[PATCH 2/8] dosfs: Fix msdos_format()
Gedare Bloom
gedare at rtems.org
Thu Nov 29 17:02:26 UTC 2012
On Thu, Nov 29, 2012 at 9:32 AM, Ralf Kirchner <
ralf.kirchner at embedded-brains.de> wrote:
> For FAT32 msdos_format() used to initialize first FAT entries to
> non-zero values only if a volume label was given. Absense of these
Typo: Absence
> entries made mounting such a FAT32 volume fail.
> cpukit/libfs/src/dosfs/msdos_format.c | 2 +-
> 1 Datei geändert, 1 Zeile hinzugefügt(+), 1 Zeile entfernt(-)
> diff --git a/cpukit/libfs/src/dosfs/msdos_format.c
> b/cpukit/libfs/src/dosfs/msdos_format.c
> index 305cec9..974c00d 100644
> --- a/cpukit/libfs/src/dosfs/msdos_format.c
> +++ b/cpukit/libfs/src/dosfs/msdos_format.c
> @@ -1063,7 +1063,7 @@ int msdos_format
> * write FAT entry 1 as EOC
> * allocate directory in a FAT32 FS
> - if ((ret_val == 0) && fmt_params.VolLabel_present){
> + if (ret_val == 0){
While you're at it, please add a space between ) and {
> * empty sector: all clusters are free/do not link further on
> 1.7.10.4
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20121129/04fd2665/attachment-0001.html>
