[PATCH 02/15] Added -o to mount command usage statement
Claus, Ric
claus at slac.stanford.edu
Tue Nov 27 18:16:54 UTC 2012
Right, on both counts.
Ric
________________________________________
From: gedare at gwmail.gwu.edu [gedare at gwmail.gwu.edu] On Behalf Of Gedare Bloom [gedare at rtems.org]
Sent: Tuesday, November 27, 2012 6:25 AM
To: Claus, Ric
Cc: rtems-devel at rtems.org
Subject: Re: [PATCH 02/15] Added -o to mount command usage statement
This (and 3,4) seem separate from the submission of the virtex4/ppc changes.
Other than the spurious whitespace changes, this looks straightforward
to me. I suppose the -o already is supported, just not shown in usage
message?
-Gedare
On Mon, Nov 26, 2012 at 10:26 PM, Ric Claus <claus at slac.stanford.edu> wrote:
> cpukit/libmisc/shell/main_mount.c | 16 ++++++++--------
> 1 files changed, 8 insertions(+), 8 deletions(-)
> diff --git a/cpukit/libmisc/shell/main_mount.c b/cpukit/libmisc/shell/main_mount.c
> index 1fe688f..27f417a 100644
> --- a/cpukit/libmisc/shell/main_mount.c
> +++ b/cpukit/libmisc/shell/main_mount.c
> @@ -51,7 +51,7 @@ static int rtems_shell_main_mount(
> if (arg == argc) {
> fprintf(
> stderr,
> - "%s: -t needs a type of file-system;; see -L.\n",
> + "%s: -t needs a type of file-system; see -L.\n",
> argv[0]
> return 1;
> @@ -69,7 +69,7 @@ static int rtems_shell_main_mount(
> if (arg == argc) {
> fprintf(
> stderr,
> - "%s: -o needs a list if filesystem options.\n",
> + "%s: -o needs a list of filesystem options.\n",
> argv[0]
> return 1;
> @@ -122,10 +122,10 @@ static int rtems_shell_main_mount(
> rtems_shell_cmd_t rtems_shell_MOUNT_Command = {
> - "mount", /* name */
> - "mount [-t type] [-r] [-L] source target", /* usage */
> - "files", /* topic */
> - rtems_shell_main_mount, /* command */
> - NULL, /* alias */
> - NULL /* next */
> + "mount", /* name */
> + "mount [-t type] [-r] [-L] [-o options] source target", /* usage */
> + "files", /* topic */
> + rtems_shell_main_mount, /* command */
> + NULL, /* alias */
> + NULL /* next */
> 1.7.1
> rtems-devel mailing list
