[PATCH 01/23] sapi: Use rtems_config*_get_microseconds_per_tick
Sebastian Huber
Tue Nov 6 15:39:49 UTC 2012
On 11/06/2012 04:25 PM, Gedare Bloom wrote:
> Can you provide some background on this patch series?
Most of them are simple clean-ups. The important (and potentially
controversial) change is the last one:
The Configuration is now read-only and must be statically initialized
via confdefs.h or similar.
cpukit/sapi/include/confdefs.h | 2 +-
cpukit/sapi/include/rtems/config.h | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 17cb2ee..00ba59b 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2316,7 +2316,7 @@ rtems_fs_init_functions_t rtems_fs_init_helper =
* This is the primary Configuration Table for this application.
- rtems_configuration_table Configuration = {
+ const rtems_configuration_table Configuration = {
CONFIGURE_EXECUTIVE_RAM_SIZE, /* required RTEMS workspace */
CONFIGURE_STACK_SPACE_SIZE, /* required stack space */
CONFIGURE_MAXIMUM_USER_EXTENSIONS, /* maximum dynamic extensions */
diff --git a/cpukit/sapi/include/rtems/config.h
b/cpukit/sapi/include/rtems/config.h
index 55b7bda..ed869ec 100644
--- a/cpukit/sapi/include/rtems/config.h
+++ b/cpukit/sapi/include/rtems/config.h
@@ -222,7 +222,7 @@ typedef struct {
* This is the configuration table generated by confdefs.h.
-extern rtems_configuration_table Configuration;
+extern const rtems_configuration_table Configuration;
#if defined(RTEMS_MULTIPROCESSING)
My aim is to make it possible to call _Internal_error_Occurred() in every (!)
system state provided the read-only data is write protected. Since the initial
extensions are part of the Configuration this change is the first step. It is
also beneficial for targets with a small internal RAM.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
