[PATCH 09/15] Clean up compiler warnings
Ric Claus
claus at slac.stanford.edu
Tue Nov 27 03:26:47 UTC 2012
c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c | 23 ++++++++++---------
c/src/lib/libbsp/powerpc/virtex4/preinstall.am | 4 +++
.../lib/libbsp/powerpc/virtex4/startup/bspstart.c | 19 ++-------------
3 files changed, 19 insertions(+), 27 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c b/c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c
index ffcfe4c..89e921d 100644
--- a/c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c
@@ -35,21 +35,21 @@ rtems_irq_global_settings* BSP_rtems_irq_config;
* these functions just do nothing fulfill the semantic
* requirements to enable/disable a certain interrupt or exception
-void BSP_irq_nop_func(const rtems_irq_connect_data *unused)
+static void BSP_irq_nop_func(const rtems_irq_connect_data *unused)
* nothing to do
-void BSP_irq_nop_hdl(void *hdl)
+static void BSP_irq_nop_hdl(void *hdl)
* nothing to do
-int BSP_irq_isOn_func(const rtems_irq_connect_data *unused)
+static int BSP_irq_isOn_func(const rtems_irq_connect_data *unused)
* nothing to do
@@ -64,7 +64,7 @@ int BSP_irq_isOn_func(const rtems_irq_connect_data *unused)
* functions to enable/disable/query external/critical interrupts
-void BSP_irqexc_on_fnc(rtems_irq_connect_data *conn_data)
+static void BSP_irqexc_on_fnc(const rtems_irq_connect_data *conn_data)
uint32_t msr_value;
@@ -76,7 +76,7 @@ void BSP_irqexc_on_fnc(rtems_irq_connect_data *conn_data)
_CPU_MSR_SET(msr_value);
-void BSP_irqexc_off_fnc(rtems_irq_connect_data *unused)
+static void BSP_irqexc_off_fnc(const rtems_irq_connect_data *unused)
uint32_t msr_value;
@@ -91,7 +91,8 @@ void BSP_irqexc_off_fnc(rtems_irq_connect_data *unused)
* High level IRQ handler called from shared_raw_irq_code_entry
-int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
+static int C_dispatch_irq_handler (BSP_Exception_frame *frame,
+ unsigned int excNum)
* Handle interrupt
@@ -275,17 +276,17 @@ int BSP_rtems_irq_mngt_set(rtems_irq_global_settings* config)
* dummy for an empty IRQ handler entry
static rtems_irq_connect_data emptyIrq = {
- 0, /* Irq Name */
+ 0, /* IRQ Name */
BSP_irq_nop_hdl, /* handler function */
NULL, /* handle passed to handler */
- BSP_irq_nop_func, /* on function */
- BSP_irq_nop_func, /* off function */
+ BSP_irqexc_on_fnc, /* on function */
+ BSP_irqexc_off_fnc, /* off function */
BSP_irq_isOn_func /* isOn function */
static rtems_irq_global_settings initialConfig = {
- BSP_IRQ_NUMBER, /* irqNb */
- { 0, /* Irq Name */
+ BSP_IRQ_NUMBER, /* IRQ Number */
+ { 0, /* IRQ Name */
diff --git a/c/src/lib/libbsp/powerpc/virtex4/preinstall.am b/c/src/lib/libbsp/powerpc/virtex4/preinstall.am
index 34b03f1..e441f38 100644
--- a/c/src/lib/libbsp/powerpc/virtex4/preinstall.am
+++ b/c/src/lib/libbsp/powerpc/virtex4/preinstall.am
@@ -69,6 +69,10 @@ $(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
+$(PROJECT_INCLUDE)/bsp/mmu.h: include/mmu.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mmu.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mmu.h
$(PROJECT_INCLUDE)/bsp/vectors.h: ../../../libcpu/@RTEMS_CPU@/@exceptions@/bspsupport/vectors.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/vectors.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/vectors.h
diff --git a/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c b/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c
index ed9e45e..40c519f 100644
--- a/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c
@@ -138,24 +138,14 @@ void BSP_ask_for_reset(void)
void BSP_panic(char *s)
- rtems_interrupt_level level;
- rtems_interrupt_disable(level);
printk("\n%s PANIC %s\n", rtems_get_version_string(), s);
BSP_ask_for_reset();
void _BSP_Fatal_error(unsigned int v)
printk("\n%s FATAL ERROR %x\n", rtems_get_version_string(), v);
@@ -205,12 +195,9 @@ void bsp_start(void)
intrStackStart = CPU_UP_ALIGN((uint32_t)__bsp_ram_start);
intrStackSize = rtems_configuration_get_interrupt_stack_size();
- sc = ppc_exc_initialize(PPC_INTERRUPT_DISABLE_MASK_DEFAULT,
- intrStackStart,
- intrStackSize);
- if (sc != RTEMS_SUCCESSFUL) {
- BSP_panic("Cannot initialize exceptions");
+ ppc_exc_initialize(PPC_INTERRUPT_DISABLE_MASK_DEFAULT,
+ intrStackStart,
+ intrStackSize);
/* Let the user know what parameters we were compiled with */
printk(" Base/Start End Size\n"
1.7.1
