[PATCH v3] score: PR1607: Add and use CPU_SIZEOF_POINTER
Ralf Corsepius
ralf.corsepius at rtems.org
Thu Nov 8 10:33:41 UTC 2012
On 11/08/2012 11:02 AM, Sebastian Huber wrote:
> On 11/08/2012 10:33 AM, Ralf Corsepius wrote:
>> On 11/08/2012 09:27 AM, Sebastian Huber wrote:
>>> Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an
>>> integer literal that can be used by the assembler. This value will be
>>> used to calculate offsets of structure members. These offsets will be
>>> used in assembler code.
>>> The size of a pointer is part of the application binary interface (ABI)
>>> and thus independent of the actual programming language. The compiler
>>> will provide defines to determine the current ABI. We use these
>>> defines
>>> to select the appropriate CPU_SIZEOF_POINTER value.
>>> Static assertions in the new file "cpukit/score/src/percpuasm.c" will
>>> ensure that the value of CPU_SIZEOF_POINTER is consistent with the
>>> current compiler settings. Also the offset values used by assembler
>>> code are verfied.
>> It's just a random accident it appears to work for some targets.
> In particular I am interested to know how you justify "random
> accident" if you look at the static assertions.
random accident here means: You didn't notice your design's flaw,
because your "usual cases" do not exhibit this behavior.
The static_assert is just a naive sillyness - It's just absurd.
Ralf
