[PATCH] score: Add CPU_Exception_frame
Thu Nov 22 11:20:57 UTC 2012
This usage of the error code leads to problems on a 64-bit target since
sizeof(void *) >= sizeof(uint32_t) (= type of error code).  Maybe we should use
an integer type like uintptr_t for the error code which is at least 32-bit wide.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
