[PATCH 05/16] score: Add INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
Sebastian Huber
Wed Nov 14 15:46:59 UTC 2012
Use INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR on PowerPC for
_CPU_ISR_install_vector().
c/src/lib/libcpu/powerpc/new-exceptions/cpu.c | 22 -------------
cpukit/sapi/src/interrdesc.c | 3 +-
cpukit/score/cpu/powerpc/Makefile.am | 1 +
cpukit/score/cpu/powerpc/ppc-isr-vector-install.c | 33 ++++++++++++++++++++
cpukit/score/include/rtems/score/interr.h | 3 +-
testsuites/sptests/spinternalerror02/init.c | 2 +-
.../spinternalerror02/spinternalerror02.scn | 1 +
7 files changed, 40 insertions(+), 25 deletions(-)
create mode 100644 cpukit/score/cpu/powerpc/ppc-isr-vector-install.c
diff --git a/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c b/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c
index cb944ba..7ce7e2f 100644
--- a/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c
+++ b/c/src/lib/libcpu/powerpc/new-exceptions/cpu.c
@@ -132,25 +132,3 @@ void _CPU_Context_Initialize(
_CPU_Context_initialize_altivec(the_context);
#endif
-/* _CPU_ISR_install_vector
- * This kernel routine installs the RTEMS handler for the
- * specified vector.
- * Input parameters:
- * vector - interrupt vector number
- * old_handler - former ISR for this vector number
- * new_handler - replacement ISR for this vector number
- * Output parameters: NONE
-void _CPU_ISR_install_vector(
- uint32_t vector,
- proc_ptr new_handler,
- proc_ptr *old_handler
- BSP_panic("_CPU_ISR_install_vector called\n");
diff --git a/cpukit/sapi/src/interrdesc.c b/cpukit/sapi/src/interrdesc.c
index 181bcff..5eab683 100644
--- a/cpukit/sapi/src/interrdesc.c
+++ b/cpukit/sapi/src/interrdesc.c
@@ -42,7 +42,8 @@ static const char *const internal_error_desc [] = {
"INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP",
"INTERNAL_ERROR_GXX_KEY_ADD_FAILED",
"INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED",
- "INTERNAL_ERROR_NO_MEMORY_FOR_HEAP"
+ "INTERNAL_ERROR_NO_MEMORY_FOR_HEAP",
+ "INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR"
const char *rtems_internal_error_description( rtems_fatal_code error )
diff --git a/cpukit/score/cpu/powerpc/Makefile.am b/cpukit/score/cpu/powerpc/Makefile.am
index 65007ef..e8b2f92 100644
--- a/cpukit/score/cpu/powerpc/Makefile.am
+++ b/cpukit/score/cpu/powerpc/Makefile.am
@@ -13,6 +13,7 @@ include_rtems_powerpc_HEADERS = rtems/powerpc/registers.h
noinst_LIBRARIES = libscorecpu.a
libscorecpu_a_SOURCES = cpu.c
+libscorecpu_a_SOURCES += ppc-isr-vector-install.c
libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
include $(srcdir)/preinstall.am
diff --git a/cpukit/score/cpu/powerpc/ppc-isr-vector-install.c b/cpukit/score/cpu/powerpc/ppc-isr-vector-install.c
new file mode 100644
index 0000000..4b8e81a
--- /dev/null
+++ b/cpukit/score/cpu/powerpc/ppc-isr-vector-install.c
@@ -0,0 +1,33 @@
+ * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Obere Lagerstr. 30
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/score/cpu.h>
+#include <rtems/score/interr.h>
+void _CPU_ISR_install_vector(
+ uint32_t vector,
+ proc_ptr new_handler,
+ proc_ptr *old_handler
+ _Internal_error_Occurred(
+ INTERNAL_ERROR_CORE,
+ false,
+ INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 8aa85ae..6d823a3 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -73,7 +73,8 @@ typedef enum {
INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP,
INTERNAL_ERROR_GXX_KEY_ADD_FAILED,
INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED,
- INTERNAL_ERROR_NO_MEMORY_FOR_HEAP
+ INTERNAL_ERROR_NO_MEMORY_FOR_HEAP,
} Internal_errors_Core_list;
typedef uint32_t Internal_errors_t;
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 357ea5b..79b36ca 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -33,7 +33,7 @@ static void test(void)
puts( desc );
} while ( desc != desc_last );
- rtems_test_assert( error - 3 == INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
+ rtems_test_assert( error - 3 == INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR );
static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spinternalerror02/spinternalerror02.scn b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
index c1152c4..6fdbed6 100644
--- a/testsuites/sptests/spinternalerror02/spinternalerror02.scn
+++ b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
@@ -23,6 +23,7 @@ INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP
+INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
*** END OF TEST SPINTERNALERROR 2 ***
1.7.7
