arm_cpu_mode = 0x1f;
-  /* configure clock period */
-  rtems_configuration_set_microseconds_per_tick (10000);
   defaultExceptionHandler ();
1.7.7
