[PATCH 01/15] PR 2048 - Removed use of PPC440 macro from asm.h and moved affected macros to registers.h
Claus, Ric claus at slac.stanford.edu
Tue Nov 27 18:04:34 UTC 2012
IMHO, they are necessary.  They improve the readability and clarity of the code.  I suggest applying the patch and 'diff -b'.
Ric
________________________________________
From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] On Behalf Of Sebastian Huber [sebastian.huber at embedded-brains.de]
Sent: Tuesday, November 27, 2012 12:04 AM
To: rtems-devel at rtems.org
Subject: Re: [PATCH 01/15] PR 2048 - Removed use of PPC440 macro from asm.h and moved affected macros to registers.h
There are a lot of white space changes in this patch.  Can you please separate
the white space changes from the other changes.  Are the white space changes
really necessary?
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
rtems-devel mailing list
http://www.rtems.org/mailman/listinfo/rtems-devel
