"Butter bei de Fische" was: Re: [PATCH v3] score: PR1607: Add and use CPU_SIZEOF_POINTER
Fri Nov 9 10:36:14 UTC 2012
On 11/09/2012 08:44 AM, Thomas Doerfler wrote:
> Sebastian, Ralf, can you both identify a typical piece of assembly code, that
> might be recoded into a more portable code? We could then consider, which versions
> - meet the portability requirements
> - meet the performance requirements
> - are readable and maintainable
> - interface properly to the C portion of the code
#define CPU_SIZEOF_POINTER X
This will define the size of a pointer for the current ABI.
http://en.wikipedia.org/wiki/Application_binary_interface
The type size affects also the selection of the load/store machine
instructions.  Please remember bugs like this:
http://www.rtems.org/pipermail/rtems-users/2009-March/005030.html
Just a reminder for all people who think that "ABIs are _completely irrelevant_"
We can use CPU_SIZEOF_POINTER to calculate offsets to structure members.  The
static assertions make sure that this value and the offsets are consistent with
the current compiler settings.  Examples:
#define PER_CPU_ISR_NEST_LEVEL \
           PER_CPU_END_STACK + 0
#define PER_CPU_EXECUTING \
           PER_CPU_END_STACK + (1 * CPU_SIZEOF_POINTER)
#define ISR_NEST_LEVEL \
          (SYM(_Per_CPU_Information) + PER_CPU_ISR_NEST_LEVEL)
They are later used in assembler code like this:
http://git.rtems.org/rtems/tree/c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h
	/* Increment ISR nest level and thread dispatch disable level */
	lis	SCRATCH_REGISTER_2, ISR_NEST_LEVEL at ha
	lwz	SCRATCH_REGISTER_0, ISR_NEST_LEVEL at l(SCRATCH_REGISTER_2)
	lwz	SCRATCH_REGISTER_1, _Thread_Dispatch_disable_level at sdarel(r13)
	addi	SCRATCH_REGISTER_0, SCRATCH_REGISTER_0, 1
	addi	SCRATCH_REGISTER_1, SCRATCH_REGISTER_1, 1
	stw	SCRATCH_REGISTER_0, ISR_NEST_LEVEL at l(SCRATCH_REGISTER_2)
	stw	SCRATCH_REGISTER_1, _Thread_Dispatch_disable_level at sdarel(r13)
The ARMv7-M port uses inline assembler only:
http://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/armv7m-context-switch.c
This works, because the GCC ARM supports the __attribute__((naked)).  One
drawback is, that this will work only with GCC.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
