[PATCH 04/16] sapi: Add and use rtems_internal_error_description
Wed Nov 14 15:46:58 UTC 2012
 cpukit/sapi/Makefile.am                            |    2 +-
 cpukit/sapi/include/rtems/fatal.h                  |   11 ++++
 cpukit/sapi/src/interrdesc.c                       |   58 +++++++++++++++++++
 testsuites/psxtests/psxfatal_support/init.c        |   32 +----------
 testsuites/sptests/Makefile.am                     |    1 +
 testsuites/sptests/configure.ac                    |    1 +
 testsuites/sptests/spfatal_support/init.c          |   32 +----------
 testsuites/sptests/spinternalerror02/Makefile.am   |   19 ++++++
 testsuites/sptests/spinternalerror02/init.c        |   61 ++++++++++++++++++++
 .../spinternalerror02/spinternalerror02.doc        |   11 ++++
 .../spinternalerror02/spinternalerror02.scn        |   28 +++++++++
 11 files changed, 193 insertions(+), 63 deletions(-)
 create mode 100644 cpukit/sapi/src/interrdesc.c
 create mode 100644 testsuites/sptests/spinternalerror02/Makefile.am
 create mode 100644 testsuites/sptests/spinternalerror02/init.c
 create mode 100644 testsuites/sptests/spinternalerror02/spinternalerror02.doc
 create mode 100644 testsuites/sptests/spinternalerror02/spinternalerror02.scn
diff --git a/cpukit/sapi/Makefile.am b/cpukit/sapi/Makefile.am
index 67f11eb..4406708 100644
--- a/cpukit/sapi/Makefile.am
+++ b/cpukit/sapi/Makefile.am
@@ -37,7 +37,7 @@ libsapi_a_SOURCES = src/debug.c src/extension.c src/extensioncreate.c \
     src/iounregisterdriver.c src/iowrite.c src/posixapi.c  \
     src/rtemsapi.c src/extensiondata.c src/getversionstring.c \
     src/chainappendnotify.c src/chaingetnotify.c src/chaingetwait.c \
-    src/chainprependnotify.c src/rbheap.c
+    src/chainprependnotify.c src/rbheap.c src/interrdesc.c
 libsapi_a_CPPFLAGS = $(AM_CPPFLAGS)
 include $(srcdir)/preinstall.am
diff --git a/cpukit/sapi/include/rtems/fatal.h b/cpukit/sapi/include/rtems/fatal.h
index 4ddb578..8f646a9 100644
--- a/cpukit/sapi/include/rtems/fatal.h
+++ b/cpukit/sapi/include/rtems/fatal.h
@@ -23,6 +23,7 @@
 #define _RTEMS_FATAL_H
 #include <rtems/score/basedefs.h> /* RTEMS_COMPILER_NO_RETURN_ATTRIBUTE */
+#include <rtems/extension.h>
 #ifdef __cplusplus
 extern "C" {
@@ -42,6 +43,16 @@ void rtems_fatal_error_occurred(
   uint32_t   the_error
 ) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
+ * @brief Returns a description for an internal error code.
+ * @param[in] error The error code.
+ * @return The error code description or "?" in case the passed error code is
+ * invalid.
+const char *rtems_internal_error_description( rtems_fatal_code error );
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/sapi/src/interrdesc.c b/cpukit/sapi/src/interrdesc.c
new file mode 100644
index 0000000..181bcff
--- /dev/null
+++ b/cpukit/sapi/src/interrdesc.c
@@ -0,0 +1,58 @@
+ * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Obere Lagerstr. 30
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/fatal.h>
+static const char *const internal_error_desc [] = {
+  "INTERNAL_ERROR_NO_CONFIGURATION_TABLE",
+  "INTERNAL_ERROR_NO_CPU_TABLE",
+  "INTERNAL_ERROR_TOO_LITTLE_WORKSPACE",
+  "INTERNAL_ERROR_WORKSPACE_ALLOCATION",
+  "INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL",
+  "INTERNAL_ERROR_THREAD_EXITTED",
+  "INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION",
+  "INTERNAL_ERROR_INVALID_NODE",
+  "INTERNAL_ERROR_NO_MPCI",
+  "INTERNAL_ERROR_BAD_PACKET",
+  "INTERNAL_ERROR_OUT_OF_PACKETS",
+  "INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS",
+  "INTERNAL_ERROR_OUT_OF_PROXIES",
+  "INTERNAL_ERROR_INVALID_GLOBAL_ID",
+  "INTERNAL_ERROR_BAD_STACK_HOOK",
+  "INTERNAL_ERROR_BAD_ATTRIBUTES",
+  "INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY",
+  "INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL",
+  "INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE",
+  "INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0",
+  "INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP",
+  "INTERNAL_ERROR_GXX_KEY_ADD_FAILED",
+  "INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED",
+  "INTERNAL_ERROR_NO_MEMORY_FOR_HEAP"
+  size_t i = error;
+  const char *desc = "?";
+  if ( i < RTEMS_ARRAY_SIZE( internal_error_desc ) ) {
+    desc = internal_error_desc [i];
+  return desc;
diff --git a/testsuites/psxtests/psxfatal_support/init.c b/testsuites/psxtests/psxfatal_support/init.c
index e2ab241..abd9a00 100644
--- a/testsuites/psxtests/psxfatal_support/init.c
+++ b/testsuites/psxtests/psxfatal_support/init.c
@@ -68,40 +68,10 @@ char *Errors_Rtems[] = {
   "RTEMS_NOT_IMPLEMENTED"           /* directive not implemented */
-char *Errors_Core[] = {
-  "INTERNAL_ERROR_NO_CONFIGURATION_TABLE",
-  "INTERNAL_ERROR_NO_CPU_TABLE",
-  "INTERNAL_ERROR_TOO_LITTLE_WORKSPACE",
-  "INTERNAL_ERROR_WORKSPACE_ALLOCATION",
-  "INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL",
-  "INTERNAL_ERROR_THREAD_EXITTED",
-  "INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION",
-  "INTERNAL_ERROR_INVALID_NODE",
-  "INTERNAL_ERROR_NO_MPCI",
-  "INTERNAL_ERROR_BAD_PACKET",
-  "INTERNAL_ERROR_OUT_OF_PACKETS",
-  "INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS",
-  "INTERNAL_ERROR_OUT_OF_PROXIES",
-  "INTERNAL_ERROR_INVALID_GLOBAL_ID",
-  "INTERNAL_ERROR_BAD_STACK_HOOK",
-  "INTERNAL_ERROR_BAD_ATTRIBUTES",
-  "INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY",
-  "INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL",
-  "INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE",
-  "INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0",
-  "INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP",
-  "INTERNAL_ERROR_GXX_KEY_ADD_FAILED",
-  "INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED",
-  "INTERNAL_ERROR_NO_MEMORY_FOR_HEAP"
 void Put_Error( uint32_t source, uint32_t error )
   if ( source == INTERNAL_ERROR_CORE ) {
-    if ( error >  INTERNAL_ERROR_NO_MEMORY_FOR_HEAP )
-      printk("Unknown Internal Core Error (%d)", error);
-    else
-      printk( Errors_Core[ error ] );
+    printk( rtems_internal_error_description( error ) );
   else if (source == INTERNAL_ERROR_RTEMS_API ){
     if (error >  RTEMS_NOT_IMPLEMENTED )
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index b596961..1e183eb 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -31,6 +31,7 @@ SUBDIRS = \
 SUBDIRS += speventtransient01
 SUBDIRS += speventsystem01
 SUBDIRS += spinternalerror01
+SUBDIRS += spinternalerror02
 include $(top_srcdir)/../automake/subdirs.am
 include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 0f0c9bd..a71746f 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -27,6 +27,7 @@ AC_CHECK_SIZEOF([time_t])
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+spinternalerror02/Makefile
 spinternalerror01/Makefile
 speventsystem01/Makefile
 speventtransient01/Makefile
diff --git a/testsuites/sptests/spfatal_support/init.c b/testsuites/sptests/spfatal_support/init.c
index 9822b13..c9fb7f7 100644
--- a/testsuites/sptests/spfatal_support/init.c
+++ b/testsuites/sptests/spfatal_support/init.c
@@ -69,40 +69,10 @@ char *Errors_Rtems[] = {
-    else
diff --git a/testsuites/sptests/spinternalerror02/Makefile.am b/testsuites/sptests/spinternalerror02/Makefile.am
index 0000000..600e74b
--- /dev/null
+++ b/testsuites/sptests/spinternalerror02/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spinternalerror02
+spinternalerror02_SOURCES = init.c
+dist_rtems_tests_DATA = spinternalerror02.scn spinternalerror02.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spinternalerror02_OBJECTS)
+LINK_LIBS = $(spinternalerror02_LDLIBS)
+spinternalerror02$(EXEEXT): $(spinternalerror02_OBJECTS) $(spinternalerror02_DEPENDENCIES)
+	@rm -f spinternalerror02$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 0000000..357ea5b
--- /dev/null
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -0,0 +1,61 @@
+ *  82178 Puchheim
+ *  Germany
+#ifdef HAVE_CONFIG_H
+#endif
+#include "tmacros.h"
+#include <rtems.h>
+static void test(void)
+  rtems_fatal_code error = 0;
+  const char *desc_last = NULL;
+  const char *desc;
+  do {
+    desc_last = desc;
+    desc = rtems_internal_error_description( error );
+    ++error;
+    puts( desc );
+  } while ( desc != desc_last );
+  rtems_test_assert( error - 3 == INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
+static void Init(rtems_task_argument arg)
+  puts("\n\n*** TEST SPINTERNALERROR 2 ***");
+  test();
+  puts("*** END OF TEST SPINTERNALERROR 2 ***");
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spinternalerror02/spinternalerror02.doc b/testsuites/sptests/spinternalerror02/spinternalerror02.doc
index 0000000..ebae4f0
--- /dev/null
+++ b/testsuites/sptests/spinternalerror02/spinternalerror02.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spinternalerror02
+directives:
+  rtems_internal_error_description()
+concepts:
+  - Ensure that rtems_internal_error_description() works for some values.
diff --git a/testsuites/sptests/spinternalerror02/spinternalerror02.scn b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
index 0000000..c1152c4
--- /dev/null
+++ b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
@@ -0,0 +1,28 @@
+*** TEST SPINTERNALERROR 2 ***
+INTERNAL_ERROR_NO_CONFIGURATION_TABLE
+INTERNAL_ERROR_NO_CPU_TABLE
+INTERNAL_ERROR_TOO_LITTLE_WORKSPACE
+INTERNAL_ERROR_WORKSPACE_ALLOCATION
+INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL
+INTERNAL_ERROR_THREAD_EXITTED
+INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION
+INTERNAL_ERROR_INVALID_NODE
+INTERNAL_ERROR_NO_MPCI
+INTERNAL_ERROR_BAD_PACKET
+INTERNAL_ERROR_OUT_OF_PACKETS
+INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS
+INTERNAL_ERROR_OUT_OF_PROXIES
+INTERNAL_ERROR_INVALID_GLOBAL_ID
+INTERNAL_ERROR_BAD_STACK_HOOK
+INTERNAL_ERROR_BAD_ATTRIBUTES
+INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY
+INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL
+INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE
+INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0
+INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP
+INTERNAL_ERROR_GXX_KEY_ADD_FAILED
+INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED
+INTERNAL_ERROR_NO_MEMORY_FOR_HEAP
+*** END OF TEST SPINTERNALERROR 2 ***
1.7.7
