core spinlock wait returns immediately
Thu Oct 11 21:56:45 UTC 2012
Are you doing this at user-level? I don't think core spinlock part of
the public API...
I haven't looked closely at the code to tell if it supports using the
attributes the way you suggest, so I don't know the answer to your
question.
-Gedare
On Thu, Oct 11, 2012 at 4:46 PM, Andrei Dimitrief-Jianu
<andrei.dimitrief.jianu at gmail.com> wrote:
> On Thu, Oct 11, 2012 at 9:58 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> Is the spinlock already locked? if not it would return immediately
>> Did the thread that's attempting to gain the lock previuosly lock it?
>> if so it would return immediately
>> -Gedare
>> On Wed, Oct 10, 2012 at 11:59 PM, Andrei Dimitrief-Jianu
>>> Hello,
>>> I initialize a core spinlock using the code below:
>>>   CORE_spinlock_Attributes spinlock_attributes;
>>>   spinlock_attributes.XXX = 0;
>>>   _CORE_spinlock_Initialize( &spinlock, &spinlock_attributes );
>>> When calling wait() on the same spinlock from a worker task using the
>>> code below, the task returns w/o waiting for the spinlock to be
>>> released.
>>>   CORE_spinlock_Status spinlock_status;
>>>   spinlock_status = _CORE_spinlock_Wait( &spinlock, true, 0 );
>>> Anything that is obvious that I am doing wrong?
>>> Thanks!
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
> I need to have a worker task waiting on the spinlock until
> the main task is releasing the lock or the spinlock times out.
> The CORE_spinlock exposes 3 functions:
> void _CORE_spinlock_Initialize(
>   CORE_spinlock_Control       *the_spinlock,
>   CORE_spinlock_Attributes    *the_spinlock_attributes
> CORE_spinlock_Status _CORE_spinlock_Wait(
>   bool                    wait,
>   Watchdog_Interval       timeout
> CORE_spinlock_Status _CORE_spinlock_Release(
> I am assuming that I can initialize the spinlock as locked or
> unlocked by passing CORE_SPINLOCK_LOCKED or CORE_SPINLOCK_UNLOCKED
> as attributes to _CORE_spinlock_Initialize().
> Once the spinlock is initialized as locked by the main task, I can
> call _CORE_spinlock_Wait() from the worker task to block until
> _CORE_spinlock_Release() is called by the main task or the call times out.
> The problem that I have is that the worker task does not block. I am not
> sure that the approach described above is the right one.
> Thanks!
