[PATCH 15/16] score: Add RTEMS_FATAL_SOURCE_ASSERT
Sebastian Huber
Wed Nov 14 15:47:09 UTC 2012
cpukit/libcsupport/src/__assert.c | 2 +-
cpukit/score/include/rtems/score/interr.h | 7 +++++++
testsuites/sptests/spfatal10/testcase.h | 8 +++++---
testsuites/sptests/spfatal11/testcase.h | 2 +-
4 files changed, 14 insertions(+), 5 deletions(-)
diff --git a/cpukit/libcsupport/src/__assert.c b/cpukit/libcsupport/src/__assert.c
index 5adefdf..07af01b 100644
--- a/cpukit/libcsupport/src/__assert.c
+++ b/cpukit/libcsupport/src/__assert.c
@@ -34,7 +34,7 @@ void __assert_func(
(func) ? ", function: " : "",
(func) ? func : ""
- rtems_fatal_error_occurred(0);
+ rtems_fatal( RTEMS_FATAL_SOURCE_ASSERT, (rtems_fatal_code) func );
#endif
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index b316fbf..20efcb3 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -84,6 +84,13 @@ typedef enum {
RTEMS_FATAL_SOURCE_BSP_SPECIFIC,
+ * @brief Fatal source of assert().
+ * The fatal code is the pointer value of the function string.
+ RTEMS_FATAL_SOURCE_ASSERT,
* @brief The last available fatal source.
* This enum value ensures that the enum type needs at least 32-bits for
diff --git a/testsuites/sptests/spfatal10/testcase.h b/testsuites/sptests/spfatal10/testcase.h
index 6d011ce..9af96d9 100644
--- a/testsuites/sptests/spfatal10/testcase.h
+++ b/testsuites/sptests/spfatal10/testcase.h
@@ -10,15 +10,17 @@
#include <assert.h>
+static const char func [] = "Init";
#define FATAL_ERROR_TEST_NAME "10"
#define FATAL_ERROR_DESCRIPTION "asserting with non-NULL strings..."
-#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_RTEMS_API
+#define FATAL_ERROR_EXPECTED_SOURCE RTEMS_FATAL_SOURCE_ASSERT
#define FATAL_ERROR_EXPECTED_IS_INTERNAL FALSE
-#define FATAL_ERROR_EXPECTED_ERROR 0
+#define FATAL_ERROR_EXPECTED_ERROR ((rtems_fatal_code) func)
void force_error()
- __assert_func( __FILE__, __LINE__, "Init", "forced" );
+ __assert_func( __FILE__, __LINE__, func, "forced" );
/* we will not run this far */
diff --git a/testsuites/sptests/spfatal11/testcase.h b/testsuites/sptests/spfatal11/testcase.h
index 43a4ab2..055b95c 100644
--- a/testsuites/sptests/spfatal11/testcase.h
+++ b/testsuites/sptests/spfatal11/testcase.h
@@ -12,7 +12,7 @@
#define FATAL_ERROR_TEST_NAME "11"
1.7.7
