[PATCH 4/8] dosfs: Delete fattype parameter for msdos_format()
Ralf Kirchner ralf.kirchner at embedded-brains.de
Thu Nov 29 14:32:42 UTC 2012
Delete fattype parameter of msdos_format_request_param_t because the FAT
type is determined by cluster and disk size.
Estimate FAT type and re-evaluate FAT type after exact parameter
determination.
 cpukit/libfs/src/dosfs/dosfs.h                 |    6 -
 cpukit/libfs/src/dosfs/msdos_format.c          |  303 +++++++++++++-----------
 cpukit/libmisc/shell/main_msdosfmt.c           |   25 +-
 testsuites/fstests/mdosfs_support/fs_support.c |    1 -
 4 Dateien geändert, 167 Zeilen hinzugefügt(+), 168 Zeilen entfernt(-)
diff --git a/cpukit/libfs/src/dosfs/dosfs.h b/cpukit/libfs/src/dosfs/dosfs.h
index 530d23e..163c44b 100644
--- a/cpukit/libfs/src/dosfs/dosfs.h
+++ b/cpukit/libfs/src/dosfs/dosfs.h
@@ -26,11 +26,6 @@ extern "C" {
 int rtems_dosfs_initialize(rtems_filesystem_mount_table_entry_t *mt_entry,
                            const void                           *data);
-#define MSDOS_FMT_FATANY 0
-#define MSDOS_FMT_FAT12  1
-#define MSDOS_FMT_FAT16  2
-#define MSDOS_FMT_FAT32  3
 #define MSDOS_FMT_INFO_LEVEL_NONE   (0)
 #define MSDOS_FMT_INFO_LEVEL_INFO   (1)
 #define MSDOS_FMT_INFO_LEVEL_DETAIL (2)
@@ -46,7 +41,6 @@ typedef struct {
   uint32_t  sectors_per_cluster;  /* request value: sectors per cluster    */
   uint32_t  fat_num;              /* request value: number of FATs on disk */
   uint32_t  files_per_root_dir;   /* request value: file entries in root   */
-  uint8_t   fattype;              /* request value: MSDOS_FMT_FAT12/16/32  */
   uint8_t   media;                /* media code. default: 0xF8             */
   bool      quick_format;         /* true: do not clear out data sectors   */
   bool      skip_alignment;       /* do not align FAT, data cluster, and   */
diff --git a/cpukit/libfs/src/dosfs/msdos_format.c b/cpukit/libfs/src/dosfs/msdos_format.c
index e8107a2..507f37e 100644
--- a/cpukit/libfs/src/dosfs/msdos_format.c
+++ b/cpukit/libfs/src/dosfs/msdos_format.c
@@ -300,7 +300,8 @@ static int msdos_format_eval_sectors_per_cluster
  uint32_t   sectors_per_cluster,      /* sectors per cluster (requested)  */
  const bool skip_alignment,          /* true for no cluster alignment */
  uint32_t *sectors_per_cluster_adj,  /* ret: sec per cluster (granted)   */
- uint32_t *sectors_per_fat_ptr       /* ret: sectors needed for one FAT  */
+ uint32_t *sectors_per_fat_ptr,      /* ret: sectors needed for one FAT  */
+ uint32_t *data_cluster_cnt
 | Return Value:                                                             |
@@ -313,7 +314,6 @@ static int msdos_format_eval_sectors_per_cluster
   uint32_t fatdata_cluster_cnt;
   uint32_t fat_capacity;
   uint32_t sectors_per_fat;
-  uint32_t data_cluster_cnt;
   uint32_t fatdata_sect_cnt;
   uint32_t fat_sectors_cnt;
@@ -352,15 +352,15 @@ static int msdos_format_eval_sectors_per_cluster
     fat_sectors_cnt = loc_align_object (sectors_per_fat * fat_num, sectors_per_cluster, skip_alignment);
-    data_cluster_cnt = (fatdata_cluster_cnt -
+    *data_cluster_cnt = (fatdata_cluster_cnt -
 			((fat_sectors_cnt
 			  + (sectors_per_cluster - 1))
 			 / sectors_per_cluster));
      * data cluster count too big? Then make clusters bigger
-    if (((fattype == FAT_FAT12) && (data_cluster_cnt > FAT_FAT12_MAX_CLN)) ||
-        ((fattype == FAT_FAT16) && (data_cluster_cnt > FAT_FAT16_MAX_CLN))) {
+    if (((fattype == FAT_FAT12) && (*data_cluster_cnt > FAT_FAT12_MAX_CLN)) ||
+        ((fattype == FAT_FAT16) && (*data_cluster_cnt > FAT_FAT16_MAX_CLN))) {
       sectors_per_cluster *= 2;
     else {
@@ -389,7 +389,6 @@ static int msdos_format_eval_sectors_per_cluster
   return 0;
 | Function:        |
@@ -414,6 +413,9 @@ static int msdos_format_determine_fmt_params
   uint32_t onebit;
   uint32_t sectors_per_cluster_adj = 0;
   uint64_t total_size = 0;
+  uint32_t data_clusters_cnt;
+  uint8_t  iteration_cnt = 0;
+  uint8_t  fat_type = UINT8_MAX;
   memset(fmt_params,0,sizeof(*fmt_params));
@@ -491,153 +493,178 @@ static int msdos_format_determine_fmt_params
   if (ret_val == 0) {
     fmt_params->sectors_per_cluster = 1;
-    if ((rqdata != NULL) &&
-	      (rqdata->fattype == MSDOS_FMT_FAT12)) {
+     * limiting values for disk size, fat type, sectors per cluster
+     * NOTE: maximum sect_per_clust is arbitrarily choosen with values that
+     * are a compromise concerning capacity and efficency
+    uint32_t fat12_sect_per_clust = 8;
+    uint32_t fat16_sect_per_clust = 32;
+    if (rqdata != NULL && rqdata->sectors_per_cluster != 0) {
+      fat12_sect_per_clust = rqdata->sectors_per_cluster;
+      fat16_sect_per_clust = rqdata->sectors_per_cluster;
+    if (fmt_params->totl_sector_cnt < FAT_FAT12_MAX_CLN * fat12_sect_per_clust) {
       fmt_params->fattype = FAT_FAT12;
+      /* start trying with small clusters */
+      fmt_params->sectors_per_cluster = 2;
-    else if ((rqdata != NULL) &&
-	           (rqdata->fattype == MSDOS_FMT_FAT16)) {
+    else if (fmt_params->totl_sector_cnt < FAT_FAT16_MAX_CLN * fat16_sect_per_clust) {
       fmt_params->fattype = FAT_FAT16;
-	           (rqdata->fattype == MSDOS_FMT_FAT32)) {
+    else {
+      #define ONE_GB (1024L * 1024L * 1024L)
+      uint32_t gigs = (total_size + ONE_GB) / ONE_GB;
+      int b;
       fmt_params->fattype = FAT_FAT32;
+      /* scale with the size of disk... */
+      for (b = 31; b > 0; b--)
+        if ((gigs & (1 << b)) != 0)
+          break;
+      fmt_params->sectors_per_cluster = 1 << b;
-	           (rqdata->fattype != MSDOS_FMT_FATANY)) {
-      ret_val = -1;
-      errno = EINVAL;
-    else {
+    while (   (0 == ret_val)
+           && (fmt_params->fattype != fat_type)) {
-       * limiting values for disk size, fat type, sectors per cluster
-       * NOTE: maximum sect_per_clust is arbitrarily choosen with values that
-       * are a compromise concerning capacity and efficency
+       * try to use user requested cluster size
-      uint32_t fat12_sect_per_clust = 8;
-      uint32_t fat16_sect_per_clust = 32;
-      if (rqdata != NULL && rqdata->sectors_per_cluster != 0) {
-        fat12_sect_per_clust = rqdata->sectors_per_cluster;
-        fat16_sect_per_clust = rqdata->sectors_per_cluster;
-      if (fmt_params->totl_sector_cnt < FAT_FAT12_MAX_CLN * fat12_sect_per_clust) {
-        fmt_params->fattype = FAT_FAT12;
-        /* start trying with small clusters */
-        fmt_params->sectors_per_cluster = 2;
+      if ((rqdata != NULL) &&
+          (rqdata->sectors_per_cluster > 0)) {
+        fmt_params->sectors_per_cluster = rqdata->sectors_per_cluster;
-      else if (fmt_params->totl_sector_cnt < FAT_FAT16_MAX_CLN * fat16_sect_per_clust) {
-        fmt_params->fattype = FAT_FAT16;
+       * check sectors per cluster.
+       * must be power of 2
+       * must be smaller than or equal to 128
+       * sectors_per_cluster*bytes_per_sector must not be bigger than 32K
+      for (onebit = 128;onebit >= 1;onebit = onebit>>1) {
+        if (fmt_params->sectors_per_cluster >= onebit) {
+          fmt_params->sectors_per_cluster = onebit;
+          if (fmt_params->sectors_per_cluster <= 32768L/fmt_params->bytes_per_sector) {
+            /* value is small enough so this value is ok */
+            onebit = 1;
-      else {
-        #define ONE_GB (1024L * 1024L * 1024L)
-        uint32_t gigs = (total_size + ONE_GB) / ONE_GB;
-        int b;
-        fmt_params->fattype = FAT_FAT32;
-        /* scale with the size of disk... */
-        for (b = 31; b > 0; b--)
-          if ((gigs & (1 << b)) != 0)
-            break;
-        fmt_params->sectors_per_cluster = 1 << b;
+       * Skip aligning structures or d align them
+      if (   (0    == ret_val)
+          && (NULL != rqdata))
+        fmt_params->skip_alignment = rqdata->skip_alignment;
+        if (fmt_params->skip_alignment)
+          fmt_params->sectors_per_cluster = 1;
-     * try to use user requested cluster size
-	      (rqdata->sectors_per_cluster > 0)) {
-      fmt_params->sectors_per_cluster = rqdata->sectors_per_cluster;
-     * check sectors per cluster.
-     * must be power of 2
-     * must be smaller than or equal to 128
-     * sectors_per_cluster*bytes_per_sector must not be bigger than 32K
-    for (onebit = 128;onebit >= 1;onebit = onebit>>1) {
-      if (fmt_params->sectors_per_cluster >= onebit) {
-	      fmt_params->sectors_per_cluster = onebit;
-	      if (fmt_params->sectors_per_cluster <= 32768L/fmt_params->bytes_per_sector) {
-	        /* value is small enough so this value is ok */
-	        onebit = 1;
+      if (ret_val == 0) {
+        msdos_format_printf (rqdata, MSDOS_FMT_INFO_LEVEL_DETAIL,
+                             "sectors per cluster: %d\n", fmt_params->sectors_per_cluster);
+        if (fmt_params->fattype == FAT_FAT32) {
+          /* recommended: for FAT32, always set reserved sector count to 32 */
+          fmt_params->rsvd_sector_cnt = 32;
+          /* for FAT32, always set files per root directory 0 */
+          fmt_params->files_per_root_dir = 0;
+          /* location of copy of MBR */
+          fmt_params->mbr_copy_sec = 6;
+          /* location of fsinfo sector */
+          fmt_params->fsinfo_sec = 1;
+        else {
+          /* recommended: for FAT12/FAT16, always set reserved sector count to 1 */
+          fmt_params->rsvd_sector_cnt = 1;
+          /* recommended: for FAT16, set files per root directory to 512 */
+          /* for FAT12/FAT16, set files per root directory */
+          /* must fill up an even count of sectors         */
+              (rqdata->files_per_root_dir > 0)) {
+            fmt_params->files_per_root_dir = rqdata->files_per_root_dir;
+          else {
+            if (fmt_params->fattype == FAT_FAT16) {
+              fmt_params->files_per_root_dir = 512;
+            else {
+              fmt_params->files_per_root_dir = 64;
+          fmt_params->files_per_root_dir = (fmt_params->files_per_root_dir +
+                                           (2*fmt_params->bytes_per_sector/
+                                           FAT_DIRENTRY_SIZE-1));
+          fmt_params->files_per_root_dir -= (fmt_params->files_per_root_dir %
+                                            /FAT_DIRENTRY_SIZE));
+        fmt_params->root_dir_sectors =
+          (((fmt_params->files_per_root_dir * FAT_DIRENTRY_SIZE)
+            + fmt_params->bytes_per_sector - 1)
+           / fmt_params->bytes_per_sector);
+         * check values to get legal arrangement of FAT type and cluster count
-   * Skip aligning structures or d align them
-  if (   (0    == ret_val)
-      && (NULL != rqdata)) {
-    fmt_params->skip_alignment = rqdata->skip_alignment;
-  if (ret_val == 0) {
-    msdos_format_printf (rqdata, MSDOS_FMT_INFO_LEVEL_DETAIL,
-                         "sectors per cluster: %d\n", fmt_params->sectors_per_cluster);
-    if (fmt_params->fattype == FAT_FAT32) {
-      /* recommended: for FAT32, always set reserved sector count to 32 */
-      fmt_params->rsvd_sector_cnt = 32;
-      /* for FAT32, always set files per root directory 0 */
-      fmt_params->files_per_root_dir = 0;
-      /* location of copy of MBR */
-      fmt_params->mbr_copy_sec = 6;
-      /* location of fsinfo sector */
-      fmt_params->fsinfo_sec = 1;
+        ret_val = msdos_format_eval_sectors_per_cluster
+          (fmt_params->fattype,
+           fmt_params->bytes_per_sector,
+           fmt_params->totl_sector_cnt,
+           fmt_params->rsvd_sector_cnt,
+           fmt_params->root_dir_sectors,
+           fmt_params->fat_num,
+           fmt_params->sectors_per_cluster,
+           fmt_params->skip_alignment,
+           &sectors_per_cluster_adj,
+           &(fmt_params->sectors_per_fat),
+           &data_clusters_cnt);
+        fmt_params->sectors_per_cluster = sectors_per_cluster_adj;
+        fat_type = fmt_params->fattype;
+        if (data_clusters_cnt < FAT_FAT12_MAX_CLN ) {
+          fmt_params->fattype = FAT_FAT12;
+          if (fat_type != fmt_params->fattype) {
+        else if (data_clusters_cnt < FAT_FAT16_MAX_CLN) {
+          fmt_params->fattype = FAT_FAT16;
+        else {
+          fmt_params->fattype = FAT_FAT32;
+            int b;
+                break;
+        if (   (fat_type != fmt_params->fattype)
+            && (1 < iteration_cnt)) {
+          --fmt_params->totl_sector_cnt;
-    else {
-      /* recommended: for FAT12/FAT16, always set reserved sector count to 1 */
-      fmt_params->rsvd_sector_cnt = 1;
-      /* recommended: for FAT16, set files per root directory to 512 */
-      /* for FAT12/FAT16, set files per root directory */
-      /* must fill up an even count of sectors         */
-	        (rqdata->files_per_root_dir > 0)) {
-	      fmt_params->files_per_root_dir = rqdata->files_per_root_dir;
-      else {
-	      if (fmt_params->fattype == FAT_FAT16) {
-	        fmt_params->files_per_root_dir = 512;
-	      else {
-	        fmt_params->files_per_root_dir = 64;
-      fmt_params->files_per_root_dir = (fmt_params->files_per_root_dir +
-			                                 (2*fmt_params->bytes_per_sector/
-			                                 FAT_DIRENTRY_SIZE-1));
-      fmt_params->files_per_root_dir -= (fmt_params->files_per_root_dir %
-			                                  /FAT_DIRENTRY_SIZE));
+      ++iteration_cnt;
-    fmt_params->root_dir_sectors =
-      (((fmt_params->files_per_root_dir * FAT_DIRENTRY_SIZE)
-	      + fmt_params->bytes_per_sector - 1)
-       / fmt_params->bytes_per_sector);
-     * check values to get legal arrangement of FAT type and cluster count
-    ret_val = msdos_format_eval_sectors_per_cluster
-      (fmt_params->fattype,
-       fmt_params->bytes_per_sector,
-       fmt_params->totl_sector_cnt,
-       fmt_params->rsvd_sector_cnt,
-       fmt_params->root_dir_sectors,
-       fmt_params->fat_num,
-       fmt_params->sectors_per_cluster,
-       fmt_params->skip_alignment,
-       &sectors_per_cluster_adj,
-       &(fmt_params->sectors_per_fat));
-    fmt_params->sectors_per_cluster = sectors_per_cluster_adj;
   if (0 == ret_val)
@@ -764,6 +791,8 @@ static int msdos_format_determine_fmt_params
   return 0;
 | Function:        |
diff --git a/cpukit/libmisc/shell/main_msdosfmt.c b/cpukit/libmisc/shell/main_msdosfmt.c
index 60926b9..600f947 100644
--- a/cpukit/libmisc/shell/main_msdosfmt.c
+++ b/cpukit/libmisc/shell/main_msdosfmt.c
@@ -33,7 +33,6 @@ static int rtems_shell_main_msdos_format(
     .sectors_per_cluster = 0,
     .fat_num =             0,
     .files_per_root_dir =  0,
-    .fattype =             MSDOS_FMT_FATANY,
     .media =               0,
     .quick_format =        TRUE,
     .skip_alignment =      0,
@@ -92,27 +91,6 @@ static int rtems_shell_main_msdos_format(
           rqdata.files_per_root_dir = (uint32_t) tmp;
           break;
-        case 't':
-          arg++;
-          if (arg == argc) {
-            fprintf (stderr, "error: no FAT type.\n");
-            return 1;
-          if (strcmp (argv[arg], "any") == 0)
-            rqdata.fattype = MSDOS_FMT_FATANY;
-          else if (strcmp (argv[arg], "12") == 0)
-            rqdata.fattype = MSDOS_FMT_FAT12;
-          else if (strcmp (argv[arg], "16") == 0)
-            rqdata.fattype = MSDOS_FMT_FAT16;
-          else if (strcmp (argv[arg], "32") == 0)
-            rqdata.fattype = MSDOS_FMT_FAT32;
-          else {
-            fprintf (stderr, "error: invalid type, can any, 12, 16, or 32\n");
-            return 1;
-          break;
         case 'v':
           rqdata.info_level++;
           break;
@@ -146,7 +124,6 @@ static int rtems_shell_main_msdos_format(
     printf (" %-20s: %" PRIu32 "\n", "sectors per cluster", rqdata.sectors_per_cluster);
     printf (" %-20s: %" PRIu32 "\n", "fats", rqdata.fat_num);
     printf (" %-20s: %" PRIu32 "\n", "files per root dir", rqdata.files_per_root_dir);
-    printf (" %-20s: %i\n", "fat type", rqdata.fattype);
     printf (" %-20s: %d\n", "media", rqdata.media);
     printf (" %-20s: %d\n", "quick_format", rqdata.quick_format);
     printf (" %-20s: %s\n", "skip_alignment", (0 == rqdata.skip_alignment) ? "false" : "true");
@@ -162,7 +139,7 @@ static int rtems_shell_main_msdos_format(
   return 0;
-#define OPTIONS "[-v label] [-r size] [-t any/12/16/32]"
+#define OPTIONS "[-v label] [-r size]"
 rtems_shell_cmd_t rtems_shell_MSDOSFMT_Command = {
   "mkdos",                                   /* name */
diff --git a/testsuites/fstests/mdosfs_support/fs_support.c b/testsuites/fstests/mdosfs_support/fs_support.c
index c58379a..123e9df 100644
--- a/testsuites/fstests/mdosfs_support/fs_support.c
+++ b/testsuites/fstests/mdosfs_support/fs_support.c
@@ -31,7 +31,6 @@ msdos_format_request_param_t rqdata = {
     sectors_per_cluster: 0,
     fat_num:             0,
     files_per_root_dir:  0,
-    fattype:             MSDOS_FMT_FATANY,
     media:               0,
     quick_format:        FALSE,
     skip_alignment:      0,
1.7.10.4
