FIx for pc386 QEMU wrapper - Was: pc386.in - allow graphic display emulation with qemu
Pavel Pisa
ppisa4lists at pikron.com
Sat Oct 6 16:22:19 UTC 2012
Hello Joel,
I am testing committed patches and I have found that
there there was left one copy of the line by mistake
in "rtems-testing". Please, can you remove it and commit.
diff --git a/sim-scripts/pc386.in b/sim-scripts/pc386.in
index 9c35cde..40998c0 100644
--- a/sim-scripts/pc386.in
+++ b/sim-scripts/pc386.in
@@ -79,7 +79,6 @@ runARGS()
# 486 or pentium for older qemu
echo "-m 512 -boot a -cpu 486 \
-fda ${fd0Image} -hda fat:${hd0Dir} ${COVERAGE_ARG} \
- -monitor null -nographic -serial ${SERIAL_ARG} --no-reboot"
-monitor null ${GRAPHIC_ARG} -serial ${SERIAL_ARG} --no-reboot"
As for the Cirrus driver, I have build it successfully and tested
with Alex's version of RTEMS Graphic Toolkit. I have added
information about use under QEMU on the RTEMS Graphic Toolkit
page.
http://www.rtems.org/wiki/index.php/RTEMSGraphicsToolkit#Running_RTEMS_Graphics_Toolkit_under_QEMU
I have found some minor problem with USE_CIRRUS_GD5446 option propagation.
When used as temporary only assignment for configure
USE_CIRRUS_GD5446=1 ./configure --enable-rtemsbsp=pc686 ...
make
make install
it is not recorded and recursive later configuration at make time
does not use the option.
If used as
export USE_CIRRUS_GD5446=1
make
make install
everything work.
Best wishes,
Pavel
PS: Alex, please, try to fill some more info about graphic
toolkit state.
