[rtems-libbsd commit] Added rtems specific version of _pthread_main_np()
Ralf Corsepius ralf.corsepius at rtems.org
Fri Oct 5 17:03:01 UTC 2012
On 10/05/2012 04:31 PM, Jennifer Averett wrote:
> Module:    rtems-libbsd
> Branch:    master
> Commit:    45a81cdc5e8c9ed35a8aa706e0ea360d357a574b
> Changeset: http://git.rtems.org/rtems-libbsd/commit/?id=45a81cdc5e8c9ed35a8aa706e0ea360d357a574b
> Author:    Jennifer Averett <jennifer.averett at oarcorp.com>
> Date:      Fri Oct  5 09:34:09 2012 -0500
> This required adding rtems_id rtems_init_task_id to identify the
> main task.
Two remarks:
> + * Provide the equivalent to Solaris thr_main() function
a) Why should RTEMS care about Solaris' thr_main()?
Solaris threads are dead for decades and nobody with a sane mind will
use them. The rationale for adding this escapes me.
> +int
> +_pthread_main_np()
> +  /* Created and set in rtems_bsd_initialize */
> +  extern rtems_id rtems_init_task_id;
This is a nested extern. It's something, many people consider _really_
bad design, because it renders code unreliable and error-prone.
Personally I have been fighting such nested externs as long as I had
been involved into RTEMS.
Please consider using a private global definition or even a static
variable instead.
Ralf
