New Work Area Initialization API
Mon Oct 15 14:49:28 UTC 2012
I skimmed the patch series and saw no obvious issues.
Overall, I like the change. It unifies more of the bsp startup code,
and if it later permits the use of malloc sooner then it may help with
generalizing the bsp_early_malloc in sparc.
I saw one BSP that uses the new feature. Is there any documentation of
how to use the feature, or maybe just a pointer to that BSP for the
interested BSP-developer?
-Gedare
On Mon, Oct 15, 2012 at 9:04 AM, Sebastian Huber
> The work areas (RTEMS work space and C program heap) will be initialized now in
> a separate step and are no longer part of rtems_initialize_data_structures().
> Initialization is performed with tables of Heap_Area entries.  This allows
> usage of scattered memory areas present on various small scale
> micro-controllers.
> The sbrk() support API changes also.  The bsp_sbrk_init() must now deal with a
> minimum size for the first memory chunk to take the configured work space size
> into account.
> rtems-devel mailing list
> rtems-devel at rtems.org
