[PATCH 23/23] sapi: Make Configuration read-only
Tue Nov 6 12:56:45 UTC 2012
The Configuration is now read-only and must be statically initialized
via confdefs.h or similar.
 cpukit/sapi/include/confdefs.h     |    2 +-
 cpukit/sapi/include/rtems/config.h |    2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 17cb2ee..00ba59b 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2316,7 +2316,7 @@ rtems_fs_init_functions_t    rtems_fs_init_helper =
    *  This is the primary Configuration Table for this application.
-  rtems_configuration_table Configuration = {
+  const rtems_configuration_table Configuration = {
     CONFIGURE_EXECUTIVE_RAM_SIZE,             /* required RTEMS workspace */
     CONFIGURE_STACK_SPACE_SIZE,               /* required stack space */
     CONFIGURE_MAXIMUM_USER_EXTENSIONS,        /* maximum dynamic extensions */
diff --git a/cpukit/sapi/include/rtems/config.h b/cpukit/sapi/include/rtems/config.h
index 55b7bda..ed869ec 100644
--- a/cpukit/sapi/include/rtems/config.h
+++ b/cpukit/sapi/include/rtems/config.h
@@ -222,7 +222,7 @@ typedef struct {
  *   This is the configuration table generated by confdefs.h.
-extern rtems_configuration_table  Configuration;
+extern const rtems_configuration_table Configuration;
 #if defined(RTEMS_MULTIPROCESSING)
1.7.7
